Old 01-16-2026, 09:09 PM   #1359
zeal86
zeal86's Avatar
Drives:
I'm installing my Monogram interior into the BRZ whose condition is 10 out of 10. It was removed early on in my other build then wrapped in plastic for a long time.
I'll likely spray the headliner flat black to go along with the rest of the interior. The BRZ's interior will be mint very soon.
Pictures don't do the condition of the seats justice.
zeal86 is offline   Reply With Quote
Old 01-16-2026, 11:22 PM   #1360
zeal86
zeal86's Avatar
Drives:
Originally Posted by Wally86 View Post
Wait, plug and play?? (I haven't looked at the connector of the OEM port)
And if it is plug and play does it still allow carplay on the bottom port?
No, It just powers and charges devices. The charger snaps right into the OEM location and has two different style connectors that work with other Toyotas. Unfortunately, it is not plug and play for our chassis...I wired it into the OEM 12v plug.
I extended the USB coming off the head unit and installed it in the location of the old 12v plug...that's where I have Android Auto connectivity.
Old 01-21-2026, 04:10 AM   #1361
zeal86
zeal86's Avatar
Drives:
I completed another mod. This particular mod drops the height level of the rear deck brake light. The end result is a cleaner look and better visibility.
I saw a video where a guy CNC'ed a piece of aluminum to basically accomplish what I did with the OEM plastic.
I had started making a handmade aluminum base for this mod but changed my mind and went with the version you see pictured below.
**I still need to check the fitment of this mod against the rear glass and verify it comes as close to the glass as possible. I may need to make an adjustment but I'm really hoping I don't.
Back of rear brake light removed.
Cut off three risers with dremel. Use DA sander or sandpaper on a block to flatten cutoff risers. Drill hole for rivets, cut aluminum to size, and install with rivets. Drill three M8 holes into aluminum...use rear deck panel as a template. File M8 holes into squares just big enough for the squared heads of the carriage bolts.
Painted flat side of brake light
Painted light
Painted flat side with carriage bolts.
Carriage bolts need to be clearanced. Use duct tape to hold in place.
Assembled flat side and light bezel
Nuts and washers installed. Hand tighten these to be safe. If you tighten too much, light bezel and flat bottom side separate from each other.
Rear deck brake light installed. I cleaned and painted rear deck panel with Dupli-Color flat black vinyl and fabric paint.
Closeups of rear brake light installed.
TOOLS USED:
- River Squeezer/Puller or Hammer and Bucking Bar
- Countersunk Rivets (I used size 4-4 w/ 426 Head)
- Drill bit (I used a #30 bit)
- 1 Inch Wide Strip of Aluminum
- Hot Glue Gun
- Grinder or File
- Dremel with Cutoff Wheel
- Sand Paper on block or DA Sander
- Duct Tape
HARDWARE USED:
5/16 x 1inch Carriage Bolt - x3
5/16 Nut - x3
5/16 Flat Washer - x3
Flat Top Hole Friction Clip - x2
Old 01-24-2026, 07:13 AM   #1362
zeal86
zeal86's Avatar
Drives:
I picked up another set of tail lights for the Monogram. These are a used set of Valenti Jewel LED tail lights with gold reflectors. I had been looking for a set I could put a little elbow grease into and get them looking as close to a 9 to 10 in condition.
So, I cleaned and polished my set and I feel I have achieved an 8.5 to 9. Not a higher score because of a couple of issues...one, there are a couple internal blemishes and two, there is a little dirt stuck between the edges of the glass and plastic that I haven't been able to clean it out yet.
I did not use sandpaper in restoring the tails...I used a foam pad with Maguire's Ultimate Compound followed by Maguire's Mirror Glaze on a cloth buffing pad. I did 4 passes with the foam pad and 2 with the Mirror Glaze. I shined the black plastic with Maguire's Ultimate Black. I used this Mini Polisher https://www.amazon.com/dp/B0FQJM1SYX...ap_share<br />
The whole theme for my Monogram is red, gold and black so these are perfect.
Old pics to show theme and why these tails work. My engine bay will be updated with Cusco, KTS, and Blitz parts. The interior is also red with gold accents.
_______________________________________________
BEFORE:
AFTER:
Old 02-08-2026, 03:20 AM   #1363
zeal86
zeal86's Avatar
Drives:
I ordered a shift and e-brake boot combo from Amazon. https://a.co/d/0g72nTOo
I was very impressed with the quality of the work on these boots. The JTS product line is made in the USA. The shift boot is a perfect fit and easy install. Both boots are made of thick and lush suede. The stitch and suede colors match my BRZ's interior nicely. The price and delivery time was on point. Communication with the seller was exceptional. All in all, I'm happy with my purchase.
I may take a stab at learning how to sew in the upcoming months. I would love to be able to complete every aspect of my builds on my own.
Old 03-06-2026, 11:51 PM   #1364
zeal86
zeal86's Avatar
Drives:
I have acquired an FA24 engine out of a 2025 GR86. I actually acquired everything that wasn't damaged in the accident...so I have the transmission, rear subframe, differential, axles, steering rack,and drive shaft. Donor GR86 had 4,550 miles at time of accident. Thanks to Mani @Eight6ersgarage for making the aforementioned parts and chassis available to me.
I'll be installing the engine and all the aforementioned components in a 2019 Toyota 86 TRD. The TRD has just under 24k miles on the chassis. I'll swap the TRD's components over to the BRZ. The BRZ will get the RS1's engine and transmission. The RS1 will get the BRZ's engine and transmission. Basically, the newest parts on the newest chassis.
I have about three issues to figure out with the BRZ before I pull out the engine and transmission. I did get the interior pretty much done but I didn't get pics before I left the state for work. Even though I'm away right now for work, I brought parts from the FA24 with me to polish. I also brought an extra alternator to polish...I may have also brought an extra throttle body to polish...idk...I forget. I'm staying busy though.Name:  FA24 4550.jpg
Size:  145.9 KBName:  2019 Toyota 86 TRD Chassis_1.jpg
Sent from my moto g power - 2025 using Tapatalk
Old 03-29-2026, 08:56 PM   #1365
zeal86
zeal86's Avatar
Drives:
Picked these up for my '19 86 TRD while working out of state. I drove 4 hours (2 & 2) to pick them up. I got a great deal on the wheels and tires.
They are in pretty good shape but I'm still going to get them refinished and change the SSR logo on the wheels to a Cusco blue. I may keep the same black color though. I'll end up replacing the tire brand with something Japanese.
I'll be swapping all the red in the TRD for a cusco / anodized blue color.
Square Setup:
SSR GTX01 5x100 18x9.5 +40
265/35 ContinentalsName:  SSR GTX01 5x100 18x9.5 +40 - 2.jpg
Size:  162.6 KBName:  SSR GTX01 5x100 18x9.5 +40 - 3.jpg
Old 04-06-2026, 09:58 PM   #1366
zeal86
zeal86's Avatar
Drives:
Parts from my FA24 that are ready to be polished:
Old 04-14-2026, 11:19 AM   #1367
zeal86
zeal86's Avatar
Drives:
I recently picked up a set of SSR GTX01 18x9.5 +40 (square) wheels for my FA24 swap TRD 86 build. The wheels were used but in really good condition. They were originally powder coated matte black but I decided to go gloss black to seperate them from my Work Emotion CR2P and Work Meister L13P Wheels that are flat and matte black.
Plan for the TRD 86 is to completely change the OEM red theme to a Cusco blue theme. That means interior stitching will be swapped to blue. I plan on going with blue Bride seats in the future as well.
The TRD 86 will be almost exclusively Greddy parts. It will stay NA.
My themes are:
Mono - WB/HKS/Work Meister L13P >> Red theme, SC (Hot)
BRZ - NB/Blitz/Work Emotion CR2P >> Red theme, Turbo (Hot)
TRD - NB/Greddy/SSR GTX01 >> Blue theme, Cold (NA)
Three JDM giants! I hope to bring them all to a Wekfest in the future. Will be a crazy setup!
Old 04-15-2026, 01:01 AM   #1368
zeal86
zeal86's Avatar
Drives:
The SSR gloss black super low center caps I ordered arrived today. They look perfect with the gloss black powder coat.
Old 04-27-2026, 07:47 AM   #1369
zeal86
zeal86's Avatar
Drives:
Some more FA24 parts ready for polishing. Only have a few small parts left for the FA24 to polish. I may get the two brackets I cleaned up powder coated with a chrome or polished finish.
FA24 Alternator
FA24 Engine Bracket
For the BRZ Limited. Bracket painted to prevent corrosion.
BRZ Shifter Frame and Rubber Boot
[img]https://i.vgy.me/BP84ua.jpg[/img[
Old 04-27-2026, 08:49 AM   #1370
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Hey I also painted my boot trim piece. Mine had some strange corrosion so I did the same. Feels good knowing when you have to dig it back up, it'll be fresh! I wish I had the patience to polish like you do, my parts always come out pretty bleh in comparison. I'm always hoping you'll throw something into classifieds so I can grab it hahaha. Awesome as always!
Old 04-27-2026, 07:12 PM   #1371
zeal86
zeal86's Avatar
Drives:
I have a severe case of "While I have this apart"...lol I'm always going down that rabbit hole.
In the future...once I'm done with my builds, I will likely polish and powder coats parts for others as a service. I will also likely make parts like door strap pulls and engine covers. I'll probably make the parts out of fiberglass, aluminum, and I may get into 3D printing.
I'm about to start learning how to paint...I'm excited for the introduction...practice will make perfect. I'm also looking to start learning how to sew. So much to do...never enough time.
Old 04-27-2026, 07:49 PM   #1372
zeal86
zeal86's Avatar
Drives:
I got a good deal on these wheels that I couldn't pass up.
They are Work Emotion MR8 19x9.5 +38 5x114.3. Square set up.
I had them repaired and powder coated a low black (20%) sheen.
I ordered the black high type Work Emotion caps.
Finished product looks pretty good.
I am leaning towards flipping these wheels or trading them for parts or other widebody wheels. If you are interested hit me up.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
