Old 06-30-2025, 08:21 AM   #197
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by RToyo86 View Post
The surface is pretty grippy. My understanding was that they mixed granite into the pour which has made the surface more abrasive/harder on tires as surface has worn.
There is plans to resurface the track likely 2026. Connection I know wants to connect them with whoever did surface at road America and get the same mix.
Ah, that makes sense. There's no shortage of granite up that way and all of the highways are made from it.
It will last forever...
The Following User Says Thank You to new2subaru For This Useful Post:
RToyo86 (07-05-2025)
Old 07-05-2025, 02:11 AM   #198
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Jackson racing shrouded oil cooler installed. Shroud was in raw aluminum finish, primed and painted it my self. Only did a 20 minute drive to get everything hot to check for leaks, but oil temps were barely able to crack 190f in cool 17c night air. Temps were actually dropping cruising at 120kmh lol.. I will probably switch back to 0w20 if temps remain sub 200 on the street.
Added some rubber moulding near the headlights to soften sharp edges wrapped the cooler lines in a abrasion resistant sleeve.
RToyo86 is online now   Reply With Quote
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
NLSP (07-06-2025), SuperTom (08-19-2025)
Old 07-06-2025, 05:26 PM   #199
RToyo86
RToyo86's Avatar
Reinstalled the OEM license plate bracket whuch conveniently sits directly infront of the shroud for the oil cooler. This did exactly what I was hoping for and brought oil temps up to 195-212f range driving around. Four screws and it comes off when I go to the track.
autoracer86 (07-07-2025), SuperTom (07-06-2025)
Old 07-07-2025, 07:21 AM   #200
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Great to know about blocking it off. Seems easy enough
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
RToyo86 (07-28-2025)
Old 08-19-2025, 10:17 AM   #201
RToyo86
RToyo86's Avatar
Made some time to get in a two hour lapping night the other day. Mounted 245/40 Nankang CRS a couple weeks back to replace RS4. Car handled great, and oil temps peaked at 220F and ran the car for 35 minutes straight, then another 25 then 15-20 with short breaks between.
The Following 8 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (08-19-2025), KMA KiCKz (08-23-2025), new2subaru (08-19-2025), NLSP (08-21-2025), spcmafia (08-28-2025), StraightOuttaCanadaEh (08-19-2025), Teseo (08-19-2025), villainous_frx (08-20-2025)
Old 08-19-2025, 09:36 PM   #202
RToyo86
RToyo86's Avatar
Pulled my dashcam footage and clipped a bunch together.
About time I invest in a proper lap timer, rough clipping has one of decent clean laps around a 1:24.3 with track a bit slower since NASCAR Canada race event 2 weeks prior. A friend of mine with a fast NC Miata who was there ran a 1:24.8 but typically runs high 1:21.x.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (08-21-2025), KMA KiCKz (08-23-2025), new2subaru (08-20-2025)
Old 08-21-2025, 07:43 AM   #203
autoracer86
Drives: Toyota GT86
Nice driving Lines look pretty good and looked smooth as well
RToyo86 (08-21-2025)
Old 09-07-2025, 11:34 PM   #204
RToyo86
RToyo86's Avatar
Another lapping night at bogie, track was super busy. PD'd 2.29.6 with the one good clean lap chasing a Turbo NB Miata on old RS4s. T
Car ran great.. tires are pretty beat up after 4 sessions around 20 minutes each. Can't wait for CMP to resurface the track.
Old 10-13-2025, 03:38 PM   #205
RToyo86
RToyo86's Avatar
Had a set of Konig hyperspec installed in 17x9 +40 Anthracite finish. Remounted Conti ecs02.
The plan is to swap between these for street use and keep my CSF1s for track duty. Quite happy with them, I will say pictures don't do them Justice, need to see them in person.
Drift shoot with Ryan's 2jz FRS Amillionoh7 Scion FR-S / Toyota 86 GT86 General Forum 0 07-28-2016 11:11 AM
Ryan Tuerck shift knob ChrisP Cosmetic Modification (Interior/Exterior/Lighting) 12 01-22-2016 09:38 PM
Ryan Tuerck’s Street FRS Sideways&Smiling Scion FR-S / Toyota 86 GT86 General Forum 1 10-01-2014 12:07 PM
Ryan Higa owns an FRS? tekkenman Off-Topic Lounge [WARNING: NO POLITICS] 13 06-21-2013 07:48 PM
FAO Ryan GeeTee86 AFRICA 4 05-31-2013 11:46 AM
