Old 03-08-2024, 05:22 AM   #1
lapsio
lapsio's Avatar
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
Stronger driveshaft replacement?
Hello
I have stock (engine-wise) 2020 BRZ and it seems I have bent driveshaft joints after 3 years of use (possibly leading to transmission leakage which was detected first). Since OEM driveshaft is kinda expensive (around 1500 usd in EU) I'm considering some aftermarket options that wouldn't fail so quickly,
Any suggestions? Is it... I wouldn't say "normal" but within expectations to kill driveshaft on stock BRZ in 3 years? It's driven pretty hard, also on track, using tw80 / tw100 tyres so there may be some slightly increased stress on it coming from increased grip but it shouldn't be too bad I believe... I dunno.
lapsio is offline   Reply With Quote
Old 03-08-2024, 09:30 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’ve never heard of someone killing a stock driveshaft in one of these.
You are limited to the carbon fiber aftermarket options. DSS or PST. I don’t think Verus makes their’s anymore but they used to have one.
The DSS aluminum is not an option for cars seeing over 110mph. @blsfrs had one fail and did a thread on it. DSS admitted the diameter is not enough and the critical speed of the aluminum shaft is too low.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (03-08-2024), DarkPira7e (03-08-2024), lapsio (03-08-2024)
Old 03-08-2024, 09:50 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
IMHO: I'd stick with the stock one.
https://www.ft86club.com/forums/showthread.php?t=154478
The Following User Says Thank You to blsfrs For This Useful Post:
NoHaveMSG (03-08-2024)
Old 03-08-2024, 01:28 PM   #4
OP is in Poland.
@lapsio, I agree with others. Stock is the only safe bet. Something very strange must have happened to damage your original.
blsfrs (03-09-2024)
Old 03-08-2024, 06:26 PM   #5
Grady
Grady's Avatar
Stock is your best bet. All one piece upgrades will have speed limitations and are more susceptible to physical damage. If your stock got damage my bet it was from hitting something.
The Following 2 Users Say Thank You to Grady For This Useful Post:
blsfrs (03-09-2024), Ohio Enthusiast (03-08-2024)
Old 03-09-2024, 10:16 AM   #6
blsfrs
blsfrs's Avatar
OP is in Poland.
According to USPS, shipping a 20lbs item to Poland would be around $220. There might be cheaper options. That's better than $1500 for a nude one.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
humfrz (03-09-2024), Ultramaroon (03-09-2024)
Old 03-09-2024, 03:53 PM   #7
Do they not have wrecking yards in Poland?
blsfrs (03-10-2024), Ultramaroon (03-09-2024)
Old 03-09-2024, 07:54 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I've had my CF one piece up to 120mph a couple times. Smooth as silk.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
blsfrs (03-10-2024), Grady (03-09-2024), SuperTom (04-17-2024)
Old 03-09-2024, 10:26 PM   #9
Grady
Grady's Avatar
I have a Verus and at 130 it starts to have a harmonic vibration.(it does not vibrate but makes a noise) You can push it past but if you do it repeatedly you are goin to have a catastrophic failure.
Old 03-09-2024, 10:57 PM   #10
Oh, hell yes. Good point.
Old 03-09-2024, 10:58 PM   #11
Also a good point.
...well, question.
humfrz (03-10-2024)
Old 03-10-2024, 03:10 AM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Mine is DSS.
Old 03-10-2024, 10:13 AM   #13
blsfrs
blsfrs's Avatar
Several months ago (in a galaxy far, far away) Didn't someone post about a CF driveshaft failure on their rally car.
Old 03-10-2024, 10:38 AM   #14
Grady
Grady's Avatar
Mine is DSS.
Looks like about same diameter, that ones critical speed will be similar.
The Following User Says Thank You to Grady For This Useful Post:
blsfrs (03-10-2024)
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft Brzzee Transmission and Driveline 1 09-14-2018 09:22 AM
Driveshaft Shop Carbon Driveshaft for Manual Transmission for Sale!! (SOLD) GT86Asia Transmission and Driveline 3 07-30-2018 04:06 PM
Nameless 2.5" catted/resonated overpipe + Driveshaft Shop aluminum driveshaft #my86build Engine, Exhaust, Transmission 11 02-04-2017 05:42 PM
