Old 06-26-2012, 12:56 PM   #1
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Subaru BRZ parts catalog
Sorry if this is a repost but I've searched and can't find (perhaps not posted yet) a parts manual showing the parts and part numbers for BRZ's.
So...is this info available?
Thanks!
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 06-26-2012, 02:07 PM   #2
thermobox
Drives: 16 Impreza 5dr CWP
Whoops. Thought you meant Accessories.
thermobox is offline   Reply With Quote
Old 06-26-2012, 02:36 PM   #3
sparks
sparks's Avatar
There are 2 catalogs for Dealers, however they are not available to the public. What part numbers do you need?
sparks is offline   Reply With Quote
Old 06-26-2012, 03:09 PM   #4
BMWDavid
Need the part number for the engine oil drain plug sealing washer. As long as I'm asking also would like the part numbers for the manual trans drain and fill sealing washers and the final drive drain and fill sealing washers.
It's easier to go to the dealer with the P/N's ready than to look everything up there.
Thanks.
2005 Honda XR650L
2006 VW GTI/DSG
Old 06-26-2012, 03:20 PM   #5
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Thanks.
Oil Drain Gasket: 803916010
M/T Fill plug gasket: 17008AA050 - I can't find the drain plug gasket in the parts lookup diagram BUT, it says it uses a quantity of 2 for the fill plug gasket....maybe they are the same?
Rear Diff Fill plug gasket: 11126JB000
Rear Diff Drain plug gasket: 1215710010
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 06-26-2012, 03:48 PM   #6
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Anyone have the Subaru part number for the rear differential (complete) and the LSD (just the Torsen unit)?
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-26-2012, 06:04 PM   #7
BMWDavid
A big thanks
2005 Honda XR650L
2006 VW GTI/DSG
Old 06-27-2012, 08:16 AM   #8
sparks
sparks's Avatar
Jeff
DIFF - 4111018020
LSD - 4130153020
Old 06-27-2012, 09:09 AM   #9
Tman08
Tman08's Avatar
Drives: DGM BRZ Limited
Not sure where I could post this without creating another thread. Does anyone know if the steering wheel controls will be an option down the road?
I know some of you don't like them, but saw them the other day on a pre-production car:
Tman08 is offline   Reply With Quote
The Following User Says Thank You to Tman08 For This Useful Post:
chanomatik (01-30-2014)
Old 08-05-2012, 11:18 PM   #10
Verge
Verge's Avatar
Drives: 2013 Scion FRS
Looking for part number on door sensors . Auto Hvac parts. And push start parts.
Thank you . Looking to do a Jdm conversion and subby parts may be a bit cheaper
Verge is offline   Reply With Quote
Old 01-02-2013, 10:20 AM   #11
Basti
Basti's Avatar
can you please provide the part number for
rear seatback lock sub-assembly (both sides)
rear seatback lock release band
for clarification please see points 7 and 9 of the link below:
http://www.pic-upload.de/view-17540633/Foto-3.png.html
if the sub-assy can be split into several part numbers that'd be even better
Thanks a lot!
Basti is offline   Reply With Quote
Old 01-02-2013, 11:43 AM   #12
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
If that's something down the road, how much will it cost to add a steering wheel with controls to a 2013 BRZ? anyone know?
chenshuo is offline   Reply With Quote
Old 01-02-2013, 11:49 AM   #13
OrbitalEllipses
Drives: Attitude
More money/trouble than it's worth due the likely possibility that the wiring harness for that doesn't exist in current MY cars.
adprokid (01-02-2013)
Old 01-02-2013, 04:35 PM   #14
Basti
Basti's Avatar
I wouldn't be so sure about that. The CC is obviously already in there and for the radio one might probably be able to use some of the AT-ready wiring (if there's any)
Still, even if a OEM steering wheel like that were to come it'd most likely be quite an easy mod. Done something similar already. I just hope it comes at all. Then we'll see
'til then: can someone get me the part numbers from my a/m post?
FR-S PARTS CATALOG SYSTEM IS UP AND RUNNING TPO Scion FR-S / Toyota 86 GT86 General Forum 96 06-03-2015 05:16 PM
Luck 86/FR-S/BRZ Project Parts Catalog kanundrum Engine, Exhaust, Transmission 58 05-24-2015 01:29 PM
SCION FR-S ACCESSORIES CATALOG IS UP TPO Scion FR-S / Toyota 86 GT86 General Forum 50 05-23-2012 11:23 PM
Mod parts from Subaru. Lottta BRZ First-Gen (2012+) — General Topics 24 02-06-2012 06:50 PM
