#267 |
Drives: 2015 midnight blue limited edition.
#268 |
Drives: brz 2017 hksv2
e85 coul give you a lot more gain than +20hp peak
#269 |
Drives: 2015 BRZ WRB
#270 |
Drives: 2017 BRZ w/PP
#272 | |
Missed the mustang dyno part. Makes sense when you add 5-10% to get dynojet numbers. Taking the base run numbers and doing back of the napkin fast and furious math also pretty much matches |
#274 | |
![]() Sent from my Pixel 6 Pro using Tapatalk |
#275 |
Drives: 2013 86
Harrop supercharged
-Rod/Eaton PSI
-Harrop SC -98ron -9psi -85mm pulley, billet 90mm 11.5:1 pistons (2.2L), custom LAsleeve liners, forged rods, lightened OEM valves, lightened OEM flywheel, WRX oil pump, minor head porting, fully balanced. Stock exhaust, airbox/filter, injectors. ECUtek tune. |
| The Following User Says Thank You to Eaton PSI For This Useful Post: | tomm.brz (03-26-2024) |
#276 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
IAG Closed Deck Block Cometic Head Gasket (lowering compression to 12.2:1) Edelbrock Supercharger with 2.70" pulley E80 Fuel with Ptuning flex kit Radium in tank pump with Warlbro 450 Radium parallel feed fuel rails IDX1050 injectors JDL 4-2-1 headers CSG 70mm exhaust Built heads with Ferrea oversize valves and springs, ported/polished/radiused Fluidampr Harmonic balancer ACT clutch/flywheel 3.7 Final Drive |
| The Following 3 Users Say Thank You to B T For This Useful Post: |
#277 |
330.5 whp/228 Ft-Lbs
Mainline Hub Dyno IAG 600 12.5 Compression 86.25mm Bore GSC Valves and Valve Springs Fluidampr SouthBend Stage 2 Endurance Clutch, 4140 Billet Flywheel Harrop SC with 85mm Pulley E70 Fuel with PTuning FF Kit Radium In Tank Hanger with Walbro F90000267 Radium FPR Surge Rank with Walbro F90000267 IDX 1050 Injectors JDL 4-2-1 Headers JDL FP/OP Dual Resonated Perrin 2.5" Resonated Exhaust 3.91 22+ Auto Diff
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | StraightOuttaCanadaEh (05-16-2024) |
#278 |
Wes
interesting that you went with 12.5 compression, usually people go in the other direction and get 10.1 iirc
Instagram: @gt86ws
#279 |
Power numbers are still relatively small, for what it is. 10.1-10.5 just gets to you to the point of requiring more boost and further increasing lag. etc
Kyle H. - #89 STX
#280 |
Wes
Oh and I see they were able to get around the recent ecutek restrictions? Or is this dyno plot from before the changes?
Instagram: @gt86ws
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
