Old 04-13-2024, 02:16 PM   #1
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
NO SPARE for 2024??
Hey all,
I noticed after I purchased my '24 86 there was no spare in the trunk. Is that by design or is there some aftermarket kit I am not aware of?
Thanks in advance.
2024 Toyota GR86
2013 Scion FR-S
briang0901 is offline   Reply With Quote
Old 04-13-2024, 03:07 PM   #2
whataboutbob
AutoX-10/10ths every run
Looks like it isn't included:
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
Borrowed Time (04-21-2024), briang0901 (04-13-2024)
Old 04-13-2024, 03:16 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
I swapped over the spare from my '17 PP along with the styrofoam bits, all fits
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Borrowed Time (04-21-2024), briang0901 (04-13-2024), Busybee (04-14-2024)
Old 04-14-2024, 07:42 AM   #4
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Do you know if the Styrofoam placeholder out of the '24 models fits well on the first gens? The OEM spare doesn't fit over my brakes, so no sense in lugging it around. It would be nice to have an OEM solution to filling that gap though.
gkubed is offline   Reply With Quote
Old 04-14-2024, 08:11 AM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
I can't think of a reason the '22+ stuff shouldn't fit in 1st-gen tire well...
Old 04-14-2024, 10:57 AM   #6
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Is the tire well also fitting the 18”. Not sure how to organize it for the 18”. Also, the spare needs to be something that clears the Brembo.
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 04-14-2024, 01:32 PM   #7
ruturaj001
Drives: BRZ 2023
PP cars came with 17" spare while rest came with 16" spare in previous gen. Wheel well, brembos package are all still same. I wrote a guide with part numbers on GR86 forum for PP
https://www.*********/threads/how-to....3808/#replies
ruturaj001 is offline   Reply With Quote
Old 04-14-2024, 01:42 PM   #8
ruturaj001
Drives: BRZ 2023
Last generation twins came with spare in rear which had 16" wheel but there was also a different spare for performance package. Performance package spare had 17" wheel in order to fit over Brembos.
Not specific to PP or regular
Spare Tire Bolt : 901720002
Spare Tire Washer: 97047FG000
Performance specific parts
PP Spare Wheel: 28151FE030
PP Spare Tire: 28121VA050
PP Spare Foam Insert: 95086CA070
PP Spare Foam Spacer: 97046CA000
Regular spare
Spare Wheel: 28151FJ031
Spare Tire: <Still looking>
Spare Foam Insert: 95086CA040
Spare Foam Spacer: 52153PA181
The Following 2 Users Say Thank You to ruturaj001 For This Useful Post:
Busybee (04-14-2024), Ohio Enthusiast (04-14-2024)
Old 04-14-2024, 01:51 PM   #9
Busybee
Busybee's Avatar
Regular spare
Thanks for posting here. Was checking the tread in the other GR86 forum. All great info.
Getting a trueno so I assume I will need all parts. Was previous gen PP cars 18” and spare 17? If that’s the case I can do the same set up. But read that having the 17 spare on the rear there will be 0.2 difference. Will that affect?
I wish that the 18” wheel and tires fit the styrofoam directly so no change will be needed .
Old 04-14-2024, 01:57 PM   #10
ruturaj001
Drives: BRZ 2023
Yes, previous gen PP came with 17" spare and 18" wheels.
You never install spare in rear. If rear has puncture then you have to put spare in front and install front in rear.
Busybee (04-14-2024), Stephen W. (04-24-2024)
Old 04-14-2024, 02:04 PM   #11
Busybee
Busybee's Avatar
Thanks for all the great info.
Looks like getting the below parts and a fitting jack (I think someone had the part # in the forum) will solve all the issue.
Spare Tire Washer
Old 04-14-2024, 02:06 PM   #12
ruturaj001
Drives: BRZ 2023
Spare Tire Washer
It should. See if any BRZ owner wants to sell the jack, it comes with a jack so I didn't bother looking up part number. If some BRZ owner doesn't want to add spare then probably won't need jack either.
The Following User Says Thank You to ruturaj001 For This Useful Post:
Old 04-14-2024, 02:34 PM   #13
Busybee
Busybee's Avatar
Just curious!
Does the GR86 come with the 3 pieces Styrofoams on each side and behind the seat which fits the jack and other pieces
Thanks
Old 04-14-2024, 03:56 PM   #14
OldBiker
Drives: 2023 Gray BRZ
Perhaps a little off-topic... I think a plug-kit + pump + jack/wrench is the best combo for these cars. Just remove the tire, plug it, inflate, then re-mount. Easy peasy. (And there appears to be a cosmic rule that one will not have a flat if properly prepared for it.)
OldBiker is offline   Reply With Quote
The Following User Says Thank You to OldBiker For This Useful Post:
2024 ts trim Shub Deetle BRZ Second-Gen (2022+) — General Topics 30 01-25-2024 07:38 PM
S-FR.... or not (TAS 2024) spike021 Other Vehicles & General Automotive Discussions 7 01-23-2024 05:30 AM
PRICING ON 2024 BRZ ruturaj001 BRZ Second-Gen (2022+) — General Topics 12 11-16-2023 12:23 AM
2024 BRZ tS Releaved Rainy BRZ Second-Gen (2022+) — General Topics 55 08-12-2023 04:20 AM
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 09:36 PM
