Old 01-21-2022, 12:05 PM   #29
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by G_Rossney View Post
So I have a 2013 BRZ. I figured out the wiring to get the Non-Navi radio from a 2016 or 2017 to work. I have a 2019/2020 Navi Radio. I got it hooked up, everything seems to be working EXCEPT, the radio audio is missing the low end. I had this issue when I upgraded to the 2016/2017 Non-Navi radio, but when i moved the pins it worked.
Does anyone know where the issue is for the missing low end/bass and what I need to move to fix it. I've been looking at wiring diagrams.
Replied to your other post.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-24-2022, 12:42 PM   #30
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
Originally Posted by Grady View Post
Yes it would work. You will just need to look at the 2014 wire diagram to verify pin assignments.
I don't believe the GPS antenna in the early models '13/'14 are compatible. Mine did not work. 1. Plugs are not the same, after swapping, it still did not work.
G_Rossney is offline   Reply With Quote
Old 11-07-2022, 04:24 PM   #31
Espi
Espi's Avatar
Drives: 17 BRZ
the thread ive been looking for!
If I dont want to retain the steering wheel pause button in the 17 can I just plug in a 18 Ts Radio with GPS antenna and call it a day?
Or is all this required to get the radio to work with GPS?
Thank you in advance.
Espi is offline   Reply With Quote
Old 11-07-2022, 06:17 PM   #32
Grady
Grady's Avatar
You can but from what I remember some the steering wheel controls were incorrect. Not just losing the pause button.
The Following User Says Thank You to Grady For This Useful Post:
Espi (11-07-2022)
Old 06-28-2024, 11:22 PM   #33
PHATsuby
Drives: 2001 Legacy GT
bumping this, did anyone end up making an adapter harness for this? I was thinking this was similar to the Toyota swap to the Harman unit. I am going from 2016 BRZ to 2018 limited head unit and didn't find this thread till now. :facepalm:
Any adapter harness would be great.
Ben
PHATsuby is offline   Reply With Quote
Old 10-01-2024, 05:36 PM   #34
JaredMV
Drives: 2015 Subaru BRZ Limited
Ben
I just got my 2020 BRZ nav unit to work in my 2015 BRZ. When I have the time, I'll upload all of my research and findings either to this thread or a new one so yall can build the same harness(es).
JaredMV is offline   Reply With Quote
2018 radio in 2017? COBlue Electronics | Audio | NAV | Infotainment 53 01-22-2022 12:38 PM
FS: 2017-2018 Toyota 86 Front lip GYNXxx Canada Classifieds 5 08-30-2019 06:25 PM
Help deciding on a 2017 or 2018 BRZ wild03 BRZ First-Gen (2012+) — General Topics 41 09-20-2018 09:29 PM
2018 BRZ Suspension in pre 2017 brz? HeresMyMind Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-06-2018 09:39 PM
2017 Subaru BRZ Navigation? Crave Electronics | Audio | NAV | Infotainment 14 08-17-2016 06:40 PM
