Old 09-23-2024, 09:40 PM   #1
Fishbone
Drives: 2024 GR86
New Koni GTS Coilovers
I searched and was surprised that there is no posts related to this. Looks like Koni has launched their new GTS Coilovers and has fitment for the GR/BRZ.
https://shop.koni-na.com/producttech...i0FsPUDHC5-8Q4
Has anyone tried these yet?
Fishbone is offline   Reply With Quote
Old 10-24-2024, 01:24 PM   #2
ruturaj001
Drives: BRZ 2023
I am thinking about ordering these.
ruturaj001 is offline   Reply With Quote
Old 10-24-2024, 08:29 PM   #3
ruturaj001
Drives: BRZ 2023
I placed an order with tire rack, would let you know how they turn out.
The Following 2 Users Say Thank You to ruturaj001 For This Useful Post:
Fishbone (10-25-2024)
Old 10-25-2024, 12:02 AM   #4
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Too bad their website doesn't seem to tell you anything actually important about them. I can't find any hard specifications.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
strat61caster (10-26-2024)
Old 10-25-2024, 01:04 AM   #5
ruturaj001
Drives: BRZ 2023
Spring rate seems to be 6k front 7k rear. I emailed them asking about camber adjustment, drop and travel.
Old 10-25-2024, 02:31 PM   #6
ruturaj001
Drives: BRZ 2023
Few more specs received
The overall stroke of the dampers is 127mm in the front, and 116mm in the rear. The kit allows for 20mm – 55mm of lowering from the factory ride height.
Old 10-25-2024, 07:57 PM   #7
Fishbone
Drives: 2024 GR86
This is correct. I emailed them a couple of months ago and they replied to me that they are 350lbs/in Frt and 400lbs/in Rr which converts to approx. 6K and 7K like you said. I emailed them about the finish, material and if they are Made in Germany but they never responded.
Holding off for more reviews but I don't think Koni will ever release a bad product. I've used Koni Yellows x H&Rs on 2 of my previous cars with no issues.
The Following User Says Thank You to Fishbone For This Useful Post:
ruturaj001 (10-26-2024)
Old 10-26-2024, 02:13 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It may not be a bad product but it’s hard to tell what they’re good for without knowing spring rates, twin tube vs monotube, re-valvability, and what the adjustment knob is supposed to do. They didn’t even bother putting up marketing damper dynos.
ineedyourdiddly
Old 10-26-2024, 05:43 PM   #9
ruturaj001
Drives: BRZ 2023
Things I could find through people. 350 front, 400 rear. Twin tube. Linear damping. Rebound damping adjustment.
From koni "The overall stroke of the dampers is 127mm in the front, and 116mm in the rear. The kit allows for 20mm – 55mm of lowering from the factory ride height."
Old 10-27-2024, 12:24 PM   #10
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Koni is a Dutch company, not German, and that's where their factory is - in Oud-Beijerland, the Netherlands.
Tatsu333 is offline   Reply With Quote
Old 10-28-2024, 01:31 PM   #11
Fishbone
Drives: 2024 GR86
Got a reply from KONI.
The GTS dampers are produced in our main production facility in Holland, on the same lines as our Sport, and Special ACTIVE dampers. The bodies are powder coated, and the threads have black e-coating (KPL) for ultimate corrosion protection.
Mason O’Hara
Product Specialist
KONI - an ITT company
The Following 3 Users Say Thank You to Fishbone For This Useful Post:
Ohio Enthusiast (10-28-2024), ruturaj001 (10-29-2024)
Old 10-29-2024, 03:47 AM   #12
ruturaj001
Drives: BRZ 2023
Installation instructions if anyone is interested
https://koni.com/getmedia/d6172157-4...05-21-27_1.pdf
Old 10-29-2024, 08:19 PM   #13
ruturaj001
Drives: BRZ 2023
Got them today
The Following User Says Thank You to ruturaj001 For This Useful Post:
DocWalt (10-30-2024)
Old 10-29-2024, 08:36 PM   #14
ruturaj001
Drives: BRZ 2023
A low quality video I could made
The Following 5 Users Say Thank You to ruturaj001 For This Useful Post:
2.2Lude (10-30-2024), DocWalt (10-30-2024), Fishbone (10-31-2024), strat61caster (11-01-2024)
TRD + Koni or Tien Coilovers Bowtie2bimmer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-05-2020 05:20 PM
Bilstein B8 + Swift R + HVT coilovers and Koni struts sibanez Brakes, Suspension, Chassis 6 09-12-2017 08:54 PM
Koni Yellow Shocks on Sale now at B2autodesigns. Suspension Techniques Coilovers. b2autodesigns Brakes, Suspension, Chassis 476 01-05-2017 10:30 AM
Koni Yellow Sport shocks on sale with FREE SHIPPING!! Plus Ground Control coilovers! Moddiction Brakes, Suspension, Chassis 52 08-26-2014 02:07 PM
RS*R Sports i Moto Miwa Spec Coilovers vs RCE Yellow Springs and Koni Shocks MaXimus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 12-18-2013 07:44 PM
