Old 01-08-2024, 02:09 PM   #253
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Originally Posted by Arthur-A View Post
Interesting, does that mean the car won't inherit the Gen2 oil pressure issues as they seem to be caused by the oil pan difference?
Possibly....
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 02-08-2024, 09:47 PM   #254
Opie
Opie's Avatar
Does anyone have a picture of the actual cylinder heads from an FA24 from a BRZ/GR86?
I ask because I have an idea that has been brewing in my head....
FA24 block and cylinder heads with FA20 cam carriers, cams, front timing cover and oil pan (upper & lower).
IF, and I say IF, this all goes together this would be a drop in FA20 replacement. It obviously would need a tune to make it happy but based on parts diagrams only it looks feasible. I have the ability to try and assemble this...looks like about $5k in parts (FA24 short block + L & R FA24 cylinder heads. I have a donor FA20 to get the cams, carriers, front timing cover and oil pans from.
Anybody want to donate $ towards the parts, or donate an FA24, to see if this works? I'll put up $2500 of my own money....
2023 GR Cup Car
Old 02-09-2024, 06:30 AM   #255
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I don't have that information, but you can get the '22 service manuals from my sigline and see if there's anything there that may help.
Old 02-09-2024, 08:52 AM   #256
Opie
Opie's Avatar
Appreciate it, I've got access to the entire Subaru Service Manuals as well.
2023 GR Cup Car
Old 02-09-2024, 12:57 PM   #257
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Might be interesting as a proof of concept.
Using a non-OEM tune going forward as a marketing leader may be difficult.
It could fly in Florida. Will be hard to pass a smog test elsewhere.
Track only transported would likely work for the time being.
Does using 20 cams offer some sort of advantage over the 24's?
Old 02-09-2024, 02:23 PM   #258
But there's only space for four.
Old 02-09-2024, 05:30 PM   #259
FrickingReallySlow
Drives: 2015 FR-S
@Kevin Vo tore down his GR86 you can ping him, I've seen a few more FA24D engine tear downs. Maybe you guys do a collab for YouTube, he needs content
FrickingReallySlow is offline   Reply With Quote
Old 02-09-2024, 05:41 PM   #260
Opie
Opie's Avatar
Not so much the cams, but the cam phazers to keep the computer happy...
2023 GR Cup Car
Old 02-09-2024, 06:01 PM   #261
Opie
Opie's Avatar
Hmm after watching that I'm even more convinced it'll work...it may also be possible to run the FA24 cams with the FA20 cam phazers....
2023 GR Cup Car
Old 02-09-2024, 06:06 PM   #262
RedReplicant
Drives: None
There is a guy in the FT86Club Discord that has a 2017+ car running a FA24 longblock with few FA24 sensors and a few repinned wires. Are you sure they even need to be swapped?
RedReplicant is offline   Reply With Quote
Old 02-09-2024, 08:55 PM   #263
Opie
Opie's Avatar
For a 2013 - 2016 car, yes.
2023 GR Cup Car
Old 02-09-2024, 09:44 PM   #264
RedReplicant
Drives: None
Sorry, I missed the part where that year range was mentioned.
Old 02-10-2024, 01:33 PM   #265
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have a whole spare long block I got for free. 2013. I can get you whatever parts you need in it. Keep in mind, my understanding is that the cam trigger wheels may not bolt up to the fa24 cams. RS Motor’s is making different ones. Here is a picture they posted on FB. May be able to mod the stock ones to work but IDK.
Old 02-10-2024, 07:23 PM   #266
Opie
Opie's Avatar
I'm looking for 2022+ Cylinder heads, I've also got a 2013 long block. I've seen RS Motor's solution which is great, but I'm not so thrilled about the modification needed on the FA20 cylinder heads to make the FA24 work, that's why I want to try the FA24 short block & heads with the FA20 upper oil pan, timing cover cam carriers and camshafts....
2023 GR Cup Car
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
