Old 11-02-2024, 08:40 PM   #15
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Those wing options are all neat and good, but need to check with your organization.
"...and can only run OEM aero - as in it had to be a factory option." Is going to mean vastly different things to different organizations, such as the SCCA Solo discussion above.
As an example, per SCCA Solo rules and Street Touring, you can run the full 'STi' lip kit because it's an option in the regular BRZ accessory booklet. If the parts were only listed in the STi booklet and not the regular BRZ booklet, then they wouldn't be legal.
The underbody panels are factory on the 2017-2020 BRZs with the performance pack. I'm not sure about the 'base' models. They are probably also factory on the TRD optioned 17-20 GT86s.
Breezio is offline   Reply With Quote
Old 11-03-2024, 09:57 AM   #16
Ohio Enthusiast
Drives: 2018 BRZ
My base non-PP ("Premium") 2018 BRZ has the underbody panels.
Old 11-04-2024, 07:23 AM   #17
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Do you have any part numbers? Or photos?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 11-04-2024, 07:01 PM   #18
Breezio
Breezio's Avatar
For what parts?
Old 11-05-2024, 12:59 AM   #19
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Subaru part numbers for the underbody panels are listed below.
Under Cover Center Right: 56411CA001
Under Cover Center Left: 56411CA011
Under Fuel Tank Protector Right: 42045CA030
Under Fuel Tank Protector Left: 42045CA020
Bolts Require for Installation:
Bolt: 901000344 x 5
M8 Nut: 902170046 x 5
Fender Liner Clips: 909140007 x 5
Cargo Liner Clips: 909140065 x 20
Not sure if you need the very front panel towards the front pipe which is the,
Under Cover COM FTM:56410CA001
ZC6_STi is offline   Reply With Quote
Old 11-07-2024, 12:56 PM   #20
Luns
Drives: 2017 GT86
I've been looking at this myself lately, and noticed something with this list. There are new revisions of all four panels, which are 2nd gen parts, but have superceded the original parts listed above and are listed for 1st gen too. The newer tank panels are CA021/031 instead of 020/030, and as far as I can tell are a direct substitute (don't know what changed) so it's not a big deal.
The front panels on the other hand have changed in design. There's now an additional part that clips on at the very front (norcalpb called it a 'puck').
from https://www.ft86club.com/forums/show...41&postcount=1
Both pieces are listed as superceding the original panel, but if you just look for the old part number, you get only the panel (as given in the above list) and not the puck. There were Interchangeability & Substitution Bulletins covering this.
Under Cover Center Front Left: 56411CA040
Under Cover Center Front Left: 56411CA050
Fender Liner Clips: 909140007 x 4 (the same part number is also used for the tank covers)
The other thing I notice in the above list is the counts for fasteners seem to be more than what seems necessary. I don't know whether they deliberately include extras, or if I'm miscounting, but as best as I can tell, the counts should be:
Bolt: 901000344 x (6 -3)
M8 Nut: 902170046 x (4 -1)
Fender Liner Clips: 909140007 x (4+4 -2)
Cargo Liner Clips: 909140065 x (16 - 3)
The -x at the ends are counts of what is already present on cars without these panels and you may be able to re-use. This is also omitting the bolts that also hold the front panel in place.
Anybody wanting to browse the parts catalogs themselves, the front panels are under the Body section and are easily found. The rear panels are listed under Engine and Cooling, in the Fuel Tank, Band and Cover section.
Luns is offline   Reply With Quote
Old 11-07-2024, 02:48 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That's true. I remember an old member named "Elliot" had a tS and adjusted the wing for more downforce. He sold it when he got a Porsche. He's done quite a lot of track days on his tS. Here's a reference for @GrandSport. The problem is obtaining the tS wing will be very difficult to find, so the JDM version is the best route.
The airfoil profile on the TS wing was not that great. You were not gaining much unless you added a ton of AoA and drag to go with it. It probably stalled out at pretty low speeds with an angle that severe too. Elliott’s car(s) were supercharged.
Old 11-08-2024, 08:23 AM   #22
GrandSport
GrandSport's Avatar
Bolt: 901000344 x 5
hero!
Old 12-20-2024, 09:02 AM   #23
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Almost looks like it's supposed to be a jacking point. I don't suppose you know if it's solid or hollow?
CrowsFeast is offline   Reply With Quote
Old 12-21-2024, 12:47 PM   #24
ZC6_STi
ZC6_STi's Avatar
It's hollow. It can't be a jacking point due to the curve design to help aeroflow for the underbody panels
AERO Kit for sale (Factory Toyota AERO Kit) GTS86 Exterior Parts (Aero, Lighting, Etc.) 28 02-11-2017 08:34 AM
GTS 86 aero kit in U.S velvet33n Scion FR-S / Toyota 86 GT86 General Forum 4 06-24-2014 02:30 PM
Aero Fin cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 20 04-16-2014 10:53 AM
My red GTS Aero is here Ryan1JZ AUSTRALIA 14 01-10-2013 06:47 PM
Aero or lip kit Ryan86 Exterior Parts (Aero, Lighting, Etc.) 6 11-29-2012 08:59 AM
