| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2014 Scion FRS
DIY OLM/VLAND Headlight Install
#2 |
Drives: 2018 CWP Subaru BRZ Sport-tech RS
What's the difference between the OLM headlights and the VLAND headlights?
IG: @matt_hui95
#3 |
#4 |
Drives: 2020 Toyota GT86
OLM Headlight Issues
So I have a 2020 Toyota 86 which has an 8 pin harness and turn signals inside the stock headlights. A lot of people have said it’s plug n play but I’m having issues getting my turn signals working. I followed the video above changing the white wire connection but my turn signals aren’t working at all. Am I missing something?…PLEASE HELP
#5 | |
Be Kind
Drives: 2020 86
In picture: Yellow in headlight to white on 8pin harness. Yellow/White in headlight to white headlight leveler wire. (Boomerang DRL) Option: Yellow/White in headlight to yellow 8pin harness. (No boomerang DRL)
#6 |
You are a god. Thanks my guy!
#7 |
Drives: 2016 FRS
I haven't seen anyone mention this but I have a 2016 frs that has a bottom drl. would that need to be removed for the headlight drls to work or could they be spliced together so they both work?
#8 |
Drives: 2013 Black Scion FRS
DRL also keep bulbs on?
I have the new v3 vland headlights. everything works but one thing: when my daytime lights are on its also turning on my low and high beams? any idea why?
#9 | |
Be Kind
Drives: 2020 86
Could most likely splice them but I have no idea where the bottom DRLs are wired. Time for a multimeter! Sent from my iPhone using Tapatalk Pro
#10 | |
Be Kind
Drives: 2020 86
I don't have v3s so who knows how they're wired differently. I'd grab a multimeter and a 12v tester and start testing *insert thumbs up here* Sent from my iPhone using Tapatalk Pro
| Vland Headlight Installation | mackattack55 | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 07-31-2020 07:05 AM |
| vland headlight bulb | mcnvgget | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-14-2019 06:11 PM |
| VLAND Headlight HID Kit | Kai Uhl | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-02-2019 11:49 PM |
| Vland Headlight question | Sikku | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-12-2019 09:50 AM |
| Vland Headlight question | Sikku | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 04-03-2019 02:46 PM |
