Old 12-15-2024, 08:12 PM   #10879
Interesting that it doesn't talk about the blind spot in each eye. It's small but there's another reason to move your head around the pillars. If the pillar blocks the vision of one eye, it can't account for the other eye's blind spot.
Fucking A-pillar. I have to lean to my right for all left-handers. #tallguyproblems
Old 12-15-2024, 09:00 PM   #10880
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Remember when I posted about the loose or fouled pin on my MAF connector? After I noticed how my LTFT had drifted way off during a long idle, I had barely touched the connector when the engine stumbled hard and recovered.
I haven't done anything since re-seating the connector that one time, ... but I'm keeping a closer eye on the trims.
edit: for accuracy, I changed 'high' to 'off.' I don't remember which direction it flopped.
Those codes didn’t even pop until I started the car without connecting the MAF. I am sure it is not related to the running issues. I am questioning if I got the EVAP purge hoses on correctly on the bottom of the intake manifold, may have forgot the clamp or something dumb. Driving it feels completely fine under light load. It acts like it is triggering some load compensation and just dumping tons of fuel under certain conditions. Idling and light load driving AFR’s look mostly fine, a bit unstable but not alarming.
Honestly I am just happy I didn’t end up with any cam position correlation codes. I had to disassemble and clean all the cam gears, driver side intake I had to replace.
Old 12-15-2024, 09:11 PM   #10881
Gotcha. Makes sense. Careful! Boost amplifies the effects of an off-kilter engine.
Preaching to the choir but worth mentioning.
Old 12-15-2024, 09:18 PM   #10882
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah I been watching AFR and oil pressure like a hawk. Also driving with windows down(in the rain) with no stereo on listening for noises. I think mechanically it’s fine, just issue with fueling. I guess I should try to take less then a year to put a car back together next time
Old 12-15-2024, 09:30 PM   #10883
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I did also learn from reading in the WRX forums the driver intake cam gear seems to have more issues. It is a lot different from the other cam gears. It has this spool valve in addition to the plunger present on the other cam gears. The valve is held in place by a staked on cover. Mine was loose but even punching it back down it wouldn’t lock into its normal position. I did find when assembling the cam gears onto the cam to leave them in a position were the plunger is not locked so it can rotate freely, then rotating it till it locks after bolted back to the cam. Rotating it till the plunger is locked, then bolting it to the cam seemed to make them bind.
Old 12-16-2024, 07:53 AM   #10884
Anyone else having issues with the main forum page?
Every once in a while the main page with the forum directory won’t load. But if I search say, “ft86club technical topics” and click into the sub forum it works fine. Does this to me a lot.
Yea, I've seen the blank front page but never occurred to me to look for a subpage.
Old 12-16-2024, 12:47 PM   #10885
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Reminds me of the time I was riding with a buddy in his 2000 Cherokee. It was dark and a little rainy when we stopped at the local auto parts. He decided to cut diagonally across the outer parking spaces to park in front of the store. I saw the light pole coming. Twice, I told him to stop but he thought I was making some kind of a joke (which I am not above doing). Boom, he hit the concrete base of the pole. We were only going 3-4 mph so there was only minor damage to his car and we added another scar to the concrete base.
Dang A-pillar.
Old 12-16-2024, 08:39 PM   #10886
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
At least you can see over the side mirrors
Old 12-17-2024, 01:25 AM   #10887
Old 12-18-2024, 11:17 AM   #10888
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I had to look that up, I had never heard of it.
Yea, it's a thing with white people with Viking blood.
Old 12-18-2024, 11:21 AM   #10889
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by blsfrs View Post
This article was "eye opening".
Our eyes and brain process things in pictures. One thing that has always fascinated me is the wagon wheel effect.
Old 12-18-2024, 11:33 AM   #10890
Over the "hump" on my last week of work (retiring this Friday 12/20/24). My office is empty of all personal items except one framed collection of the Wright Brothers patent applications and a mini-fridge.
I've entered the surreal zone....
Old 12-18-2024, 11:50 AM   #10891
Yaaaaaa .........CONGRATULATIONS!
Old 12-18-2024, 11:52 AM   #10892
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Congrats! It's weird at first telling people your retired.
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
