| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#19853 | |
I've been doing it wrong all these years.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (01-20-2024) |
#19854 |
Drives: 2013 frs base
#19855 |
Drives: Crapcan
Like this. Tons of leverage, quick to adjust.
#19856 |
Drives: 2017 Subaru BRZ w/ PP
Today, I installed my new head unit cover. The fitment was absolutely perfect
#19857 |
Drives: 2017 BRZ - WRB
Got fresh fluids front to back
| The Following User Says Thank You to Oxyg3n For This Useful Post: | Wally86 (04-29-2024) |
#19858 |
30 minute maintenance
Drives: My18 wrxsti
Coolant, brake and clutch fluid?
#19859 |
I probably should be thinking about those next tbh. Brake fluid and spark plugs are next up on my list. Might pay someone to do those though since I'm getting old
#19860 |
New drive belt, brake fluid, transmission fluid, differential fluid, oil change, full alignment, pvc valve replacement and new Michelin PS/4 tires last week.
70k miles. Will replace spark plugs later this year. |
#19861 |
Did you do these yourself? I'm curious how much it costs to pay someone to do brake fluid.
#19862 |
Drives: 2017 BRZ PP, 2004 WRX
After 4 years of ownership, I finally made some more substantial modifications. Bought some RCE SS-1 coilovers locally and paired them with some SPC RLCAs. Alignment isn't done yet and is schedule for a week from now. Old wheels and tires are back on for now. New wheels are the Apex Arc-8 in 17x9, 245/40/17 A052's.
I've modified Subarus for 15+ years now, but I've never owned coilovers. Setting the ride height is turning out to be a pain. The front was more or less maxed out and sits about at stock height. I was adjusting by hand and that some point in raising it in the rear I couldn't get any more turns out of it without a spanner wrench, which I need to go buy. I'm trying to get it only about 20mm lower than stock ride height. The driver's side rear seems to be sitting 1/2 inch lower than the passenger side despite being threaded up a good inch more than the other side. I'm going to redo the rears to see what's going on there.
| The Following 3 Users Say Thank You to cmiovino For This Useful Post: |
#19863 |
Drives: 2017 BRZ series.yellow
Put her back down on the ground after being on jack stands all winter. Gave her a bath and headed to the first autocross (for me) of the season.
| The Following 4 Users Say Thank You to Breezio For This Useful Post: |
#19864 | |
I've been running DS for 4 years and actually never owned adjustable coilovers only any of the cars I've run. My front is set at about 5 1/2 inches at the pinch welds, which allows me to just squeeze my low profile jack under the front in the middle. Rear I was playing with since the rear driver's side needed to be raised a good bit to get even with the other side. I'm now sitting at about 6" at the pinch welds in the rear, which more or less makes the rear wheel gap look close to stock. Not sure if the height is going to affect handling much. Still need to get around town (at least to events) and PA has a much of potholes and hills.
| The Following User Says Thank You to cmiovino For This Useful Post: | Breezio (03-21-2024) |
#19865 |
I like to measure from the ground to the fenders, or center hub to fenders.
In which case, from center hub to fender, I'm at 13" in the front and 13" in the rear. Not super low, be certainly a good bit less then stock height. Even if you had decent roads you don't want to go too low, especially in the rear as it can cause extra stress on your axles. |
#19866 | |
Just measured: 13.5" front and about 14.25" rear. The rear is sitting a bit high for sure. Car also hasn't been moved since it was last up, so it usually settles about a 1/4" inch. Probably need to come down a good 1/2" to 3/4" in the rear. Thanks for the measurements.
| The Following User Says Thank You to cmiovino For This Useful Post: | Breezio (03-25-2024) |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 08:53 AM |
