#4495 | |
Drives: 2023 BRZ, 2018 Golf R 6MT
Anyway, I ran the tap up through. It barely did anything on one side, so I feel good about that. On the other side, it did quite a bit of cutting, and the thread fit is sloppy, but the torque wrench clicked at 107, so ![]() -Mike |
| The Following User Says Thank You to grippgoat For This Useful Post: | Racecomp Engineering (03-18-2025) |
#4496 |
What size shim would you start with?
#4497 |
You're going to need the actual dims when you specify your custom spacers. It would've been easier to give the numbers like I asked.
#4498 |
#4499 |
Again, I know the original question was very difficult, but I’ve already got them modelled and programmed, so the answer is, “I will be.”
#4500 |
Nobody makes them because they aren't necessary. See how the axes are made collinear at one end? That's all you need. The rest is for ease of assembly.
#4501 |
Now I make them.
#4502 |
Drives: 2018 BRZ
#4503 |
#4504 |
Anyone have experience with Tein EnduraPro shocks/struts, for lowering springs specifically?
I'm considering pairing these with D2 lowering springs I already have. I want something that can handle a lowering spring long term without blowing like the OE damper. The adjustability is a nice bonus to me. Tein's marketing is a bit confusing. They say these are intended to be used with OE size springs, but can be used with Tein lowering springs as well. I understand there may be differences in bump/droop travel between this and a B8, but my priority is reliability. These are WAY cheaper than a Koni Yellow or Bilstein B8 - enough to give me pause. I understand you often get what you pay for in the aftermarket, but I do due diligence when there's a $700+ price delta. So, what gives? |
#4505 | |
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
#4506 | |
- Andrew |
#4507 | |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | Racecomp Engineering (05-20-2025) |
#4508 | |
Track Day Junkie
Drives: 2022 BRZ Limited
I could not help but wonder what RotARy15 is doing these mods to his car for and how will he drive it... I guess your answer is brief because you don't want to get into detailed advice based on usage. I wonder about the quality of advice if you don't ask questions so you can give better advice.
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
