go_a_way1, MisterSheep
Old 11-06-2024, 02:04 PM   #24669
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Am I getting old? I have Tein Flex A's on my FRS and always kept the dampener adjustment at the stiff end. Over the past few months, I noticed all of the little shakes and rattles were becoming more annoying. Maybe I was unconsciously comparing the the FRS to my wife's new Forester which is very smooth and quite.
Well duh: I reset the dampeners to 10 clicks from the softest setting and 90% of the shakes and rattles disappeared. I guess I am getting old because: A, I like the smoother quieter ride and B, it took me so long to figure out the solution.
The Following 6 Users Say Thank You to blsfrs For This Useful Post:
Dadhawk (11-07-2024), overd0sed (11-14-2024), RToyo86 (11-06-2024), Stephen W. (11-06-2024), Ultramaroon (11-06-2024)
Old 11-06-2024, 03:49 PM   #24670
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I get that. My wife's Impreza rides so much better than the 86. Just glides over rough roads.
It's even worse when I drive on the RS4s, sidewall has zero give. I can hardly wait to put the ecs02s back on
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (11-06-2024)
Old 11-07-2024, 01:51 PM   #24671
Just go faster.
NoHaveMSG (11-07-2024), RToyo86 (11-07-2024)
Old 11-07-2024, 10:05 PM   #24672
RToyo86
RToyo86's Avatar
RS4s mounted on new wheels.. turns out there was a Mixup with sizes on my stock wheels none of us caught. 225 and 215s mix.
Ordering 225s to match and will be selling 215s as a full set cheap to somebody who wants them.
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
norcalpb (11-11-2024), Overdrive (11-22-2024), Stephen W. (11-07-2024)
Old 11-21-2024, 03:15 PM   #24673
RToyo86
RToyo86's Avatar
New Conti Icecontacts on my stock wheels. 16" Speedlines now up for sale
Old 11-21-2024, 08:38 PM   #24674
orz
orz's Avatar
Drives: Halo
2016 Scion FRS: 8year Anniversary. First California Smog Check. PASS
Current Setup
OFT Stage 2 Tune
OEM 2017 Intake Manifold (red)
OEM Airbox + all factory components
FT86SpeedFactory UEL Catted Header
Gruppe-S Overpipe
OEM Front Pipe
OEM Mid Pipe
Nameless axle back muffled single exit trackpipe
Comments: The tech was chill. Even asked if I'm going to turbo someday. I had a good feeling about this guy. Did a quick visual. Nothing to be concern about and gave me the thumbs up. I was out of there in 15mins.
orz is offline   Reply With Quote
The Following 3 Users Say Thank You to orz For This Useful Post:
blsfrs (11-21-2024), Busybee (11-23-2024), humfrz (11-22-2024)
Old 11-22-2024, 12:47 PM   #24675
Did you have to "tip" him?
Old 11-22-2024, 01:59 PM   #24676
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
That's looking good, man.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
RToyo86 (11-23-2024)
Old 11-22-2024, 07:21 PM   #24677
orz
orz's Avatar
Drives: Halo
Nope said wasn't necessary but appreciated. So I did one better and knighted him my official smog tech guy for life.
The Following 2 Users Say Thank You to orz For This Useful Post:
bcj (11-23-2024), humfrz (11-22-2024)
Old 12-04-2024, 06:47 PM   #24678
Ryūkotsusei
Junior Junior Member
Drives: 2014, Aquamarine
I managed to find a new unpainted Modellista antenna last month and spent quite a while translating its instructions. It's currently at the shop this week to install that and to fix some minor issues.
Ryūkotsusei is offline   Reply With Quote
Old 12-04-2024, 09:56 PM   #24679
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Found this $30 Aliexpress shift knob that’s similar to the BRZ TS oem red one with the exception that the leather on this cheapo one has a grainy texture instead of a smooth nappa leather. Decided to paint the silver bits all black.
I tried wrapping it instead, but my vinyl wrapping skills are lacking. We’ll see how long this paint lasts.
EDIT:
I ordered the same shift knob but from a different Aliexpress seller "Vivid" and it's completely lower quality. Leather is worse, and the knob is lighter. The better shift knob is from "Five Phases".
kevaughan is offline   Reply With Quote
The Following 2 Users Say Thank You to kevaughan For This Useful Post:
orz (12-05-2024), RToyo86 (12-07-2024)
Old 12-07-2024, 05:58 AM   #24680
Hypnocracy
Hypnocratic Missionary
Hypnocracy's Avatar
At 168k heads gave up the ghost…Turbotime in Sanford NC sent me this.
Hypnocracy is offline   Reply With Quote
The Following 3 Users Say Thank You to Hypnocracy For This Useful Post:
bcj (12-07-2024), JD001 (12-09-2024), RToyo86 (12-07-2024)
Old 12-09-2024, 04:24 PM   #24681
WNDSRFR
Drives: FR-S,GTI
Got to use my jack today.
Heard this loud bang, bang, bang while passing a tire shop, pulled over and had a huge 6 in screw sticking out of my right rear tire. It would bash into the wheelwell, sounded like the fender was falling off. So I jacked up the car with the POS OEM jack and replaced it with the spare. Putting the lugnuts on I noticed they were a little rough just about ready to seize like FR-S lugstuds do.
Started driving home. 15 miles away. Didn't take long for all the dash lights to come on to remind me not to put the spare on the rear. Pulled over in the middle of nowhere to swap right rear spare with front right tire. My idea was to jack up the car in the middle to lift the front and rear right off the ground. Not easy with the POS OEM jack but I did it. First went to remove the front but the lugnuts were bigger and didn't fit the wrench. OK, on to plan B. Put the wheel with the flat under the right side of the car to keep it jacked up and moved the jack to the left side. Went to remove the lugnuts from the spare and THE FIRST One was seized. That's it, nowhere to go from here. Put my flashers on and drove home at 45 mph. Went to remove the spare and 2 of the lugnuts were siezed. Cut them off with a minigrinder cutoff wheel Now I'm thinking of replacing all the studs that haven't seize yet, because they will.
Had this car for over ten years now and the only real obvious defects are the TOB and the lugstuds. But hey, it could be much worse. I coulda bought a VW.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
Stephen W. (12-09-2024), Ultramaroon (12-09-2024)
Old 12-09-2024, 04:53 PM   #24682
Amen to that! Much to my chagrin, my son-in-law just bought a 2004 mini cooper s. Spent the whole day yesterday confirming my suspicions about BMW products firsthand. OMFG...
MJones_RB (12-11-2024)
