Old 05-27-2024, 05:12 AM   #1
jiffyjhn
Drives: White FR-S kosei k4r 17x8
Drove over 3k miles with only 4 quart of oil how bad is it
Normally I'm pretty good with topping up oil between oil changes, but got busy with work, didn't change oil for about 8 months with about 8k miles since last change.
Today when I changed the oil and dip stick didn't even get any oil. only got 4 quarts of oil out of it. Though the oil looked light brown and not black at all.
I estimate I probably drove about 3-4k miles with oil well below the dipstick low level. I drive the car pretty hard. How bad is it?
It's a 2013 frs with about 50k miles
jiffyjhn is offline   Reply With Quote
Old 05-27-2024, 08:48 AM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
That's a low mileage example! I thought mine was pretty low at 84K km but it sounds like yours is around the same.
We cant tell you if you damaged your motor by neglecting to maintain a minimal oil level, but Im pretty sure that if you caused any problem, your engine will tell you. Or more likely, accelerated wear and living on the edge will b to the detriment of the next owner who will have no clue until the engine starts making noises or other issues. The car is your property and you can do that if you want to, but I doubt you would tell this to the next owner, would you? THAT, I have issues with.
TL;DR. Good work! Extreme neglect with anything can only lead to bad things, but don't worry.
Old 05-27-2024, 09:21 AM   #3
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
With 4 quarts in it I doubt you hurt anything.....just don't keep doing it.
22R
22R is offline   Reply With Quote
Old 05-27-2024, 09:37 AM   #4
LancePower
Drives: 2020 BRZ tS
I assume these have a low-oil warning light.
At what level does that come on?
LancePower is offline   Reply With Quote
Old 05-27-2024, 10:25 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Only when pressure is far too low. If you're driving and it comes on, you're probably already past the point of no return
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Tokay444 (05-28-2024), wbradley (05-27-2024)
Old 05-27-2024, 11:53 AM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I would be more worried about why you're burning/losing so much oil in 8k miles.
Old 05-27-2024, 02:01 PM   #7
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
lol no.
you will get a low oil pressure light when your engine no longer has oil in it and oil pressure falls to zero though.
removedonut is offline   Reply With Quote
The Following User Says Thank You to removedonut For This Useful Post:
Old 05-27-2024, 05:07 PM   #8
LancePower
Drives: 2020 BRZ tS
Intriguing. What's the point of even having a warning light then?
Old 05-27-2024, 05:12 PM   #9
These things should come with instructions for their owners. They could be called Owner's Manuals.
DarkPira7e (05-27-2024), Tokay444 (05-28-2024), wbradley (05-27-2024)
Old 05-27-2024, 05:20 PM   #10
wbradley
Sarcastic SOB
wbradley's Avatar
Considering these cars take 5.4 L of oil, only draining 4 L means you're 25% low. Again, if you don't give a shit that's great, but would you have the ethics to not resell the car without disclosure of such things? Likely not. So, your carelessness might be to the detriment of the next owner.. People do dumb careless shit.
I'm especially dumbfounded when it's an enthusiast that visits this site, who usually would care more not less.
Old 05-27-2024, 05:28 PM   #11
jiffyjhn
nah I don't think I'll ever sell this. Especially if I can find a good AE86 to buy. Tryin to get all 3 generations .
Old 05-27-2024, 05:32 PM   #12
I'm especially dumbfounded when it's an enthusiast that visits this site.
Years ago, a friend pulled into my driveway with a horrible knock. Spun rod bearing. She admitted that she thought the oil light was for when it was time to add a quart.
She had been driving her Tercel like that for at least a year before it died.
She also made a little shrine for her crankshaft. Called it Ode To Oil.
bcj (05-27-2024), wbradley (05-27-2024)
Old 05-27-2024, 06:11 PM   #13
jiffyjhn
When work demands I pull 70 hour weeks. The enthusiast in me takes a back seat.
Old 05-27-2024, 06:30 PM   #14
Machines don't care about excuses. Live & learn.
The 6 Quart Oil Pan Spacer - Gen 2 KillerBMotorsport Engine, Exhaust, Transmission 33 11-07-2022 08:09 PM
Down 1/3 quart on new car TheRealBFKR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 09-12-2018 03:49 AM
Driving with 1 quart of oil? TM Other Vehicles & General Automotive Discussions 9 07-31-2014 11:16 AM
Change oil even if I drove under 3k miles in 5 months? slowbrz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-10-2014 08:00 PM
Just drove my brz MT limited 1400 miles in 2 days (mpg results) sieeegel BRZ First-Gen (2012+) — General Topics 30 06-07-2012 03:43 PM
