Old 04-26-2024, 11:59 AM   #267
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Ordered Trailing arms and MCA traction mod @RToyo86 did the arms come with new bolts ? The front bolts in your picture look new
autoracer86 is offline   Reply With Quote
Old 04-26-2024, 02:43 PM   #268
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I ordered new hardware from Toyota. Old stuff was still in good shape surprisingly.
The Following User Says Thank You to RToyo86 For This Useful Post:
autoracer86 (04-26-2024)
Old 04-28-2024, 07:40 PM   #269
M0nk3y
Not everything is roses over here with the MCA.
I have wheel rub at bump with 17x10 due to correction.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
kevaughan (05-05-2024)
Old 04-28-2024, 09:35 PM   #270
ayoshioka1
Drives: 2019 BRZ / E36 325is
yikes, maybe just trim the tab on the STI arm?
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
Old 04-28-2024, 09:40 PM   #271
M0nk3y
Yup. Grinder wheel to the rescue
Kyle H. - #89 STX
The Following 4 Users Say Thank You to M0nk3y For This Useful Post:
autoracer86 (04-29-2024), DocWalt (04-29-2024), kevaughan (05-05-2024), norcalpb (04-29-2024)
Old 04-29-2024, 06:31 PM   #272
norcalpb
norcalpb's Avatar
Do the STi arms have larger “tabs” than the standard trailing arms? Curious as to why this is the first time this issue has shown up!
Old 04-29-2024, 06:53 PM   #273
autoracer86
Drives: Toyota GT86
I wouldn't be surprised if it had something to do with the 17x10 wheels he runs.
Old 04-29-2024, 08:05 PM   #274
RToyo86
RToyo86's Avatar
Could have sworn I took a photo of stock vs STi but I would bet they're identical in dimensions.
Old 04-30-2024, 08:17 AM   #275
M0nk3y
It's not a function of the 17x10 wheels. The issue is occurring underneath extreme bump - IE loaded on the track.
I have MCS Suspension, so rear bump travel is quite extensive compared to any other OTS shock.
Kyle H. - #89 STX
autoracer86 (04-30-2024)
Old 04-30-2024, 08:32 AM   #276
autoracer86
Drives: Toyota GT86
Ah okay well seems like the fix was easy enough. Thanks for the explanation
Old 04-30-2024, 04:27 PM   #277
RToyo86
RToyo86's Avatar
Could have sworn looking at rear end it is a touch lower but I did not measure to get definitive answer. I have photos from initial install of B6 on yellows with OEM wheels. Looks close from the photos.
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
DocWalt (04-30-2024), kevaughan (05-05-2024), NoHaveMSG (04-30-2024), norcalpb (05-08-2024)
Old 04-30-2024, 06:34 PM   #278
autoracer86
Drives: Toyota GT86
It seems to be that the ones reporting a change in ride height are running stock or lowering springs.
I don't think I seen anyone running much higher than stock rear spring rates report a change or maybe they never noticed lol
I will be taking measurements before and after hopefully there is no change
The Following User Says Thank You to autoracer86 For This Useful Post:
Old 04-30-2024, 06:42 PM   #279
Tatsu333
Drives: 2020 BRZ Sport Tech RS
FWIW, I had no ride height change when I initially installed the V1 MCA Traction Mod on my stock Performance Pack suspension.
Can't comment on any change with lowering springs, because I installed my H&R springs (on stock dampers) after the Traction Mod was already installed, and same with my RCE SS1 coilovers.
Tatsu333 is offline   Reply With Quote
The Following 6 Users Say Thank You to Tatsu333 For This Useful Post:
autoracer86 (04-30-2024), DocWalt (04-30-2024), kevaughan (05-05-2024), PulsarBeeerz (04-30-2024), Racecomp Engineering (04-30-2024), RToyo86 (05-07-2024)
Old 05-07-2024, 11:37 AM   #280
RToyo86
RToyo86's Avatar
I've had mine installed enough to leave some impressions on the street.
Rear end feels a bit more sophisticated, less bothered by bumps.
I tested on throttle grip mid corner on familiar bumps with my regular commute and noticed the car doesn't bounce around when I try to get the rear to break free.
This morning I got the Conti's to break free and the rear just squats and is less dramatic. Previously rear end would react more to the bump which could upset the rear suspension requiring quicker snap of counter steer.
autoracer86 (05-17-2024), norcalpb (05-08-2024), StraightOuttaCanadaEh (05-09-2024), Tatsu333 (05-10-2024)
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
