Old 05-27-2024, 05:53 PM   #15
jiffyjhn
Drives: White FR-S kosei k4r 17x8
Machines don't care about excuses. Live & learn.
Not making excuses. Not new knowledge to me to keep the oil topped to recommended level and I admit I've neglected this one time.
But when there is crazy deadlines at work I pick getting a fat bonus over a car worth less than $15k .
jiffyjhn is offline   Reply With Quote
Old 05-27-2024, 05:57 PM   #16
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
This might be the WRX owner in me (it's my current daily, and I've owned it 12+ years), but the general rule of thumb there was the check it at the gas station at each fill-up. That meant you were checking it every 200-300 miles and on a level surface.
You don't need to follow that exact procedure, but it's for people that don't have a garage or park on a level surface... or who just forget to check the oil. Doing it every fill up ensures it's never going to be catastrophically low. It's overkill, but that's the point.
Personally, I check my BRZ's probably every weekend or about every 100-200 miles in the garage. Also, put about 1/4" or so over the full mark so there's some leeway in there too. That way if it ever does burn any, you have a small reserve before it's even to the "full" mark.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
jiffyjhn (05-27-2024)
Old 05-27-2024, 05:57 PM   #17
cmiovino
cmiovino's Avatar
Double post.
Old 05-27-2024, 06:00 PM   #18
wbradley
Sarcastic SOB
wbradley's Avatar
That's an admirable sacrifice. Do you put gas in the car? If you know it consumes oil you should check the dipstick every couple of tanks. Worse case, buy a litre at the gas station and i
top it up. And not sacrifice a car that's worth only $15k. It sounds like a silly excuse.but then again I wouldn't work sweatshop hours unless the incentive was really big, big enough that after not too long I'll never need to do it ever again. OK I'll stop with the unsolicited advice.
PS, my brother in law owns a '60 Vette, '68.5 Jag E Type, a '55 Austin Healy 100M, and a new Bentley and Ferrari.
None of those awesome vintage cars would still exist to be restored if nobody cared when their car's values were low. Your eyes would bleed if I showed you the Barrett Jackson values on his restored/restomod vintage cars.
Old 05-27-2024, 06:06 PM   #19
alphasaur (05-28-2024), jiffyjhn (05-27-2024)
Old 05-27-2024, 06:12 PM   #20
jiffyjhn
Originally Posted by wbradley View Post
That's an admirable sacrifice. Do you put gas in the car? If you know it consumes oil you should check the dipstic every couple of tanks. Worse case, buy a litter at the gas station and top up. And not sacrifice a car that's worth only $15k.
Fair point. I do keep half a quart and a funnel in the trunk incase it's low , but recently I've neglected to check and refill, got too many things on my mind.
Normally I don't lose much between oil changes, I've checked the seals when changing the oil yesterday and it didn't seem to have leaks. I did see some some residual oil on the oil change nut, so that could be why it was losing more oil than normal. New washer changed so hopefully it's good now.
The Following User Says Thank You to jiffyjhn For This Useful Post:
wbradley (05-27-2024)
Old 05-27-2024, 07:28 PM   #21
jiffyjhn
I used to do this before I let my strict oil regimen slip recently, I need to start doing that again. Funny thing is sometimes people will come up to me and ask me if everything is ok at the gas station
cmiovino (05-27-2024)
Old 05-27-2024, 07:49 PM   #22
jiffyjhn
Originally Posted by removedonut View Post
lol no.
you will get a low oil pressure light when your engine no longer has oil in it and oil pressure falls to zero though.
After draining 4 quarts out of it I put in 5 quarts(not 5.4) back and it was up to the full line, so realistically it prolly had a bit more than 4 quarts and I wasn't able to drain all of it.
Any idea how low before the light comes on in these cars? Years ago my friend's G35's light came on and we were only able to get 2 quarts out of it. The engine didn't feel the same after that and he trade it into dealership.
With 4 out of 5 quarts my main concern was sump not getting oil when cornering as I corner pretty hard in this car. Does the light come on in this case?
Old 05-27-2024, 08:17 PM   #23
cmiovino
cmiovino's Avatar
Yep, I get that too. Anytime you open the hood, everyone thinks there's a big problem or something lol. No one checks their oil, coolant, or anything anymore. A lot of people don't even know where the hood latch is in their car, which is sad.
Old 05-27-2024, 11:06 PM   #24
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
I wasn’t joking when I said you have to have literally zero oil pressure for the light to come on. The oil pressure switch activates when you have less than 2.1psi of oil pressure which is like, catastrophic engine grenade scenario. I’ve seen people put windows in their blocks without that light ever coming on.
That being said, being a quart and change low isn’t going to kill your motor unless you were doing some high-G cornering like that.
removedonut is offline   Reply With Quote
The Following User Says Thank You to removedonut For This Useful Post:
fredzy (05-28-2024)
Old 05-28-2024, 08:53 AM   #25
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
Sadly it's not overkill for a Subaru engine. I think they are the only modern vehicle where you need to worry about checking the oil frequently like that.
My WRX went 7-8 years without ever using more than 1/3 quart in a 5000 mi OCI. I might have added oil 3 times in 70,000 miles, checking every 500 miles on average. And then one day after a longer gap of maybe 1500 miles I checked and the dipstick was barely touching oil. Couldn't find a leak and it didn't use any in the following 4000 miles. Shaky PCV valve maybe? Inexplicable.
I don't recommend anything with a Subaru engine to anyone.
fredzy is offline   Reply With Quote
Old 05-28-2024, 10:51 AM   #26
Tokay444
Originally Posted by LancePower View Post
Intriguing. What's the point of even having a warning light then?
It's called an idiot light for a reason. If you depend on it, you're an idiot.
This is literally the most common configuration for oil lights on the planet. Very very few vehicles employ an actual oil volume light.
Old 05-28-2024, 03:33 PM   #27
foshjowler
Drives: 2022 BRZ; 2014 BRZ
If I had to wager, it's probably fine. Any major damage would have already showed itself. Mostly just a reminder to yourself to keep an eye on it. I had a saying with my old Miata, if I wonder if I should check the oil, it's time to check the oil. But those engines were known for burning oil.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 05-28-2024, 06:45 PM   #28
LancePower
Drives: 2020 BRZ tS
Excellence in engineering.
LancePower is offline   Reply With Quote
The 6 Quart Oil Pan Spacer - Gen 2 KillerBMotorsport Engine, Exhaust, Transmission 33 11-07-2022 07:09 PM
Down 1/3 quart on new car TheRealBFKR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 09-12-2018 02:49 AM
Driving with 1 quart of oil? TM Other Vehicles & General Automotive Discussions 9 07-31-2014 10:16 AM
Change oil even if I drove under 3k miles in 5 months? slowbrz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-10-2014 07:00 PM
Just drove my brz MT limited 1400 miles in 2 days (mpg results) sieeegel BRZ First-Gen (2012+) — General Topics 30 06-07-2012 02:43 PM
