| Member's Car Journals Car journals by our members. |
#57 | |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Sold the BRZ PP wheels, picked up another set of 17x9 +35 RPF1 with some 255 RS4s. Those will go on in the spring. After sitting on the Ohlins for a full year, they're going on this car in the spring with some SPC toe arms to get everything to spec. ![]() Car hit 205k km on the odometer the other day driving to work, so that is neat. Otherwise just the usual and no changes to report. |
| The Following 2 Users Say Thank You to villainous_frx For This Useful Post: | Prodigalson (12-12-2024), RToyo86 (12-12-2024) |
#58 |
Off to the track!
Went to swap a VVT solenoid o-ring and ended up creating a bluetooth sensor. Not the end of the world, but definitely annoying to have to go buy another. Fortunately the local dealership had them in stock for nearly the same price as RockAuto, so the issue was solved in under 30 minutes.
Also swapped rear endlinks with some new OE-equivalent ones, as they have been clunking since I got the car and I have finally had enough. Overall a pretty successful Wednesday night in the books. Alignment booked for Friday as the car has started wandering a bit on the road. Probably hit a pothole hidden in the snow that bumped something loose.
| The Following 4 Users Say Thank You to villainous_frx For This Useful Post: |
#59 |
Drives: 17 Asphalt 86
Those are the cursty covers on the front of the engine?
I want to freshen them so badly.. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | Ultramaroon (12-19-2024) |
#60 |
If they ain't broken, ne touche pas!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Teseo (12-22-2024) |
#61 |
Off to the track!
Yes, the VVT Solenoids. My track record is 4/4 on the orange car and 0/1 on this one... :/
#62 |
I have one BNIB. I bought it when I thought I had a leaky one. Now it's an emergency spare.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (12-22-2024) |
#63 |
Drives: Crapcan
I think I have 6 or 7 between the engine I’ve blown up and the free long block I have with a spun bearing.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (12-22-2024) |
#64 |
Where's that meme I made? "I should buy a long block."
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (12-22-2024), villainous_frx (12-23-2024) |
#65 | |
Off to the track!
| The Following User Says Thank You to villainous_frx For This Useful Post: | Ultramaroon (12-23-2024) |
#66 |
Off to the track!
Car is back from alignment, -2.5F -1.1R. Passenger rear toe arm bushing was binding, so they opted to zero the toe out and match both sides. I've had SPC adjustable ones w/ the SPL lockout sitting on my work bench since the summer, I suppose it is time to install them in the spring. Warm weather and 200tws can't come soon enough
| The Following User Says Thank You to villainous_frx For This Useful Post: | Prodigalson (12-29-2024) |
#67 |
Off to the track!
Continuing the trend of replacing endlinks. I swapped over the fronts to OEM-equivalents, recharged the AC after 9 months, and did an oil change.
I did recently pick up two rock chips, so as those grow I will replace the beyond pitted windshield. Told myself I would replace it once there were proper chips and here we are. 207500 km of highway driving has rendered the visibility nil at sun up/down, which is when I commute 99% of the time. Amazing how much more I like the car once the problems I have been ignoring start to get fixed... Also picked up some shift knobs. A Cusco, WC Lathewerks, and STI Duracon. |
| The Following 3 Users Say Thank You to villainous_frx For This Useful Post: |
#68 |
Off to the track!
"Are these cars any good in the snow?"
#69 |
Off to the track!
Not much has changed on the car. Summer wheels on and reliably taking me to work.
Recently I've been missing my old STI swapped WRX, and throwing around the idea of a muffler delete for fun. Then as fate would have it, a super cheap Tanabe Revel Medallion-S single exit exhaust came up on marketplace. $100 later and I now own this silly straight pipe. The reason for the cheap sale was the previous owner had over-sprayed some industrial paint on it and mucked it all up on his racecar. An afternoon with some metal polish and elbow grease and it looks good as new. With the install, I ended up needing longer exhaust hangers as it was resting close to the bumper 'diffuser' and started to melt after a quick 10 minute drive from cold! Uncle Jeff to the rescue with one day shipping and we were back in business. Driving around with the UEL header the car sounds gnarly on downshifts with crackles and pops, but feels slow as sin accelerating due to all the noise. I almost feel bad just revving to 3000 it's so slow compared to the noise LOL. Naturally I had to put it through its paces for an honest review, and took it to the mountains. Cruising spiritedly at ~100 kmh on backroads it sounds wonderful. Driving on the highway at ~120(ish, I wasn't speeding officer) the drone is unbearable with any uphill throttle load. Due to this noise, I ended up adding 25 minutes to the drive home just to take the backroads again. Overall for the low price of admission and the afternoon cleaning it up, it's been stupid fun. I've gotten the noisy 'hot boy' out of my system for another 5 years after a week of noise and will be selling it to revert to the sensible/trusty OEM muffler from before. I feel if the car was OEM header, this exhaust wouldn't be the end of the world. It has potential to be quiet while cruising and gets lively when you step on the loud pedal. Either way, would buy again. ![]()
| The Following User Says Thank You to villainous_frx For This Useful Post: | autoracer86 (08-02-2025) |
#70 |
Drives: Toyota GT86
Thanks for the laugh haha oem FTW
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following User Says Thank You to autoracer86 For This Useful Post: | villainous_frx (08-02-2025) |
| Mim's daily driver | Mim | Member's Car Journals | 13 | 09-05-2017 01:55 AM |
| Is your FR-S your daily driver? | Drive | Scion FR-S / Toyota 86 GT86 General Forum | 136 | 02-10-2014 10:10 AM |
| FRS as a Daily Driver? | Pake1 | Scion FR-S / Toyota 86 GT86 General Forum | 104 | 08-16-2012 12:48 AM |
| Will the BRZ be your daily driver | WRXGuy1 | BRZ First-Gen (2012+) — General Topics | 47 | 05-23-2012 01:15 PM |
| The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 02:14 PM |
