Old 04-14-2024, 08:55 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Locked up engine
Anybody ever have an engine lock up but not blow up? On the front stretch at Summit Point, with no warning, I had a big noise and then no power. No smoke. No oil or coolant leaks. I coasted off the track. In the paddock, the engine could not be turned even with a big a$$ breaker bar.
I'm guessing part of the noise was 4th gear shearing off teeth.
I'm going back up on Friday to pick her up and start the post-mortem.
Old 04-14-2024, 09:22 PM   #2
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Uggg. Sucks. is it stuck in gear?
Sent from my SM-S901U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 04-14-2024, 11:59 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Damn, can’t really think of much that would cause that kind of failure and not show its insides on the outsides. Maybe something timing chain related? Hopefully it’s a transmission.
Old 04-15-2024, 07:05 AM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Bummer!
Old 04-15-2024, 07:40 AM   #5
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
oh no. Sorry Hope it's nothing too major
autoracer86 is offline   Reply With Quote
Old 04-15-2024, 08:45 AM   #6
blsfrs
blsfrs's Avatar
Thanks guys. If it's a weird problem, it will happen to me.
The engine has Manley rods so possibly something could seize and not expel the guts.
My wife is urging me to sell the car "as is" and get a Gen 2.
Old 04-15-2024, 09:10 AM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Well, "happy wife", right?
Old 04-15-2024, 01:54 PM   #8
Noooo....
I was looking forward to following your story.
Old 05-12-2024, 09:31 PM   #9
blsfrs
blsfrs's Avatar
Number 2 piston came apart.
Old 05-12-2024, 10:27 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Bummer. Wasn’t this a built engine? Wonder what caused the rapid unassemble? It’s in enough pieces it’d be too hard to tell which was chicken/egg. Are the big ends of the rods tight?
Old 05-13-2024, 12:40 AM   #11
Yuk. No gluing that back together.
Old 05-13-2024, 08:48 AM   #12
blsfrs
blsfrs's Avatar
Yes, it "was" a built engine. Manley rods, JE pistons, Element Tuning big valve heads.
Among the chunks of shredded metal, we found bits of piston rings and a couple of "c" clips that I assume were wrist pin retainers. The big end of the rods and crank shaft look undamaged.
I was hoping to salvage some of the parts for resale but I think the long block is headed to the scrap yard.
On the bright side, the transmission and clutch are ok and I should have my FA24 in a couple of weeks.
Old 05-13-2024, 09:30 AM   #13
autoracer86
Drives: Toyota GT86
I am looking forward to your FA24 build
Old 05-18-2024, 01:34 PM   #14
blsfrs
blsfrs's Avatar
Is it worthwhile to salvage any of the engine parts for resale at a bargain price? A little extra lunch money would be nice.
It is/was a comp engine.
The heads were built by Element Tuning with Ferrea big valve components. The spring kit sells for over $900 and valves range from $60-$70 each. I realize the valves in #2 are probably/maybe/most likely toast but the springs and the rest of the valves (and bank 1 head) should be fine.
I don't know if anything in the bottom end is worth anything.
When pulling the heads off, should I try and keep the rockers and shims matched?
Steering locked IsaiahW Engine, Exhaust, Transmission 1 06-28-2023 03:25 PM
Threads locked Wonderbar Site Announcements / Questions / Issues 4 02-11-2016 10:42 AM
Locked inside car agrajag Issues | Warranty | Recalls / TSB 12 08-10-2015 12:36 PM
car locked me out grodenglaive Issues | Warranty | Recalls / TSB 29 02-22-2013 08:24 PM
Post locked? Trikle BRZ First-Gen (2012+) — General Topics 8 08-15-2012 09:26 PM
