Old 09-15-2019, 05:13 AM   #15
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by HSV Guy View Post
I just had the exact same thing happen to me in my 2017 BRZ. Last night I turned my car off with Torque [Lite] still running in the background and then this morning when I started my car the check engine light came on and I have the U0155 error code.
How did you guys clear the permanent DTC/has anyone tried the below? I'll give this a go myself when I next get the chance and advise how it goes.
It's not a permanent DTC.
Clear the usual check engine codes via Torque, and the dash light will go away.
EndlessAzure is offline   Reply With Quote
Old 01-04-2025, 12:48 PM   #16
Jack Black
Drives: 2015 FR-S
Does anyone know if the U0155 code can be triggered by bumping something under the dash?
NC requires yearly inspections. Twice now the same tech at one of the local inspection places has failed me for a CEL when I know the car did not have a CEL when I brought it in. The first time was a few years ago. I took it to the mechanic that time but I don't know what code it was. This time I used a reader to get the code and it was U0155. I suspect this guy doesn't know how to drive stick and is kicking something under the dash, causing this CEL.
Car is a 2015 FR-S
Jack Black is offline   Reply With Quote
Old 01-04-2025, 01:23 PM   #17
tomm.brz
Drives: brz 2017 hksv2
it s usually caused by some obd device, you should be good deleting it and then remove everything during startup
Old 01-18-2025, 10:24 AM   #18
Jack Black
Drives: 2015 FR-S
This is a weird one. I took it to a mechanic who checked the car, cleared the code and told me to drive it for 100+ miles and bring it back for re-inspection.
I took it back today, he hooked it to his code reader which said there were no codes, but as soon as he hooked it to the state inspection equipment it said there was a code again. Not only that but it turned on a bunch of dash lights. ABS and a couple others in addition to the CEL. Turning the car off and back on cleared all the lights except the CEL.
I've been in NC for 8 years now and this is the first time it's behaved like this. The last time the state inspection said there was a code, just having it cleared and driving for a while made it pass the next time.
Old 03-15-2025, 07:36 PM   #19
Jack Black
Drives: 2015 FR-S
Just to close the loop on this...
I took the car to my regular mechanic. He ended up taking apart the instrument panel, cleaning all the connectors and hooking it back up. No parts changed or repaired.
Now it works fine and passed inspection.
I really have to wonder if that first tech didn't mess up some connection.
Removing gauge cluster surround Gen Cosmetic Modification (Interior/Exterior/Lighting) 8 04-25-2013 10:28 AM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
Lost fans? 315FR-S Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2012 04:13 PM
2013 FR-S (Auto) Cluster Startup Sequence xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 05-21-2012 06:36 PM
