Old 01-08-2024, 08:21 PM   #1751
moosefro
Drives: K24 2014 brz
I finally got the pedal dance to work in my car. I know a lot of people just get the trac box to activate it at a button push but just in case some people are struggling and don't want to spend the extra money, I figured I would post what worked for me.
My idle was set too high (1050) so no matter how much the car warmed up it wouldn't ever be in a state to accept the inputs. Dropping it to 850 made activating pedal dance easy and consistent to start. It only needs to be below 1000 but my brake pedal causes the rpm to jump so I went lower than necessary.
moosefro is offline   Reply With Quote
Old 01-12-2024, 04:13 AM   #1752
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Originally Posted by RedReplicant View Post
… I wrote a long post about it on another forum a couple of weeks ago and the number of issues surprised even me.
Would you please post a link to that post or pm me? I’d like to read it. Thanks.
Four_wheel_drifts is offline   Reply With Quote
Old 02-04-2024, 06:54 PM   #1753
RedReplicant
Drives: None
If anyone was ever thinking of running something stiffer than the rubber WRX mounts that come with the kit ... don't even bother trying. Took me two minutes of run time to figure it out.
edit:
Anchor 9024 is what is included in the KPower mount kit
Anchor 9023 is also listed for a WRX, it is what some refer to as "STI Mounts". They're larger than the 9024 and you have to run the drivers side flipped to clear the oil pan.
Probably just buy the 9024 if replacing the mounts.
RedReplicant is offline   Reply With Quote
Old 02-06-2024, 05:02 PM   #1754
RedReplicant
Drives: None
Going to be testing this option for the shift selector rod here soon
https://www.instagram.com/p/C2-y-FmRolc/
Old 03-12-2024, 10:43 AM   #1755
redlined600
redlined600's Avatar
Drives: Fr-s
Maybe a bit of semi-useless info, but I was digging around a found that both the TSX and S2000 use manifold braces. This may be a moot subject if Kpower offers/switches to the balancer shaft setup.
#9 might be a second brace as well but I couldn't confirm.
redlined600 is offline   Reply With Quote
Old 03-13-2024, 12:00 PM   #1756
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
This may have been buried in this thread somewhere but a homebrew brace can be made pretty easily with cheap materials.
Originally Posted by captain awesome View Post
As pointed out by RedReplicant earlier about the intake vibes that ASM was experiencing, I decided to make an intake brace. I hammered some 3/4 steel tubing flat on the ends, drilled some holes, and good to go. The two bolt holes that are typically used for a throttle cable bracket and a threaded boss on the block connect the two. It's probably not an ideal angle but has to be better than nothing.
captain awesome is offline   Reply With Quote
Old 03-13-2024, 01:42 PM   #1757
redlined600
Drives: Fr-s
Nice, I made a similar brace (maybe I posted in my build thread).
Old 05-12-2024, 04:22 PM   #1758
zuldajin
zuldajin's Avatar
Drives: K24 Swapped FRS
Jumping on the forums to see if members on here can offer any knowledge or wisdom.
My car is primarily a track car running a 4Piston K24 NA engine making around 280whp and 200wtq.
The issue that I've been having for a while now is when on track, and when things seemingly get hot, the clutch pedal doesn't come back up off the floor during gear shifts. And I'd have to use my foot to bring the pedal back up.
I would clutch in to grab a gear, and it would be hard to move the gear lever into a gear as if the clutch wasn't fully disengaging.
When I first encountered this problem last year, thinking it was air getting into the hydraulic system. I replaced the clutch master cylinder, slave cylinder with new OEM units, and stainless braided clutch line and I still am encountering the problem despite replacing all external clutch parts with new components.
Have bled the clutch slave countless of times with various brake fluids (Castrol SRF, Endless RF650, Brembo 64T)
I'm running the Verus clutch fork with Kpower steel flywheel and Exedy stage 1 clutch.
Strangely enough, this problem only occurs when things get hot on track with repeated redline shifts, and the car shifts fine on the street after everything has cooled off.
Also any tips on how to drop the transmission with the engine still in place? Seems harder to do with a K-swapped car than the stock FA20 setup. My next move is dropping the transmission to inspect all the clutch components.
zuldajin is offline   Reply With Quote
Old 05-12-2024, 06:39 PM   #1759
RedReplicant
Drives: None
I've heard of this happening before, you might find something if you search the FB group.
As far as dropping the transmission in car, it is pretty easy as long as you sufficiently clearanced the chassis so the transmission can drop down through the mounting horns on either side.
Remove the slave cylinder first and then put a block of wood under the oil pan and jack up the motor to tilt it backwards. HF transmission jack is your friend.
Old 05-13-2024, 02:32 PM   #1760
sfruski
Drives: Many
Overfill the clutch fluid reservoir. Fill to the absolute max you can The pickup at the back is going dry under braking, and you are sucking in air on the downshifts. I had this problem on my FRS race car when I still had the FA20. I spent six months chasing my tail to figure out what was happening.
sfruski is offline   Reply With Quote
Old 07-01-2024, 02:06 PM   #1761
Misfire
Misfire's Avatar
Drives: 2017 Series.Yellow, 2005 LGT wagon
Would anyone happen to have, or know how to obtain CAN data for Gen 1.5 (2017-2020) BRZs?
I have a 2017 with K-Power's full kit. Most everything works, except for a few items. My AC, oil temp gauge on the dash cluster, and clutch switch are either non-functional, or not working fully. The AC is non-functional, the Haltech doesn't receive the signal from the switch to engage. The oil temp gauge is non-functional, the Haltech receives temp info from the sensor, but doesn't relay it to the dash. The clutch switch appears partially functional, I'm able to start the car (push button), but while cruise control is on, the clutch does not cancel cruise, the Haltech does not see a state change in the clutch switch.
We know the kit was developed on a 2013 car, and Subaru obviously made some changes in 2017. I've reached out to Haltech, and they stated that the CAN they provide is not for Gens 1.5 and 2, and that they don't have the manpower to reverse engineer the CAN data for the later Gens. They did state that if I was able to get them a DBC file with it, that they could add it in.
I started dipping my toes into figuring out how to obtain the info, but it's slow going. I found a couple threads with some individuals that seemed very knowledgeable on the CAN system, namely @timurrrr , @M0nk3y, and @ojuniour. If they or anyone would be able to assist, it would be greatly appreciated.
Misfire is offline   Reply With Quote
Old 07-02-2024, 12:02 PM   #1762
M0nk3y
I started dipping my toes into figuring out how to obtain the info, but it's slow going. I found a couple threads with some individuals that seemed very knowledgeable on the CAN system, namely @timurrrr and @M0nk3y. If they or anyone would be able to assist, it would be greatly appreciated.
Sorry I've never went as far as sniffing CAN data myself.
Kyle H. - #89 STX
Old 07-04-2024, 03:08 PM   #1763
RedReplicant
Drives: None
Your best bet is talking to GeraldJust
Old 07-06-2024, 02:51 AM   #1764
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
I'll start off with making an arduino connection to the canbus port (behind the radio):
https://github.com/timurrrr/RaceChronoDiyBleDevice
Then get a VCI J2534 complaint cable (tactrix openport is a great choice) and the OEM diagnostic software ala techstream ( or SSM4) - You know where to find the application
There are quite a few windows application that can read/intercept message (or commands) off the canbus via the diy arduin-built device.
Bestr arduino with already built can trasceiver would be CANduino v4:
https://www.tindie.com/products/mass...-with-can-bus/
All you have to do is just connect the High and low canbus wire.. pretty straight forward. -(so you can basically skip most the steps from timurrr build).
let me know if you need any further help.
also the canbus data between the first and gen second gen should be practically thesame quite honestly..Unless maybe the can frame has different identifier..idk
ojuniour is offline   Reply With Quote
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
