#71 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | RT-BRZ (04-12-2024) |
#72 |
Just curious if there are any high temp greases that you would recommend?
#73 |
#74 |
Drives: BRZ 2023
I guess if one is swapping pads for track and road, one can spray every time putting street pads. It's more of issue for someone like me who wants hybrid pads like CP.
#75 |
Drives: 2020 toyota 86
CRC Disc Brake Quiet
Works great with Carbotechs...no noise at track for me.
#76 |
Drives: Crapcan
They are really good though. I lost count of how many track days I did on the C1’s with a stop tech BBK. It was at least 12 and around 20k street miles. I absolutely melted down a set of XP10’s in half that time so price wise it does pencil out. Downside is they are hard on rotors at street temps, the C1 anyway. One thing I really liked about the C1’s was the pedal feel at the edge of ABS engagement. They are very positive feeling and consistent and it was especially noticeable in braking zones that had a bit of camber to the track or a crest. I am branching out and trying a few other pads this year but I know I could always go back to them.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#77 |
Drives: Crapcan
We need to look at OnGrid’s schedule and try to hit PIR on one of their days. They are a good group and price wise very affordable. They usually run a TA event in conjunction and there are a TON of twins, first and second gen, that run it.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (04-13-2024), villainous_frx (04-14-2024) |
#78 | |
Drives: BRZ 2023
| The Following User Says Thank You to ruturaj001 For This Useful Post: | NoHaveMSG (05-01-2024) |
#79 |
Drives: BRZ 2023
Hey Mike, how long do you think the CP with B-M4 would last vs CP with stock calipers? Just thinking if I should just run season on CP with stock calipers or just get BBK.
#80 | |
There's no way for me to predict exactly without having extensive data from you and your car |
#81 |
Drives: BRZ 2023
Ordered 225 sx2 and 17x8 ultragrams wheels. I am not sure if I should get camber plates instead of using 2 camber bolts.
#82 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I understand some people love them, and I thought I did, until I tried some others. I eventually settled on Carbotech, but I may switch to Gloc just to be consistent with the miatas.
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#83 |
Drives: 17 Asphalt 86
| The Following User Says Thank You to RToyo86 For This Useful Post: | ruturaj001 (05-07-2024) |
#84 |
Camber plates are safer for sure and not super expensive. Also really enjoying my C21/C11 combo. With stock calipers and the CSG pads I have better pedal feel and bite than my old RR racing BBK and Carbotech. Way less pedal force needed. This is with Lowerend 200TW tires IE v730 levels of grip
2013 Series 10 FRS #553
| The Following 2 Users Say Thank You to jflogerzi For This Useful Post: | CSG Mike (05-10-2024), ruturaj001 (05-07-2024) |
| Wheels setup advice to learn drifting | ShadowTS | Tracking / Autocross / HPDE / Drifting | 2 | 03-22-2016 04:26 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 07:36 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 11:48 AM |
| How does the ECU learn? | boredom.is.me | Software Tuning | 19 | 10-10-2013 09:29 PM |
