#337 | |
Drives: 2022 Toyota GR86 Premium 6MT
- On the 17-20, reusing the FA20 crank position sensor would create the same problem as the 13-16 swap where you’d need to do a custom reluctor and bracket. Which is a lot more work when we’ve already got a perfectly usable hall effect signal coming out of the FA24 that we can utilize with a simple connector change. - Didn’t bother checking if the FA20 evap purge setup could be transferred over to the FA24. I would also put it in the “not worth it” category. - We can’t reuse the 13-16 fuel pressure sensor because it’s different threads. On 17-20 we can reuse it though, it’s the simplest option. |
#338 |
Drives: 2013 frs base
I see. So, repinning is much easier that finding adaptors. I guess the timing chain covers too are different for FA20 vs FA24
#339 |
With the way i’m building the harnesses, nobody needs to repin anything (besides the fuel pressure sensor, for 13-16 cars). I am building modular jumper connectors that leave the FA20 harness totally intact and just adapt the existing connectors to the sensors on the FA24. One of the big advantages of doing it this way is, for example, if you decide later after the swap that you want to add a 1st gen evap-based flex fuel kit/boost controller/etc. Rather than needing to repin the FA20 connector back onto the harness, you just unplug my adapter and then you’ve got a gen1 evap connector again.
The Following 9 Users Say Thank You to removedonut For This Useful Post: | alphasaur (05-23-2024), blsfrs (05-22-2024), pope (05-27-2024), RT-BRZ (05-23-2024), Spankopotomous (05-23-2024), T-Steve (05-22-2024), Tatsu333 (05-22-2024), Teseo (05-22-2024), Ultramaroon (05-22-2024) |
#340 |
17-20 test car is up and running with my kit. I’ll have a video posted and the kits up for sale sometime next week after I’m back from vacation. Final price is going to be $300 for the 17-20 harness set.
#341 |
Drives: frs
Much appreciated. Waiting a "curated" kit for 13-16 model year
#343 |
Drives: 17 Asphalt 86
For the 17+ cars being plug and play, are we specifically taking about the red top manual cars, or both manual and auto?
#344 | |
Auto should actually be slightly easier since all FA24s have a vacuum pump setup like the automatic FA20s did, whereas on the MT cars you have to do some brake booster rerouting. My 2013 test car is an automatic - unless there’s some hidden surprise I didn’t account for that we discover once it’s fired up, should be exactly the same process. |
#345 | |
I would assume that there is a hose/line that runs from the pump to the booster on all FA24s. |
#346 |
Correct. Which means on 6MT 1st gens, you need to acquire the brake booster tubing from an auto.
#347 |
#349 |
Here's a diagram of a 22 legacy. I imagine the twins are similar.
#350 |
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
