Old 03-31-2025, 08:48 AM   #15
Slowfoo
Slowfoo's Avatar
Drives: Black BRZ
Originally Posted by TRS View Post
Hi all,
I expierienced a clicking noise (single click) when the Torque in the axle changed between load/acceleration and coasting. It is NOT the typicall noise of a brocken CV and it occures only if torque direction is changed.
I have this exact symptom now after changing axles.. I replaced them a second time with different axles, and the sound disappeared but returned within a couple of weeks. Have you determined what caused this in your case? I know it's been a while, but I am hoping you have the solution for this problem I've been chasing for weeks.
Slowfoo is offline   Reply With Quote
Old 04-01-2025, 10:17 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Did you reuse axle nuts?
whataboutbob (04-02-2025)
Old 05-25-2025, 02:15 PM   #17
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
@Slowfoo Unfortunately I wasnt able to fix that symptom yet. I just can say that Im fully using the car despite that noise for quiet a while now without obvious negative effects. Though, Im also going to repalce the axles within the next few month since Im building a drift 86 and need axles for that build anyway. So Im going to put the used DSS into the drifter and will see how long they make it. The street LS swap will receive the new axles and hope for more luck then you had. ��
My best guess is that the spline conture of the DSS shafts is the issue. When I last inspected them I saw some the tooth had obvious wear. As far as I was able to diagnose, the tooth of the diff and axle hub seemed fine, so I expect them beeing the tougher part of the equation. To sum it up, without any actual proof, my best guess is that the DSS splines have spline shape or tolerances and that they are relatively weak in matters of hardness.
TRS is offline   Reply With Quote
Old 06-02-2025, 09:33 AM   #18
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I just installed Parts Shop Max solid Differential Risers
NVH is minimum and it raises the diff 20mm upwards to correct the angle of the axles. This should help prevent future clicking.
Lastly, the shop try to diagnose my clicking axle sound (while installing the diff risers in the same appointment) said my axles were perfectly fine! They said that the clicking is from somewhere else but they couldn't find it that day. I'll need to revisit. We speculate it could possibly from the rear parking brakes. I get 4-6 clicks upon acceleration and it disappears afterwards - sounds like something is loose and spinning in the brake drum? My car is old at 206'000km 2014 Scion FRS so it could be a number of other things.
kevaughan is offline   Reply With Quote
Old 06-02-2025, 10:50 AM   #19
Ohio Enthusiast
Drives: 2018 BRZ
Axle nut? Re-torque or replace. Cheap part to try.
Old 06-02-2025, 10:57 AM   #20
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I have a buddy that was having the "clicking" problem with his '13 BRZ. He changed axles and the problem went away for a short time and then came back. He changed his differential and the problem went away and didn't come back. Do with that what you will.
RT-BRZ is offline   Reply With Quote
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Evasive Street BRZ Breaks 1:59 Stock Motor and Street Tires Buttonwillow CW13 Video Evasive Motorsports Tracking / Autocross / HPDE / Drifting 31 07-02-2014 01:43 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
