Old 05-01-2025, 08:53 AM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Verus splitter material?
I'm trying to find out what material Verus is using for their front splitter. Only thing I have found is it's a "carbon thermoplastic", which doesn't really tell me much. I've damaged my splitter a few times now and would like to just make my own replacement pieces. I respect that info may be closely guarded business knowledge so PM me anything helpful if you prefer. Thanks
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 05-01-2025, 09:17 AM   #2
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Carbon thermoplastic is what it is. Think of it as a black rubber/plastic.
You can make a splitter out of almost any material that holds the shape and handles the force. I've seen Lexan, aluminum and wood. In fact, if you already have their splitter (I do too) then just use it as a template to make another splitter with one of the mentioned materials.
RT-BRZ is online now   Reply With Quote
The Following User Says Thank You to RT-BRZ For This Useful Post:
bmacfrs (05-01-2025)
Old 05-02-2025, 11:51 AM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I’ve seen 1/2” birch veneered plywood used for DYI splitter projects (see YouTube).
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
RT-BRZ (05-02-2025)
Old 05-02-2025, 02:34 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've used Falken Design materials for my projects.
https://www.falkenacrylic.com/collec...gn-panel-sheet
Old 05-02-2025, 09:58 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That’s what I have gone to. $50 for a sheet and when it inevitably gets destroyed it’s a lot cheaper to replace. Seems to cut grass better too. I wanted to do alumilite but it’s hard to get and expensive. Still cheaper than buying a splitter.
Old 05-03-2025, 08:03 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
Russian birch. It has more layers than standard plywood and it stronger. It's used in furniture making.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
blsfrs (05-04-2025), bmacfrs (06-03-2025)
Old 06-03-2025, 06:09 PM   #7
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
And now long-range bombers.
Sent from my SM-S901U using Tapatalk
The Following 2 Users Say Thank You to bmacfrs For This Useful Post:
GrandSport (07-03-2025), new2subaru (07-04-2025)
Old 07-03-2025, 10:46 PM   #8
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Bitch is what we run in our WRL car. Cheap and easy to cut. Plus, the bolts will likely rip out of the wood before it damages the car if it gets into something and pulled down.
We cut 2 at a time and always have at least one, preferably two, spares on hand.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Brand new unopened Verus Splitter for 2017 BRZ spicyricecake Exterior Parts (Aero, Lighting, Etc.) 11 10-04-2019 09:08 PM
Best Material for a Front Splitter?? juniorrr Cosmetic Modification (Interior/Exterior/Lighting) 5 06-30-2019 11:56 PM
WTB: Verus/velox splitter/diffuser for 2017 brz and seibon CSL trunk spicyricecake Want-To-Buy Requests 0 10-16-2018 02:05 AM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
Front Splitter Endplates - Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2016 11:54 PM
