Old 12-21-2023, 03:53 AM   #1
NoGoodNames
Drives: Toyota GT86
Lightbulb Link G5 Plug-in
Quote from Link "Another exciting PRI announcement was the GT86 G5 Plug-in, specifically for ZN6/ZC6 Toyota 86/GT86, Subaru BRZ and Scion FR-S. A replacement for the factory ECU that plugs straight into the original wiring loom with no adapter harness needed. Includes Direct Injection, Gear Shift, Keypad and Traction Control, DBW, 512MB of Logging, Flex Fuel plus much more."
NoGoodNames is offline   Reply With Quote
The Following 3 Users Say Thank You to NoGoodNames For This Useful Post:
Nick Dugdale (01-01-2024), PulsarBeeerz (12-22-2023), RedReplicant (12-22-2023)
Old 12-22-2023, 07:16 PM   #2
RedReplicant
Drives: None
Really cool news here.
RedReplicant is offline   Reply With Quote
Old 12-23-2023, 06:46 AM   #3
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Yeah very exciting indeed. Could be good option for people going forced induction instead of the more traditional ecutek route.
I wonder if this does anything with the traction control systems. Being able to control traction control and abs would be pretty sweet.
autoracer86 is offline   Reply With Quote
Old 01-01-2024, 09:45 PM   #4
Nick Dugdale
Nick Dugdale's Avatar
Drives: 2015 Subaru BRZ
What would be the advantages of going with LINK vs lets say Haltech 2500 for a motor swap situation?
"The vision manifests the reality." NASA TT5 Silver 2015 Subaru BRZ Limited
Nick Dugdale is offline   Reply With Quote
Old 01-02-2024, 11:02 AM   #5
RedReplicant
Drives: None
Link has a much more open CAN system, but it mostly comes down to personal preference.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
DocWalt (01-03-2024), RT-BRZ (01-29-2025)
Old 02-17-2025, 10:52 AM   #6
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I just got my Link ECU installed along with the LAMBDA sensor. I'm in the process of rewiring my Flex Fuel sensor from the EVAP line to the ECU over to the rear O2 sensor port since that won't be used anymore. Wish me luck. This is being paired with a new JDL turbo installation and I'm excited to get it officially tuned and dyno'd.
It still makes me sad that ECUTek took the route they did. I guess I could sell my JDL 421 header along with the ECUTek and my old ECU if anyone is looking for an upgrade.
RT-BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RT-BRZ For This Useful Post:
autoracer86 (02-17-2025), Ultramaroon (02-17-2025)
Old 02-17-2025, 03:02 PM   #7
autoracer86
Drives: Toyota GT86
Nice to see people getting the Link plug in. Looks like a great setup.
Do you happen to know if the obd port still works ? I would love for the plug in ecu to be able to pass inspection but I’m sure it’s not possible lol
Old 02-17-2025, 04:41 PM   #8
RT-BRZ
RT-BRZ's Avatar
I am 99% sure that it works like OEM. In fact, I'm counting on it since I have a datalogger to plug in to mine.
This unit doesn't support using the OEM O2 sensors so I'm going to say that there is no state that does emissions testing where this car would pass.
Old 02-17-2025, 05:39 PM   #9
autoracer86
Drives: Toyota GT86
Well keep us posted ! As for the inspection I assumed they would at least need to see there is no codes/cel. But yeah over in Ireland they look to pull info from the port sorry don’t have the details at hand.
Anyway sorry for the thread jack lol
The Following User Says Thank You to autoracer86 For This Useful Post:
RT-BRZ (02-17-2025)
Old 02-17-2025, 06:10 PM   #10
RT-BRZ
RT-BRZ's Avatar
If all they do is check for CEL codes then I would imagine it would probably work. If they check for visual things like Cats and sensors then it definitely wouldn't pass.
Thread jack away. That's what this conversation is for anyway.
autoracer86 (02-18-2025), T-Steve (02-17-2025)
Old 03-11-2026, 12:48 AM   #11
Blackson
Drives: 15 Series Blue BRZ
Anyone figured out if this works with emissions stateside? Just a obd2 check of CELS in Illinois
Blackson is offline   Reply With Quote
Old 03-11-2026, 06:27 AM   #12
RT-BRZ
RT-BRZ's Avatar
I would say that it would not "work". The Link doesn't use the OEM O2 sensors (it uses it's own wideband LAMBDA sensor) so I can't imagine it would properly respond to whatever emissions tests they would perform.
I'm not in Illinois though so YMMV.
The Following User Says Thank You to RT-BRZ For This Useful Post:
DarkPira7e (03-11-2026)
Old 03-11-2026, 08:33 AM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You need to keep OEM ECU if you want to pass the OBD readiness. If it's just exhaust emissions testing it won't change anything
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
RT-BRZ (03-11-2026), smoltz (03-12-2026)
link ecu, pnp
Opinions on strut tower brace? 1 link vs 3 link? Stomachbuzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 11-20-2019 08:05 PM
Link/thread for TBS's Peschi Issues | Warranty | Recalls / TSB 2 03-09-2015 09:14 AM
OEM end link with coilovers bad? 86socal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-30-2014 10:16 PM
Rear toe link and toe changes Suberman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-30-2014 06:49 AM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
