Old 06-07-2023, 12:12 AM   #323
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Originally Posted by chas3wba0 View Post
Question: if I already have the flexfuel kit (custom tuned for turbo) installed and then I decide to upgrade headers, does that require a re-tune at both 91 and e85? Or will simply updating the tune at e85 suffice?
If header was already catless then it's likely ok it may make turbo spool a little different and possibly hit boost limiter but unlikely just log data and check but should be fine
AussieBRZ is offline   Reply With Quote
The Following User Says Thank You to AussieBRZ For This Useful Post:
chas3wba0 (06-07-2023)
Old 06-07-2023, 03:15 PM   #324
chas3wba0
chas3wba0's Avatar
Drives: Yes
It was actually the stock catted header before, and now it's an aftermarket UEL catted header. Definitely spools differently and the gains have shifted toward the higher RPM end. Amazing on E85, and 91 feels like shiite by comparison (which is expected).
Just wondering if there would be any benefit to re-tuning specifically at 91 but my tuner said as long as they adjusted the tune on E85, the rest scales automatically based on ethanol content level.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 06-07-2023, 08:53 PM   #325
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Yes unlikely anything with fueling will change tune will still target same afr and timeing dependant on load and boost
The catless header will generally increase spool and in some cases could create a possible boost increase or overboost situation. Deliceous tunes will have an overboost safety if that's not tripping it should be fine but the only real way to tell would be to log ECU data check for any knock and confirm afr is ok.The E85 flex kit will work as normal
chas3wba0 (06-10-2023)
Old 06-21-2023, 06:20 PM   #326
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by weederr33 View Post
Bumping cuz I noticed my FlexFuel bluetooth will not connect to the App. On my OnePlus, it gave the bluetooth rejected. Then I pulled out a much older phone. Connected to the box, but the app would not connect after several minutes. Wondering if there was an update to the app recently that made it buggy?
Actually going through the testing process with Google Play Store at the moment. Hoping to have the new app on the store by the start of next week. There have a been a slew of new requirements by Google over the past couple years so it has slowed down development massively.
This will resolve a few things.
1. Should work on all Android OS 10.0 and up.
2. Fuel pressure will show the correct value again.
3. More stable bluetooth connection over time.
Cheers,
William
The Following User Says Thank You to DeliciousTuning For This Useful Post:
weederr33 (06-21-2023)
Old 06-23-2023, 11:14 AM   #327
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
If my bluetooth reads the correct ethanol percentage but the ecu no longer sees a change at the O2 sensor plug, what might be the issues? No tuning changes have happened, the signal just dropped out one day.
B T is offline   Reply With Quote
Old 06-23-2023, 01:44 PM   #328
FrickingReallySlow
Drives: 2015 FR-S
Check the connection between Delicious box and O2 connector? that's how your ECU reads it. Could be lose connection/solder connection inside the box or bad connector
FrickingReallySlow is offline   Reply With Quote
Old 06-25-2023, 03:08 PM   #329
B T
Tried cleaning the connection, reconnecting all connectors. Ended up ordering a 2nd one just to rule everything out. It went out mid drive.
Old 12-31-2023, 04:47 AM   #330
Mr_Eyo
Drives: 2017 Toyota 86
Cheers,
William
It appears that the app doesn't work again with Android 14. I've enabled location services and all permissions for the app on my Pixel 7 and it won't connect from the app, but it would from the phone's bluetooth menu.
Mr_Eyo is offline   Reply With Quote
Old 04-18-2025, 02:18 AM   #331
Mr_Eyo
Anyone know how the v3 CAN bus kit installs in the gen 1 cars? The DT website shows how the gen 2 install goes, but not gen 1.
Old 06-17-2025, 03:36 PM   #332
DeliciousTuning
We have updated the information on the primary post and will be adding more as we try to answer more questions.
We have a couple options for the Gen 1 BRZ/FRS/86 Flex Fuel Kits:
1. The V3 CAN Bus integration which will require the latest EcuTek RaceROM patches. That can be found here: V3 CAN Flex Fuel
2. Classic / Universal integration for those looking to solely replace their kits, with no need for a tune as the older tune with rear O2 input worked fine for their needs. That can be found here: Classic/Universal Flex Fuel Kit
Please note that the V3 Kit will support BOTH CAN and Rear O2 input, the only difference being the harness. So if you are looking for a replacement and not quite ready to upgrade to CAN integration this is a great way to do it.
Cheers,
William Knose
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 09:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 01:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
