Old 07-09-2024, 09:56 AM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Another FA24 swap
It's here. Ready for install. Hopefully we'll get some cooler weather so it won't be so miserable working in my garage.
The Following 17 Users Say Thank You to blsfrs For This Useful Post:
alphasaur (07-09-2024), autoracer86 (07-09-2024), brandonblt2 (07-12-2024), finch1750 (08-18-2024), gt86ser (07-11-2024), kmbkk (07-09-2024), Racecomp Engineering (07-11-2024), RT-BRZ (07-09-2024), RToyo86 (07-09-2024), Stonehorsw (08-20-2025), T-Steve (07-09-2024), Tatsu333 (07-09-2024), Teseo (07-10-2024), tobin (07-22-2024), whataboutbob (07-13-2024), ZC6_STi (07-09-2024)
Old 07-09-2024, 11:29 AM   #2
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Best of luck! I am looking forward to this one
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
blsfrs (07-11-2024)
Old 07-09-2024, 05:47 PM   #3
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
This is going to be a sick project! Can't wait for the updates!!
ZC6_STi is offline   Reply With Quote
The Following User Says Thank You to ZC6_STi For This Useful Post:
blsfrs (07-11-2024)
Old 07-09-2024, 08:46 PM   #4
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Definitely interested in this swap!
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
blsfrs (07-11-2024)
Old 07-09-2024, 09:59 PM   #5
alphasaur
friendly
Drives: 17' 86
Any plan for oiling upgrades?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
blsfrs (07-11-2024)
Old 07-10-2024, 10:57 AM   #6
Teseo
Drives: frs
Make a build thread, so we can use it as reference ��
Teseo is online now   Reply With Quote
The Following 2 Users Say Thank You to Teseo For This Useful Post:
blsfrs (07-11-2024), whataboutbob (07-13-2024)
Old 07-11-2024, 09:49 AM   #7
blsfrs
blsfrs's Avatar
Setrab 46 row cooler. I may remove the oil to water cooler.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
alphasaur (07-12-2024), Teseo (07-11-2024)
Old 07-14-2024, 07:12 PM   #8
blsfrs
blsfrs's Avatar
It's in the car. Rear motor mount bolt hole was clearance by RS Mtrs but still kind of close with my motor mounts. RSM modded crank sensor, mount, and wheel. Another member sold me the vacuum booster line from an auto car. I had to bend the mounts and tubing for clearance. I had to fab a top bracket for the DI driver.
Per RSM, I will need to modify my alternator bracket. Everything else looks to be bolt in/plug in.
The Following 7 Users Say Thank You to blsfrs For This Useful Post:
kmbkk (07-16-2024), NoHaveMSG (07-21-2024), RToyo86 (07-15-2024), Spankopotomous (08-17-2024), T-Steve (07-22-2024), Teseo (07-17-2024), Ultramaroon (07-25-2024)
Old 07-14-2024, 11:25 PM   #9
alphasaur
friendly
Drives: 17' 86
honestly seems not too bad for a swap/50hp upgrade if your engine is blown
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
blsfrs (07-15-2024), Wally86 (07-15-2024)
Old 07-16-2024, 02:23 PM   #10
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Plenty of clearance for my turbo kit
The Following 3 Users Say Thank You to kmbkk For This Useful Post:
blsfrs (07-16-2024), CkOne (08-08-2024), Teseo (07-17-2024)
Old 07-21-2024, 07:15 PM   #11
blsfrs
blsfrs's Avatar
It's running. A couple of minor hick ups Throwing a P0341 sensor A code. I've contacted RSM. Per RSM: I used my alternator mount (after mild modifications) but my accessory belt is loose. Prolly need to source 22+ one. Steam from coolant spilt on header.
The Following 8 Users Say Thank You to blsfrs For This Useful Post:
autoracer86 (07-22-2024), Falken86 (08-07-2024), murdoc (07-21-2024), NoHaveMSG (07-21-2024), redlined600 (07-26-2024), RToyo86 (07-22-2024), Teseo (07-22-2024), ZC6_STi (07-22-2024)
Old 07-22-2024, 09:52 AM   #12
blsfrs
blsfrs's Avatar
Looks like I've got to source an alternator mount. Not enough tension on the belt using my modified FA20 one. RSM zip tied a washer to one of the forward facing AC compressor bolt holes. The one closer to the center of the engine. Sure enough, there was a gap when I went to mount the compressor.
https://www.youtube.com/shorts/ME33zrThmE0
The Following 4 Users Say Thank You to blsfrs For This Useful Post:
makinen (07-23-2024), RToyo86 (07-25-2024), T-Steve (07-22-2024), Ultramaroon (07-25-2024)
Old 07-25-2024, 05:20 PM   #13
Should I ever frag my original engine, this will be my solution. It's a no-brainer.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
blsfrs (07-26-2024), kmbkk (07-25-2024), Teseo (07-25-2024), Wally86 (07-26-2024)
Old 07-26-2024, 11:06 AM   #14
redlined600
redlined600's Avatar
Drives: Fr-s
Maybe I missed it, which ECU are you using?
redlined600 is offline   Reply With Quote
FA24 swap to a GT86 ? Anything I need be aware of? twasd Engine Swaps 23 01-09-2024 11:28 PM
Viability of complete FA24 swap (motor and ECU)? Tatsu333 Engine Swaps 43 02-18-2023 07:18 PM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
