Old 04-27-2024, 05:13 PM   #1
Sam_
Drives: 2013 Scion Frs
P0172 and P1170 Codes
Hi, I recently had a check engine light pop up, and got the code read. The codes were P0172 (System too rich bank 1) and P1170 (Fuel performance/Port injector) But I decided to be responsible and take it into a shop. They told me that I needed to replace my AFR sensor, as well as my MAF sensor, also said that an oiled filter may cause the issue. But they quoted me $1400 for the repair so decided to do it myself for around $300 and replaced the air filter because it needed to be changed either way. It turns out that it was not the problem, and figured it may not have to do with the sensors being broken, but the sensors sensing something is wrong. Especially since I sometimes smell gas when I am driving. I was wondering if anyone had any suggestions or history with this issue before I try some more of my options.
Sam_ is offline   Reply With Quote
Old 04-29-2024, 09:16 AM   #2
tomm.brz
Drives: brz 2017 hksv2
the lambda could be the culprit, as well as bad exhaust leak or faulty injectors
Old 04-30-2024, 01:01 PM   #3
Sam_
I suspect it could be the injectors because of the smell of gas as well as a rough idle RPMS also tend to drop even stalling at some points
Old 05-01-2024, 08:32 AM   #4
tomm.brz
yeah
what you can do for now is check the 3 bolts of DI ecu inside bonnet near the big fuses box are fully tightened to.ground
Old 05-01-2024, 08:40 AM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Make sure that MAF sensor is removed and doused with cleaner. Also, you might need a fresh air filter if your oily one inadvertently fouled the MAF sensor and possibly restricted flow.
Regarding injectors, no experience there.
Old 03-22-2025, 10:16 AM   #6
mrntd
Drives: 2017 Series.yellow BRZ
I have had this issue for a while now. On another forum someone suggested the purge valve had failed. I pulled the line from the purge valve to the throttle body and blocked off both. The car ran much better but the milage was lower. A code eventually came up for the evap can.
I've read that the purge value should fail closed and they usually don't fail. This seems like it's failing open. I recently found it is supposed to be closed a start up then open when it's warmed up. I'm going to test that. It then should be closed again when wared up at idle. This is when the code happens.
Does anyone have additional ideas?
Thanks
mrntd is offline   Reply With Quote
P0171 and P1170 codes when at low RPMs or idle stockysnail Issues | Warranty | Recalls / TSB 35 12-22-2022 08:27 PM
Check engine codes P0171, P1170, C1201, C1231, and c1241 HELP Crystalwhitebrzsti Issues | Warranty | Recalls / TSB 10 05-30-2019 06:45 AM
Odd idle and P0171 and P1170 codes dave- Engine, Exhaust, Transmission 0 09-26-2018 11:05 PM
Throwing P0171 and P1170 codes B-R-Z Software Tuning 39 01-27-2018 09:56 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 02:50 PM
