Old 08-21-2024, 10:27 PM   #1793
jflogerzi
jflogerzi's Avatar
Originally Posted by RedReplicant View Post
It doesn't really work when you need to have a few tunes for optimizing power to weight classes or similar. Also, without getting too far into it my experience there was pretty much the tipping point that had me say fuck it and pull my FA20/Harrop for the K.
If I need to drop 5whp or pick up 5whp it takes me two minutes in Haltech without talking to a tuner.
yes that make sense... I guess it depends on what and how your using car. cant argue with you on that point
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
RedReplicant (08-21-2024), series.trackday (08-22-2024)
Old 08-22-2024, 07:51 AM   #1794
Tokay444
Originally Posted by jflogerzi View Post
I don't see many drawbacks. The Oil issue is already can be fixed. Honestly for those who can do alot of the labor and fab work, K24 is a great option. But let's not deny that FA24 NA running on e85 and can get about 240WHP and a healthy 200 WTQ tuned. Yea its early, but my gen 1 motor running e85 and boost for a period is still ticking out on track near 100K on ODO. As Gen 2 motors get cheaper, I still stand by my statement that in my situation the FA24 is the better option.
How do you fix the oiling issues?
Old 08-22-2024, 09:14 AM   #1795
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
For the FA20 you have to add in an oil passage and restrict the flow on another to allow the journal bearings to be fed equally. A description of that issue is found on this very forum:
Look at the FA20 crank mains and the rod journals and you should spot something unique where I oil starved the rod bearing. The third main from right to left has a larger oil port. Why? Because it has to feed two rod journals where all others only feed one rod journal. What happens to oil pressure when you increase the oil port size? What happens to your oil volume requirements when you need to feed two journals with one main? Guess which one failed?
Additionally, there is problems with the design and manufacturing of the oil pickup tube which can be solved by swapping to the KillerB unit.
Finally, the oil pan capacity isn't really sufficient when pulling sustained lateral G. It's just a physical limitation of the horizontally-opposed design and gravity. A baffled oil pan can help some but you're safer with a higher-capacity baffled pan and/or an Accusump accumulator.
When someone mentions the "inherent issues with a boxer engine design" the obvious comparison - Porsche - comes to mind. Well, for their high-performance engines (most 911 models) they use a dry sump system from the factory. For the "lower-performance" early-gen watercooled engines in the Cayman and Boxter, their oil capacities were gigantic compared to the FA20 - almost 8 quarts of oil in the Cayman vs. 5.8(ish) for the Twins. And that's leaving aside design differences in oil supply and routing.
As far as I know - I haven't researched it as much as I wasn't even planning on build an FA24 - Subaru/Toyota didn't do anything to address the preexisting issues with the FA20's oiling, and in fact made it worse with the change to a multi-screen plastic oil pickup design. The addition of the now well-known issue of too much RTV being applied from the factory causing the oil pickup tube to become partially or completely clogged muddied the waters a bit, but overall it seems these issues will persist on stock engines.
series.trackday is offline   Reply With Quote
The Following 2 Users Say Thank You to series.trackday For This Useful Post:
BatStig (08-22-2024), RT-BRZ (08-22-2024)
Old 08-22-2024, 11:36 AM   #1796
Tokay444
No one is talking about swapping an FA20 with an FA20.
Old 01-27-2025, 06:03 PM   #1797
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
I've had some changes in the garage and want to start the K-Swap now so I am deciding on parts. Few questions for you experts:
Oil Pump- As of 2024, KPower has a pan and notched-subframe that allows you to keep stock RBB Oil pump and Balance shafts instead of doing a k20a2 pump.
It feels like keeping everything stock would be better for reliability and reduced NVH, but going K20 pump and balance shaft removal would be better for revs and power.
I've been searching various sites like k20a.org and seemingly the balance shafts aren't *needed*
Is the NVH from removing the balance shafts all that bad? is there a video that demonstrates this?
Can it be that much more NVH than the typical FA20 noises?
Would the fluidampr help with this?
I have a 1JZ in my Supra, and I had an RSX Type S back in the day (k20a2). I fell in love with square/oversquare higher-revving engines, so I'm leaning more towards using a Type S pump to support my long term goals.
Trans - Does the 2nd gen transmission case have basically all the same measurements and mounting points, including shifter?
Planning to keep 1st gen trans for now, but I wouldn't mind keeping an eye out if a good deal comes up on FB, ebay, or the forums.
Thanks.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 01-29-2025, 04:05 PM   #1798
RedReplicant
Drives: None
Thanks.
Yes, it's bad. This shows up in cabin noise - especially at high revs, vibration you can feel across the entire range, vibration that you don't feel that murders sensors / causes the wiring harness to chafe holes in itself / causes bolts to untighten / pressure plates to develop cracks and come apart, etc.
A Fluidamper or ATI damper marginally help, but does not eliminate the higher order vibrations that the balance shafts counteract.
Yes, the second gen trans and first gen trans are interchangeable.
The K20A2 pump has been shown on the Tuning by Nick channel to be worth like 15whp, but if it were a street car you very much want to keep the K24 pump. The stuff about it not being able to keep up with oiling isn't true, it is fine, even on track. You can do some reading about that over here https://www.k20a.org/threads/is-ther...-built.228355/
ima be real, we're in a different time for these cars now. Unless you specifically want the K for an actual race car you're better off putting a FA24 into these things. It makes more power, it costs less, it's more reliable, it's easier, and it has much better nvh manners.
And yes, I say this as someone that did the swap, tracked the car for two years after, and then went ahead and K swapped another car after that.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
villainous_frx (02-17-2025)
Old 01-29-2025, 04:42 PM   #1799
2.2Lude
2.2Lude's Avatar
As much as I love Honda's and K motors this is the truth. The oil pressure issues are close to being resolved so the FA24 just makes the most sense on pretty much every level when compared to a K swap.
When I first got my 1st gen back in late 2023 I began research on a K swap for when the FA20 went but now..there's just no real practical reason to not drop in a FA24 and carry on with the boxer life.
2.2Lude is offline   Reply With Quote
The Following User Says Thank You to 2.2Lude For This Useful Post:
RedReplicant (01-29-2025)
Old 04-15-2025, 04:50 AM   #1800
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Do you have a link to how the FA24 oil issues are being fixed?
If I do a k swap and pop a motor, it’s another $1k.
If instead I do the FA24 swap, for $5k and pop that engine it’s another $5k.
Four_wheel_drifts is offline   Reply With Quote
Old 04-15-2025, 09:35 AM   #1801
2.2Lude
2.2Lude's Avatar
The Verus and Formula Delta pans are still being tested but the early results are looking good.
No doubt replacing a popped K is going to be loads cheaper than a FA. Though, the initial upfront costs for the K swap is also something to keep in mind, along with SMOG if required.
My statement applies more to your average street/HPDE build. If you’re rebuilding the motor every racing season then yes, K all the way. It’s all use case dependent. My BRZ sits in the garage 90% of the time, the other 10% is occasional street use + driving to and from the track, 2.5-4 hours away. It still needs to be street legal here in CA, so a K24 swap running a Haltech standalone isn’t really an option for me at this time.
If cost and SMOG weren’t an issue. I’d have already dropped in a K, I hate the way the stock FA sounds lol.
The Following 2 Users Say Thank You to 2.2Lude For This Useful Post:
Four_wheel_drifts (04-15-2025), RedReplicant (04-15-2025)
Old 04-15-2025, 11:54 AM   #1802
RedReplicant
Drives: None
At $5k a pop you could go through three before you reach the price of a sorted K track reliable swap.
If you pop a K you're probably spending another $300 on an oil pump and then if you managed to damage the pan via rod yeet that's another $1k.
btw, I found this on my K Lotus a few days ago. Use a manifold brace, kids, this lasted about 1000 track miles.
The Following 5 Users Say Thank You to RedReplicant For This Useful Post:
2.2Lude (04-16-2025), captain awesome (04-15-2025), Four_wheel_drifts (04-15-2025), redlined600 (05-14-2025), Wally86 (04-22-2025)
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
