Old 02-10-2024, 08:35 PM   #267
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Opie View Post
I'm looking for 2022+ Cylinder heads, I've also got a 2013 long block. I've seen RS Motor's solution which is great, but I'm not so thrilled about the modification needed on the FA20 cylinder heads to make the FA24 work, that's why I want to try the FA24 short block & heads with the FA20 upper oil pan, timing cover cam carriers and camshafts....
They have a kit coming to use an fa24 long block. It’s 700. I was never really interested in trying to use the fa20 heads.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (02-12-2024), Tatsu333 (02-12-2024)
Old 02-17-2024, 04:03 PM   #268
FrickingReallySlow
Drives: 2015 FR-S
How much of the valve assembly set are you gonna use from FA24 vs FA20? I'm assuming the whole thing up to the springs needs to be FA24 right which is still pretty pricy to buy OEM
FrickingReallySlow is offline   Reply With Quote
Old 02-17-2024, 04:59 PM   #269
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can get complete used FA24’s for about 6500. He just needs the cam trigger wheels from the FA20. 13-16 uses a different style of cam trigger and crank trigger then the 17-20 which is the same as the 2nd gen.
Old 02-17-2024, 06:15 PM   #270
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
That is currently to be seen. Ideally I'd love to be able to use the FA20 valves and springs, but haven't researched at all the specs of each. I want the FA24 heads with the FA24 short block to maintain the proper piston the head clearance and compression ratio. FA20 cam & phazers to keep the computer happy.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 02-17-2024, 09:22 PM   #271
bcj (02-18-2024), NoHaveMSG (02-18-2024), Racecomp Engineering (02-18-2024)
Old 02-18-2024, 10:51 AM   #272
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Just a note on mixing and matching.
I think there a change in some of the rocker arm/valve and maybe cam assemblies in early gen 1's. It may have been done to help eliminate rocker arm ejections. On my rebuild, my motor guy ordered a new set of rocker arms but they didn't match the original ones. He ended up sourcing a couple early rocker arms to replace my damaged ones. If you get 2014-2015 heads, you're prolly be ok.
The Following User Says Thank You to blsfrs For This Useful Post:
Opie (02-18-2024)
Old 04-18-2024, 09:51 AM   #273
blsfrs
blsfrs's Avatar
Now that I'm looking at engine/car options.
Is using an FA24 in 2013 FRS as simple as switching the cam phasers, intake, and other external items? What am I missing?
Old 04-18-2024, 10:55 AM   #274
tomm.brz
Drives: brz 2017 hksv2
interested in it too
blsfrs (04-18-2024)
Old 04-20-2024, 11:32 AM   #275
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don’t think it is going to be quite that simple, but until I get my hands on one I don’t know for sure. There is a lot of misinformation I have come across on the swap.
blsfrs (04-21-2024), Ultramaroon (04-22-2024)
Old 04-22-2024, 12:03 AM   #276
blsfrs
blsfrs's Avatar
Yeah, I've got to do a bit more research. It sound like folks are using modified fa20 heads on the fa24 block. There may be an issue with the early (2013-15) crank sensor being compatible with the fa24 block.
I've got the car home now. Next weekend, I'll try to figure exactly what's broke.
Old 04-22-2024, 12:12 AM   #277
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think the fuel pressure sensor or regulator might be different too. There was a bunch of stuff in discord but it is so hard to read and follow sometimes. I know the guys making the swap kit for the whole block were charging 700 for their kit. They were also talking some machining to the timing cover too but I don’t know how intensive it was.
blsfrs (04-22-2024)
Old 04-22-2024, 12:34 PM   #278
blsfrs
blsfrs's Avatar
I'll look into the swap kit. Do you have a link? If it uses FA20 heads and intake, i would think it would use the regulator from the FA20.
Old 04-22-2024, 03:26 PM   #279
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
So does this mean swapping an FA24 purchased from a Wrecked 2nd gen into a '17-'00 1st gen is potentially as easy as dropping it in, hooking up the wiring and tuning the ECU?
I have to imagine its still quite a bit more difficult (sensors differences, wiring harness/plug differences, etc), but have to admit to being curious..
~Scott T.
'95 NAS D-90 ST
'13 BMW X5 35d
'22 CX-5 Turbo
'?? 86 one day soon?
LRNAD90 is offline   Reply With Quote
The Following User Says Thank You to LRNAD90 For This Useful Post:
blsfrs (04-22-2024)
Old 04-22-2024, 05:00 PM   #280
RedReplicant
Drives: None
There are FA24 first gens running around with a variety of sensor/harness configurations at this point, given that people stand to make money doing this the details are being kept fairly quiet. It'll be public eventually.
RedReplicant is offline   Reply With Quote
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
blsfrs (04-22-2024), NoHaveMSG (04-22-2024), Teseo (04-23-2024)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 11:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 01:33 AM
