go_a_way1
Old 09-02-2025, 05:57 PM   #6035
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by BRZCR View Post
Shouldn’t my water/meth cover the gap between 91 and 93 octane? I know it isn’t the same, but I understand it adds knock resistance.
I skipped over that part. Yes, the water meth will help some.
JDMChris is offline   Reply With Quote
Old 11-08-2025, 11:58 AM   #6036
BRZCR
Drives: BRZ 2017
Has anyone changed the open filter setup that comes with the kit? DYI boxes, compatible aftermarket CAIs, ducting, etc. To prevent heat soak and improve IAT.
I’ve seen a couple of posts in this thread but I just have to ask again and see if anyone else has done it or in a different way and their results.
BRZCR is offline   Reply With Quote
Old 11-12-2025, 11:42 PM   #6037
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I would start by wrapping the charge pipe immediately before the throttle body in gold DEI wrap. That pipe’s proximity to the blower gets it real hot in a hurry. Monitor your temps before and after see if that gets you the results you want.
BlueWhelan is offline   Reply With Quote
Old 11-25-2025, 02:33 PM   #6038
arxm
Drives: 2013 FR-S, 2023 BRZ
Hey guys, does anyone know the length of the belt used or a part number for goodyear/gates/bando etc? I need to replace my belt but because of import fees and exchange rate the gates belt on JR website will end up costing me about 275 so im trying to find one locally, I would measure the belt myself but I dont have access to it anymore lol
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 11-27-2025, 03:41 PM   #6039
mrg666
pessimistic skeptic
mrg666's Avatar
I use the followings, whichever you can find
https://www.amazon.com/gp/product/B000UO8MAG
and
https://www.amazon.com/gp/product/B08SNTX1QZ
Old 11-27-2025, 04:12 PM   #6040
mrg666
pessimistic skeptic
mrg666's Avatar
I use the following dry flow filter. It is direct replacement. I just don't like oiling the filter for the risk of throwing oil on the MAF sensor.
https://www.amazon.com/gp/product/B00GBQ741K
I have not seen any cold air intake modification making any significant difference over the 50% power increase.
The most significant difference was replacing my exhaust with HKS HiPower SpecL and front pipe with HKS catless dual resonator pipe. The straight through configuration plus removing the second cat increased power and throttle response. I can't tell how much though. I have also replaced the header with larger diameter 2019 header. The first cat is still in place.
Above all, if you are going to make one modification only, get the JR dual radiator. That doesn't make more power, but helps tremendously with cooling. Heat soak robs the power. Save what you have first.
The Following User Says Thank You to mrg666 For This Useful Post:
BlueWhelan (11-27-2025)
Old 11-27-2025, 06:48 PM   #6041
BlueWhelan
BlueWhelan's Avatar
The most significant difference was replacing my exhaust with HKS HiPower SpecL and front pipe with HKS catless dual resonator pipe. The straight trough configuration plus removing the second cat increased power and throttle response. I can't tell how much though. I have also replaced the header with larger diameter 2019 header. The first cat is still in place.
Above all, if you are going to make one modification only, get the JR dual radiator. That doesn't make more power, but helps tremendously with cooling. Heath soak robs the power. save what you have first.
Jackson Racing themselves are actually using these for the kits now. I just ordered a replacement and they shipped me the AEM dryflow instead of the standard K&N
The Following User Says Thank You to BlueWhelan For This Useful Post:
mrg666 (11-28-2025)
Old 11-28-2025, 09:08 AM   #6042
mrg666
pessimistic skeptic
mrg666's Avatar
Good to know. These dry-flows last forever too. I have not replaced in years. I am thinking the recirculation valve is cleaning the filter with reverse flow.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
