Old 09-15-2025, 08:12 PM   #1
gnarjunkie
Drives: '23 GR86, '17 BRZ
Great deal on Karcepts sway bar, worried it'll be too stiff
I am continuing to setup my GR86 for CST class while keeping it my daily street car.
Right now, I have Tarmac 2's and RLCAs, no other mods. -2.6 degrees camber front, -2.0 rear.
Only competing at the local level, though we have a lot of fast drivers who place upper pack at nationals. I am competitive with them, often in top 5 PAX and always within top 10, usually out of 60-70 drivers.
I've been finding the car to be really good with just these basic mods.
Another driver has a full set of Karcepts bars for this platform for sale for a great price. Only thing is that it's the stiffer of the two front bar options.
Karcepts recommends the softer bar for 215-245 width tires and under -4 degrees camber. That fits my car.
The stiffer bar is meant for cars with 245-275 tires and -4 to -5 degrees camber.
I'm on 245s, but probably won't go past -3.2 degrees camber anytime soon. Maybe a touch more, but not up to -4 range.
I'm a bit worried about getting these and being overly stiff in the front. I already find that the car gets a bit understeer-happy later in the day when the lot starts to get really hot.
gnarjunkie is offline   Reply With Quote
Old 09-16-2025, 02:58 AM   #2
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I think you can just change out the center sections with those bars.
autoracer86 is offline   Reply With Quote
Old 09-16-2025, 12:09 PM   #3
steverife
Drives: 2016 Scion FRS
The stiffer Karcepts bar set at 1/1 is softer that almost all aftermarket front bars you see on autocross twins.
steverife is offline   Reply With Quote
Old 09-18-2025, 10:20 AM   #4
gnarjunkie
You can, but the center section is $500. So pretty much removes any savings at that point from buying the used one.
That's helpful!
Old 09-19-2025, 06:43 AM   #5
steverife
You will want to confirm that the Karcepts bar has full functionality with your coilovers. The Karcepts piece was designed for OE/MCS swaybar mounting.
Old 09-22-2025, 11:21 PM   #6
gnarjunkie
Thank you -- I've had a couple other people mention the same thing. Unfortunately, they are not fully compatible with my RCEs. Sounds like it's possible to have them modified to work maybe?
I'm holding off for the moment but seems like these are the best bars out there so it would be nice to make them work. I like the adjustability idea a lot.
Old 10-23-2025, 07:14 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The compromise for “don’t fit” in my experience is that you can’t use the full stiff holes which shouldn’t matter for the stiffer center section. Shooting Mr. Karwan an email is well worth it - he’ll Brain dump clarity and some great advice off the cuff. In any case I agree with Steve above, for a car going to ST the larger center section isn’t a problem, I oscillate between 2/2 and 2/3 on mine even with softer springs, 3/3 is usually too stiff. One of my coilovers I can’t use the #4 hole.
10/10 swaybar zero regrets
ineedyourdiddly
FS: Karcepts Rear Sway Bar RedReplicant Brakes, Suspension, Chassis 1 05-27-2024 12:21 AM
FS: Karcepts Front Sway Bar BrandonD1GP Brakes, Suspension, Chassis 3 03-19-2023 05:40 PM
Karcepts front sway bar. Simmons BRZ Second-Gen (2022+) — General Topics 3 03-21-2022 09:00 AM
Struts that work with Karcepts sway bar 86prime Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-13-2021 08:21 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
