Old 05-14-2025, 02:15 PM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I need to sovle a brake riddle - SCCA STL
I am changing from T4 to STL because the changes to the T4 rules have made STL a more attractive proposition plus the STL group seems to have a some good growth momentum.
So.. BRAKES!
We CANNOT upgrade front rotors! We can, however upgrade the caliper. The rules spec a maximum front rotor diameter of 300mm and since OEM are 292mm, I'm basically stuck with the OEM rotor size.
So I am looking for non-floating monoblock calipers that work on the OEM rotors. Must also clear 17" wheels.
*06-07 WRX calipers look like the easy button
PROS: bolt on, cheap, symmetrical piston size so orientation doesn't matter, no issues with bias
CONS: heavier than aluminum, limited race pad options, especially where SCCA contingency exists.
05-ish WRX STI
calipers
PROS: light, inexpensive remans available, lots of pad options for racing.
CONS: Do they just bolt on? Have to swap sides to make bleeder upright but then pistons are oriented wrong, or don't swap sides but swap bleeder location.
Any other "bolt on" options that work with OEM rotor size that would be an upgrade over the oem floating caliper?
PRO86 | STL | LuckyDog
Old 05-14-2025, 02:40 PM   #2
RedReplicant
Drives: None
Forgive me as I'm not familiar with SCCA, just NASA, and this is tangental.
With NASA, factory optional brakes are considered stock in terms of points in ST/TT5. What this means is the BRZ/86/FRS can use OEM Brembos without taking a point hit.
1. Does SCCA require downsizing brakes for classing if they're larger than your specified numbers there?
2. At what point can a FRS be called a BRZ if they're picky enough that the FRS isn't a BRZ and can't use the BRZ optional brakes? Are the bumpers/badges enough?
RedReplicant is offline   Reply With Quote
Old 05-14-2025, 02:44 PM   #3
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
With NASA, factory optional brakes are considered stock in terms of points in TT5. What this means is the BRZ/86/FRS can use OEM Brembos without taking a point hit.
I think you are onto something. It appears that the stock rotors are 272mm and the PP rotors are 292mm. If that's the case, switching the Performance Pack rotors and calipers should be on the table. Wouldn't that be the case since they are an option on the platform?
RongTurnRacing is offline   Reply With Quote
Old 05-14-2025, 03:10 PM   #4
rice_classic
#1: Not sure because the STL class is for cars that are NA 2.0L and under and cars that fit that criteria generally don't have brake rotors >300mm but I suppose the ones that do would need to be compliant with the rules.
#2: AT ANY POINT! However, Subaru does NOT participate in any contingency programs so there is ZERO value in representing the brand (unless you have your own sponsorship). Toyota has contingency so in certain classes if you win, they pay $400 for each win and they also provide an amount of travel reimbursement for towing to Runoffs. So I'm fine to use ANY brakes so long as my rotor diameter doesn't exceed 300mm. The problem I find is that most other compatible calipers works so long as you put on a rotor that exceeds 300mm.
Old 05-14-2025, 04:51 PM   #5
Tokay444
Anti stance.
Tokay444's Avatar
Only in other markets. North American cars all had 292mm rotors.
Old 05-14-2025, 07:42 PM   #6
smoltz
Drives: 01 911 Turbo, 03 G500
Stock brakes with the right pads are pretty good on these cars. If that isn't sufficient, run PP Brembos. AP Sprint is 299mm also.
smoltz is offline   Reply With Quote
Old 05-15-2025, 03:21 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
PP Brembo’s would probably be your best bet. I would be afraid of the WRX calipers may mess up bias too much.
Old 05-15-2025, 11:21 AM   #8
Tokay444
Anti stance.
Tokay444's Avatar
What braking issues are you having with the factory calipers?
Don't get me wrong. I run an Essex Endurance setup because I want to, but I'm also not subject to your restrictions.
Old 05-15-2025, 11:58 AM   #9
rice_classic
Sounds good. Are they a direct bolt on and work on our 292mm rotors? Secondly, will they fit under a 17" RFP1?
The issue I have is that they are floating calipers. They are pretty good, sure, but now that I am in a class that allows me to not use "pretty good", I need to better optimize within my restrictions.
Old 05-15-2025, 12:16 PM   #10
Tokay444
Anti stance.
Tokay444's Avatar
The Brembo setup is heavier than the cast iron setup by 2lbs, unsprung. If that doesn't matter, have at it. You will need the PP rotors. RPF1s are one of the most restrictive wheels available. I never understood their popularity.
Old 05-15-2025, 12:27 PM   #11
rice_classic
Isn't the PP rotor larger than 300mm? So it looks like the WRX caliper may be front contention.
Why are RPF1 popular? Weight, price and availability. It's a nice flow form wheel, works great for air flow and maximized rule allowance (In T4 the rule was 17x7 with a minimum weight of 15lbs and the RPF1 fit that criteria perfectly, none others did at the price range). In STL we are still restricted to 17x7" wheel which is great for me since it means I don't need to buy 16 new wheels!
Old 05-15-2025, 12:47 PM   #12
Tokay444
Anti stance.
Tokay444's Avatar
Rotors are 326mm, 316mm in the rear, but the fact that they're a factory option should keep you in class.
For that size, that's not all that light, but if it fits the class rules, I understand.
Good luck. I don't feel simply being a fixed caliper outweighs the cons of the Brembo package still being a commuter car brake setup. Especially the added weight. You're not really gaining anything other than the weight. Perhaps some more thermal mass, but you don't sounds like you're at the limit of the cast iron setup from a thermal mass standpoint.
Old 05-15-2025, 12:59 PM   #13
rice_classic
Ok, so this won't work. Class has a hard ceiling of 300mm rotors.
Old 06-20-2025, 06:15 PM   #14
sleedawg
Drives: Dance in a heartbeat
Closest application I could find. $4k.
https://trialengineering.com/product...rz-toyota-gt86
"Front brake kit utilizing 4 piston forged monobloc caliper and fully floating rotor, designed specifically for use with 15" gravel wheels. Developed to provide the superior performance for Open Class and regional competition.
PFC ZR94 caliper's monobloc design increases stiffness for a firm, consistent pedal feel. The internal fluid crossover eliminating the risk of damage or failure compared to calipers with an external crossover pipe.
299x32mm rotors are the go-to dimension for gravel brakes from group N production cars to R5. They offer maximum braking power and heat dissipation within the space of a 15" rally wheel rim."
sleedawg is offline   Reply With Quote
Riddle me this Batman draggin_az Engine, Exhaust, Transmission 7 03-10-2017 07:07 PM
STL Area Nov 11 Cruise OmarGC Rocky Mountains / Great Plains 0 11-03-2012 10:27 AM
Asphalt FR-S 6MT in STL, MO jwtscion Dealer Cars 2 07-27-2012 11:50 AM
Sundays footage STL feldy Tracking / Autocross / HPDE / Drifting 2 06-25-2012 05:34 PM
