Old 04-27-2024, 09:02 AM   #295
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by blsfrs View Post
I asked for a quote from RS Motors. He has a 2022 engine with 8k miles. He will ship it to me ready to drop in my 2013 FRS in central Va for $9900.
I'm thinking about it.
Any kind of warranty on it?
Old 04-27-2024, 11:30 AM   #296
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
That's a good question. A couple of other things come to mind too. Like: Does the engine come with a flywheel and will my pressure plate work with the 22+. Can RS send me a tune? I'd like to have them check the oil pickup for silicone too.
I know it sounds expensive but $6k for the engine, $500 shipping, $700 for the kit. The rest is labor, tax, etc.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (04-27-2024), Ultramaroon (04-27-2024)
Old 04-27-2024, 03:20 PM   #297
Yeah. What exactly does 'drop in' mean? Ten grand is decent for a true replacement assembly.
blsfrs (04-28-2024)
Old 04-27-2024, 06:24 PM   #298
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Price wise it’’s not bad. Your current tune should run it, just won’t be optimal. I’d imagine if they are going as far as to pull the timing cover to change the cam reluctor plates that they would check the oil pickup, but it doesn’t hurt to ask and be sure. I’d be hoping it least a few month or few thousand mile warranty.
blsfrs (04-28-2024)
Old 04-28-2024, 11:05 AM   #299
blsfrs
blsfrs's Avatar
He is going to pull the pan and he said that there is usually more silicone in the timing cover than the pan. Ron says my 2013 flywheel (hence clutch) will work. Drop in means drop in Cam plates and modified wiring harness.
He said no warranty because he knows how this cars are driven. I will clarify that should I have a rod knock on start up that I would have some recourse.
The Following 4 Users Say Thank You to blsfrs For This Useful Post:
kmbkk (04-28-2024), NoHaveMSG (04-28-2024), Teseo (04-29-2024), Ultramaroon (04-28-2024)
Old 04-30-2024, 11:04 AM   #300
blsfrs
blsfrs's Avatar
For better or worse, I'm going to go for it. I'll send updates.
The Following 14 Users Say Thank You to blsfrs For This Useful Post:
alex87f (05-04-2024), alphasaur (05-03-2024), autoracer86 (05-01-2024), bcj (04-30-2024), JBezugs (05-01-2024), kmbkk (04-30-2024), NoHaveMSG (04-30-2024), Ohio Enthusiast (04-30-2024), redlined600 (05-09-2024), RedReplicant (05-06-2024), RToyo86 (04-30-2024), Tatsu333 (04-30-2024), Teseo (04-30-2024), Ultramaroon (04-30-2024)
Old 05-03-2024, 02:51 PM   #301
FrickingReallySlow
Drives: 2015 FR-S
Also could be the start of your YouTube career. Start with the annoying "What's up guys, its your boy blsfrs here with another FA24 engine swap video! Make sure to hit like subscribe and hit the bell icon...blah blah blah"
FrickingReallySlow is offline   Reply With Quote
Old 05-03-2024, 03:31 PM   #302
blsfrs
blsfrs's Avatar
If this works as anticipated, the credit goes to RS Motors. I'm just spending the money and doing the grunt work of putting the engine in my car.
The Following 5 Users Say Thank You to blsfrs For This Useful Post:
kmbkk (05-05-2024), NoHaveMSG (05-03-2024), T-Steve (05-06-2024), Teseo (05-03-2024), Ultramaroon (05-03-2024)
Old 05-09-2024, 01:43 PM   #303
RedReplicant
Drives: None
Looks like there is a kit option coming soon
https://hachielectronics.com/product...e-swap-harness
RedReplicant is offline   Reply With Quote
The Following 12 Users Say Thank You to RedReplicant For This Useful Post:
alphasaur (05-13-2024), autoracer86 (05-09-2024), blsfrs (05-10-2024), new2subaru (05-10-2024), NoHaveMSG (05-09-2024), removedonut (05-09-2024), Sevs753 (05-10-2024), T-Steve (05-09-2024), Tatsu333 (05-10-2024), Teseo (05-09-2024), Ultramaroon (05-09-2024), villainous_frx (05-09-2024)
Old 05-10-2024, 11:21 AM   #304
blsfrs
blsfrs's Avatar
Pardon my ignorance, but wouldn't they need to make make 2 kits? One for 2013-2016 and another for 2016-2020? I've heard the trigger plates are not the same.
Edit: Duh. I just read the entire page.
RedReplicant (05-10-2024), Ultramaroon (05-10-2024)
Old 05-10-2024, 01:25 PM   #305
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
Correct. 2017-2020 is a much cheaper option since we are able to use the FA24 as-is with just 4 adapter harnesses and a fuel pressure sensor swap, since the 17-20 ECU is already set up to accept a hall effect crank signal and shares the same cam reluctor pattern as the FA24.
(also hi. i am the one building those swap kits lol. happy to answer any questions about the swap)
removedonut is offline   Reply With Quote
The Following 11 Users Say Thank You to removedonut For This Useful Post:
alphasaur (05-13-2024), autoracer86 (05-10-2024), bcj (05-10-2024), blsfrs (05-10-2024), pope (05-14-2024), RT-BRZ (05-10-2024), RToyo86 (05-14-2024), Spankopotomous (05-12-2024), Tatsu333 (05-13-2024), Teseo (05-10-2024), Ultramaroon (05-10-2024)
Old 05-10-2024, 09:03 PM   #306
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
For the 13-16 kit, we will be able to use the stock ECU, correct? I assume so but i just want to be sure
Sevs753 is offline   Reply With Quote
Old 05-11-2024, 01:42 AM   #307
removedonut
Correct. The kit includes a set of camshaft reluctor wheels and a custom crank position sensor setup that will allow the FA24 to be run off the 13-16 ECU.
The Following 7 Users Say Thank You to removedonut For This Useful Post:
blsfrs (05-12-2024), jflogerzi (05-17-2024), Sevs753 (05-11-2024), Spankopotomous (05-12-2024), T-Steve (05-13-2024), Teseo (05-12-2024), Ultramaroon (05-12-2024)
Old 05-11-2024, 01:48 AM   #308
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Excellent! I'll be first in line to buy the 13-16 kit as soon as its available. Can't wait!
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 11:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 01:33 AM
