#43 | |
Drives: 20’ GT86
I have the following setup: Front: rebound 10 clicks from full stiff, bump 7 clicks from full stiff Rear: rebound 9 clicks from full stiff, bump 8 clicks from full stiff I have aprox. 40mm lowered (and had to jack up the front quite a bit). The ride quality is great with this setup. Can you show a picture of your front coils? I found it very weird as my fronts were actually really easy to slam. Last edited by KiK; 03-27-2024 at 05:27 PM. |
#44 | |
https://photos.app.goo.gl/U9aT4CpyUpKjWQY27 At this perch height, I get -26mm drop (340mm wheel hub to fender), and I measured aprox. 32mm of bump travel to the "start" of bumpstop, and 43mm droop It's like the cs top mounts behave the same height as oem mounts. Quite confusing since already 3 persons in this thread agree obtaining a different result @marco_mc22 @Racecomp Engineering |
#45 |
Drives: 24 GR Yaris, 23 GR86
Kind of late but here's the pic I promised
#46 |
cool thanks. At the end, I took the coilover to a shop to make sure everything is in order, and it is apparently. I put the ride height at F 331mm/R 340mm and it should be ok. I measured front droop and calculated that bump travel might be around 25-28 mm at the spring
Probably the CS top mounts don't add more than 5mm of bump travel @KiK did you refine your bump/rebound adjustment? |
| KW Clubsport 3-way Valving | TRAKRAVN | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-20-2019 10:45 PM |
| Using KW Clubsport top mounts for KW V3 | thpark93 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 03-20-2019 11:39 AM |
| Tein SRC vs. KW clubsport | 86wtywly | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 04-02-2017 04:55 PM |
