#15 | |
Drives: Crapcan
You can ask Element yourself on the feasibility of going big valve on an NA build. That was what 86IT was told when he asked them. They said the cost benefit is just not there for what you are gaining, not that there wasn't a gain. I personally don't see the benefit of porting the FA heads aside from just cleaning up the casting marks and radius a few edges. There may be some gains from raising the floor as we mentioned above and blending the throat into the bowl more smoothly, but that is way beyond my skill set. If someone else like the OP wants to play, have at it.
#16 | |
Drives: Q5 + BRZ + M796
https://www.ft86club.com/forums/show....php?p=3324462 With direct injection or valve angle, there might be design considerations to the combustion chamber that prohibits as much lift with compression ratio because I believe K motors have run 12.5:1 custom builds with more lift and duration, so different motors, but it is in the realm of possibility given an ideal design I guess. https://www.motortrend.com/how-to/14...camshafts/amp/ https://www.kseriesparts.com/DCI-DC-...SABEgLv2vD_BwE I agree that NA modifications are limited and the aftermarket support is not there to make things very cost effective for anyone who isn’t a DIYer. I haven’t seen higher compression builds, porting, larger valves or much valve work to raise the redline. Seems like there are always limitations like valve size making porting gains unrealized, piston clearance making big cams impossible, head wall thickness making much porting difficult or oil pressure issues making valvetrain upgrades for raising the redline very challenging. Besides all that, NA mods require a lot of optimization, so it is easier to just strap on FI, but then there may become a case for porting or larger cams on a lower compression build, yet I don’t see many people going that route on this platform because this motor and transmission can’t take big power, and without demand there is little aftermarket support.
#17 | |
Drives: Crapcan
#18 | |
Drives: JRSC BRZ SOLD
#19 |
Drives: Crapcan
That must have been where he drew the line. It would be nice if they posted more numbers on their NA builds.
#20 | |
Thoughts of a FA24D swap are looking better and better. lol In the mean time via 949 Racing. "We're pulling the motor out next week for a rebuild by Keegan Engineering in Socal. Nothing fancy but it'll get forged pistons, lighter rods, double valve springs and ports cleaned up. Should make a few more whp than before, we'll see." |
#21 | |
Drives: Crapcan
#22 |
Drives: 2020 Subaru BRZ
The porting is complete. No results to discuss yet. I took a hard look a t larger valves. I found several professioal porters that dont recommend larger valves. Just take the throat to 90 to 92 percent of the vslve size and back cut the intake valve for improved flow. Also opened the bowl to 97 percent of valve size. So thats where i went. The build should be ready for track by late March. Oh yeah im sdding beehive springs tested to 9k rpm. I had Crower springs before and they took the rpm to 8200. Peak power at 7700
#23 |
Track Day Junkie
Drives: 2022 BRZ Limited
Any update? Anyone with similar headwork?
Any update? Has anyone done similar headwork? From what I've heard camshafts are not available for the engine yet. Any word on a supplier (besides Piper)?
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube |
#24 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
https://www.moto-east.com/main/fa20-...vs-ported-wrx/
BRZ head flows way more than you can use in most applications. No need to port anything IMO. |
| Porting the heads | Rabrooks | Engine, Exhaust, Transmission | 4 | 08-25-2021 10:48 AM |
| WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor | driftking96 | Want-To-Buy Requests | 0 | 02-16-2016 03:57 AM |
| porting header | Mike Brz | Engine, Exhaust, Transmission | 0 | 01-25-2015 04:16 AM |
| BRZ head lights -> JDM 86 head light conversion | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 08-02-2013 10:47 AM |
| Scion FR-S vs Mazda MX-5 Club Head-to-Head (Review and Video) | M-17 | FR-S / BRZ vs.... | 96 | 03-05-2013 02:40 PM |
