#4943 | |
Drives: 2016 Scion FRS Release Series 2#439
I had my stock flywheel re-surfaced as my OEM clutch was fine when replaced. The shop said the Toyotas advice to always use a new flywheel is just profit making nonsence.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#4944 |
Drives: 86
I'm starting to swap my clutch right now as well. Attempted it with the supercharger left on but have come to the conclusion it's not worth it and I'll just be pulling the charger.
Now that I've settled on pulling the charger any tips on any maintenance I should perform while getting it off? Only thing that comes to mind is the intake manifold gasket/maybe the belt. Dumb question but does the edelbrock unit leverage the stock intake manifold gasket or is it a bespoke edelbrock part? |
#4945 | |
#4946 |
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Has anyone run a smaller SC pulley on a stock engine using 91-94 octane gas ?
To gain some additional power I'm occasionally running 98 octane Sunoco 260GTX, Trick 100 from the 76 station in Auburn Wa. or 102 octane Fury SL99 mixed down to 98 with a 3rd fuel MAP from CSG Zach. ( I love the smell of race fuel in the morning ). But that gets expensive fast and, for road trips, requires transporting the fuel in the trunk. I was considering E85 but availability is scarce in BC and I'd still have to transport it on trips. I know... there's probably not an easier/softer (less expensive) way.
The best thing about the future is that it comes one day (and curve) at a time.
#4947 | |
#4948 |
My #2 piston broke on-track while running the stock pulley and short block on 94.
I have a 3” pulley and 700cc injectors on the bench ready to add now that my new forged short-block is broken-in. Zack will re-tune come that time. IMO, I wouldn’t risk the smaller pulley on the weak OEM block. You’d just be begging for trouble.
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) Last edited by Muskoka800; 04-11-2024 at 12:55 PM. Reason: Grammar |
#4949 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I've got to agree with Muskoka, the stock block isn't worth running on a smaller pulley unless you've got money for a second built bottom end. The FA20 doesn't handle detonation very well. My original block blew due to a bad Delicious Tuning product while sitting on cruise control at 75 mph. Also, the stock block with it's high compression ratio wouldn't give you much gain without a big increase in problems. E85 and exhaust modifications are your best bet for more power before a full build.
#4950 | |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | B T (04-15-2024) |
#4951 |
Thanks to BT and Muskoka800 for your input, you've confirmed my suspicions.
I guess it's time to save for a built block. I agree that Zach is "the man" for tunes. When re & reing the SC, in my mind the cost of installing new intake manifold gaskets is a small price to pay versus using the old ones and the possibility of leaks. And if the SC is off for some reason it's an opportune time to pull the Direct Injectors and have them cleaned/flow tested. Cheers Guys !
| The Following User Says Thank You to Brewster For This Useful Post: | CSG Mike (04-17-2024) |
#4952 |
My supercharger has had an issue where the internal bypass butterfly valve will float under operation and get stuck in there causing no boost to build. It's worth taking a look while it's off and seeing if there's any play in the rod between the vacuum actuator and butterfly.
#4953 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Brewster (04-17-2024) |
#4954 |
Sadly there's very limited "at the pump" E85 retailers in our province.
#4955 |
Drives: brz 2017 hksv2
maybe you can try some booster like Bardhal BSF?
it s no where near e85 of course but they add some octane we have no e85 in italy ,when we use those concentrated octane booster we get nice gains on boosted cars even when added to 100Ron fuel (around your 92-93 oct) things with toluene, MMT and other expensive dangerous stuff tend to also spoil spark plugs and colour everything of orange inside the engine but work quite nice for octane booster purpouse and it s just carrying around a half litre bottle instead of barrels in ur trunk and no increased fuel consumption compared to e85 but of course no cooling advantage Need to be tuned though or engine just gets lazy, it seems they slow flame speed a bit |
#4956 | |
CSG Mike has previously commented on these products and their shortcomings Until I can obtain a reasonable supply of E85 and buy a good quality Flexfuel kit, I'll stick with name brand higher octane race fuel for those "special runs"
| The Following User Says Thank You to Brewster For This Useful Post: | CSG Mike (04-18-2024) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
