Old 01-20-2025, 01:19 PM   #155
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Oh come on. I bet you have out run the sheriff.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
gt5759 (01-21-2025), Ultramaroon (01-20-2025)
Old 01-21-2025, 06:22 PM   #156
gt5759
Drives: 2017 BRZ
Yeah, those days are long gone for me!
gt5759 is offline   Reply With Quote
The Following 3 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (01-21-2025), Ultramaroon (01-22-2025), villainous_frx (01-24-2025)
Old 02-01-2025, 07:34 PM   #157
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
I made these out of 3/8" aluminum. Epoxied them in place. They blend into the contour of the door.
Scargod is offline   Reply With Quote
Old 02-03-2025, 02:43 PM   #158
gt5759
Drives: 2017 BRZ
Not sure what piece you're talking about? is it the mirror mounts?
Old 02-05-2025, 11:12 PM   #159
lonborghini
lonborghini's Avatar
Drives: '15 red FR-S SSC
But he did not shoot the deputy.
lonborghini is offline   Reply With Quote
The Following 2 Users Say Thank You to lonborghini For This Useful Post:
blsfrs (02-06-2025), Ultramaroon (02-07-2025)
Old 05-06-2025, 11:50 AM   #160
gt5759
Drives: 2017 BRZ
Finally made it and boy was it worth it!!
Small recap from the last post.
Finally made it back to the dyno to finish the tune, took about 2.5 hours to get it dialed in the way i wanted but it feels smooth as butter now and has yet to have a fault/code.
Had a private test day a couple weeks ago that went pretty dang well! Went through a set of tires and 40 gallons of fuel but sorted the majority of issues and now we get ready for our first race next week.
The bad - Stock replacement radiator is not enough cooling capacity, went with savage auto works dual pass 3" now.
We went a little to aggressive on the camber, car felt great but the temps and wear showed it needed less.
Center of the hood is too thin and lifting in the middle at speed.
The good - Brakes are A M A Z I N G!! This thing stops so hard and confidently, every time. ABS activation just feels like a gravely/buzz - have to really pay attention to feel it.
Balance is fantastic, it just goes where i want with no drama. Putting the power down will better with less camber as well but even then it was super controllable, even without the TC. She still makes 350ftlbs with the massive detune.
https://imgur.com/h2JkkbB dyno vid
https://imgur.com/49A4tQC on track vid
The Following 13 Users Say Thank You to gt5759 For This Useful Post:
ATL BRZ (05-28-2025), beltax90 (05-08-2025), blsfrs (05-11-2025), Code Monkey (05-06-2025), CSG Mike (05-07-2025), DocWalt (05-06-2025), JD001 (05-22-2025), NoHaveMSG (05-07-2025), RedReplicant (05-07-2025), RT-BRZ (05-06-2025), RToyo86 (06-26-2025), villainous_frx (05-12-2025), ZC6_STi (05-06-2025)
Old 05-06-2025, 08:49 PM   #161
JFC
Old 05-09-2025, 12:21 PM   #162
redlined600
redlined600's Avatar
Drives: Fr-s
Amazing job!
Did you make that strut bar? I'm also curious how you attached the grill to the bumper.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
gt5759 (05-12-2025)
Old 05-12-2025, 02:40 PM   #163
gt5759
Drives: 2017 BRZ
Originally Posted by redlined600 View Post
Amazing job!
Thanks!
Sure did, 1-1/4" .058 wall chromoly tubing. Grille is attached with 3m panel bond.
The Following User Says Thank You to gt5759 For This Useful Post:
redlined600 (05-12-2025)
Old 05-29-2025, 02:58 PM   #164
gt5759
Drives: 2017 BRZ
First event went pretty darn good! Won all of our races and set track record on the first day, albeit the record was soft in my mind. Still working on setup, shock settings and alignment but were getting there. Car does everything I want but is super easy to overdrive and kill the tires, need to work on being smooth.
But for being off from racing for 4 years im pretty happy and its fun having to relearn plus gain new knowledge!
The Following 9 Users Say Thank You to gt5759 For This Useful Post:
Autoxer62 (06-07-2025), Code Monkey (06-02-2025), CSG Mike (06-25-2025), DocWalt (05-29-2025), doward (05-29-2025), Pat (06-03-2025), RedReplicant (05-30-2025), RT-BRZ (05-29-2025), ZC6_STi (05-29-2025)
Old 06-25-2025, 05:59 PM   #165
gt5759
Drives: 2017 BRZ
Pic from Hedge hollow event win, since I just realized I didn't post one!
Now onto the next round, at our summer shootout in Hallet, OK - that went to shit in a hurry. Driveshaft exploded rolling out from grid, didn't even make it past the cones getting on track. Hit second gear and rolled into the throttle to clean the tires and BANG!! whupita whupita whupita.......Thought I lost a cv shaft at first but not so lucky.....
Car looked good though
Driveshaft shop got me fixed taken care of and decided against the carbon shaft this time as me and Lee discussed the potential reasons for failure, we believe heat cycling due to close proximity of the exhaust which causes the resin to become brittle. So a 3.5" aluminum is on the way!
Next up is OIR in july, we'll be ready.
Other little updates, another BRZ getting a cage....
DocWalt (06-25-2025), kask2_6.0 (06-25-2025), RedReplicant (06-25-2025)
Old 06-26-2025, 11:46 AM   #166
blsfrs
blsfrs's Avatar
Be sure to research critical speed for your Al driveshaft. You might be bettor off with chrome moly.
Old 06-26-2025, 12:56 PM   #167
smoltz
Drives: 01 911 Turbo, 03 G500
You doing this yourself? Cagekits? A cage is on my post-season to-do list, trying to figure out options.
smoltz is offline   Reply With Quote
Old 06-26-2025, 02:44 PM   #168
gt5759
Drives: 2017 BRZ
Sure did, went through all the options before locking down on this one but a lot of people don't realize how important that is for a racing application!
blsfrs (06-26-2025)
Jensen NASA ST4 race build thin2win Member's Car Journals 18 04-14-2021 01:15 AM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
Car 986 Scion FR-S NASA PTD Race Car Build phastafrican Member's Car Journals 70 01-03-2015 10:32 PM
