Old 09-21-2024, 03:59 AM   #1
neil_se
Drives: Track Only 86
Hilux/Toyota 8" Diff Gears
I'm looking to change my final drive to a 4.88 ratio but budget friendly options like Weir aren't readily available here, whereas Hiluxes are everywhere.
Nitro lists their Toyota V6 8" TV6-488-29-NG gears as compatible with the 86 when using the YOKTOYFITKIT-29 spline adaptor and crush sleeve eliminator SKCSTV6 (I'm not sure if this is really necessary or just nice to have). Nitro also isn't easy to get here but Yukon is and has same matching numbers.
Has anyone else been down this road?
Possible ring & pinions:
Yukon YG-TV6-488-29
Also Motive, Trail Gear & USA Standard equivalent Toyota V6 8" 4.88 R&Ps
Kits incl 29spl pinion flange:
Yukon TV6-488K
Drivetech 087-012391K (listed for 4cyl diffs too so may require narrower pinion bearing)
29 Spline flanges only:
Yukon T35040-29-KIT
Drivetech 087-012550 (no nut or seal)
Crush sleeve eliminator:
Yukon SKCSTV6 solid sleeve
neil_se is offline   Reply With Quote
Old 09-27-2024, 09:55 AM   #2
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
That should work, I ordered a similar 3.7 ratio rear end (P/N TV6-373-29-NG) with the 8.125 diameter from Yukon. JustDifferentials.com had the same parts at a little cheaper price. Don't bother ordering their rebuild kit as half of it was useless. Order the OEM replacement seals and timken bearings
B T is offline   Reply With Quote
Old 09-27-2024, 06:02 PM   #3
neil_se
Cheers. I did as much research as I could find on compatibility and have ordered the Drivetech gear and pinion flange set, plus Yukon solid sleeve. Cost was 1/4 of the Auto Factory set. I’ll also order all the individual seals and bearings soon except for the front pinion bearing which is the one I suspect will differ.
I’ll update this post when I get it install after the end of the season later this year.
The Following 2 Users Say Thank You to neil_se For This Useful Post:
Falken86 (11-15-2024), Teseo (09-27-2024)
Old 09-27-2024, 08:26 PM   #4
Teseo
Drives: frs
If everything go smoothly, could you provide links of the products?
Old 09-28-2024, 06:19 AM   #5
neil_se
Certainly
Old 09-29-2024, 11:55 AM   #6
B T
From what i recall the front pinion bearing is indeed different, believe it had more riding surface area by being deeper.
Old 09-29-2024, 11:46 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You telling me I already have 4.88 and 4.56 gears sitting in my shop this whole time.
WTB/WTT 6mt diff or gears OzzyGT86 Want-To-Buy Requests 2 08-11-2016 06:57 AM
Transmission won't engage any gears.. Diff/Axle is done. Rifle Issues | Warranty | Recalls / TSB 35 03-29-2016 01:36 PM
Cars that "GRIND YOUR GEARS" Let's Rant! vividracing Other Vehicles & General Automotive Discussions 18 03-06-2014 04:50 PM
Hilux/Tacoma/4 runner axle ratio into 86?? Xauterus Engine, Exhaust, Transmission 4 07-15-2012 06:03 AM
Designing the Toyota GT86 - 4 Part Feature by Toyota Design Chief, "Dezi" Nagaya Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 03-19-2012 01:37 AM
