Old 02-06-2024, 09:57 AM   #15
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by Ohio Enthusiast View Post
Are you referring to this one?
Does the built-in "Engine Oil Temperature" not work for you that you use a custom PID?
Yes the same one.
Honestly did not try, since I'm more accustomed to creating user-defined PIDs - I can give it a try tomorrow.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
Ohio Enthusiast (02-06-2024)
Old 02-07-2024, 05:31 AM   #16
FR-Saliba
FR-Saliba's Avatar
Drives: 13' Scion FR-S 10 Series
Originally Posted by Compelica View Post
Yes the same one.
update us if its the same
and which adapter are you using
FR-Saliba is offline   Reply With Quote
Old 02-07-2024, 08:24 AM   #17
Compelica
Compelica's Avatar
Drives: 86 GT
Yes the same one.
Tried today - got a "no data received".
Vgate Vlinker FS BT
Ohio Enthusiast (02-07-2024)
Old 02-07-2024, 08:42 AM   #18
Ohio Enthusiast
Drives: 2018 BRZ
Amazing! I tried the custom PID and also got "no data received". The built-in "Engine Oil Temperature" worked fine.
I guess folks should try both variants of the oil temp PID and see what works for them.
For reference, my OBD dongle is "Veepeak Mini Bluetooth OBD2" from Amazon.
Old 02-07-2024, 09:45 AM   #19
FR-Saliba
FR-Saliba's Avatar
I think mine is same as yours but different branding.
am gonna try reading both custom and built in today, if it doesn't work
am gonna try installing the app from the small cd that came with the dongle.
Old 02-07-2024, 09:56 AM   #20
FR-Saliba
FR-Saliba's Avatar
did someone ever try to compare the ECU results with an aftermarket oil temperature system/gauge ?
Old 02-07-2024, 08:44 PM   #21
Compelica
Compelica's Avatar
Drives: 86 GT
Interesting. I use a generic blue ELM327 as well, and the custom PID didn't work for me with the free Torque app, but the built in Engine Oil Temperature "sensor" works fine with the paid Torque app.
Nice suggestion about the ELM327 Identifier app - my OBD dongle passed up to 1.4, then failed 1.4b and above.
What's the custom PID that you use for oil temp? I've seen a few variations but none worked for me with the free Torque.
Something that came to mind - do you know which ECU calibration that you're using?
It won't be the same, since the location where the oil temperature is read will play a role.
I recall reading posts somewhere buried that it was accurate enough.
Old 02-07-2024, 09:08 PM   #22
Ohio Enthusiast
Drives: 2018 BRZ
No idea. My car's drivetrain is stock, no tune. So I guess whatever came in North America in 2018 BRZs.
Old 02-08-2024, 03:19 AM   #23
FR-Saliba
FR-Saliba's Avatar
But i think the difference shouldn't be that big tho, if the oem temp sensor is accurate.
I tried testing my OBD adapter with the ELM327 identifier, it wouldn't even connect to it
Although the adapter connects to the ECU and torque app normally, but was giving unable to connect everytime i tried the identifier app.
Old 02-08-2024, 06:32 PM   #24
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
I am using a generic (read inexpensive) eBay ELM-327 BT unit with the free version of the Torque App on my Android head unit. Using it to bring up 6 dial gauges:
* Coolant temp
* Oil temp
* Throttle position
* Engine speed
* Instant MPG
* Ambient temp
The list of available values appears when adding a new display element - no PID codes required.
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
Ohio Enthusiast (02-08-2024)
Old 02-09-2024, 07:44 AM   #25
FR-Saliba
FR-Saliba's Avatar
* Coolant temp
* Oil temp
* Throttle position
* Engine speed
* Instant MPG
* Ambient temp
the built in oil temperature with the free version from the playstore?
i thought this wasn't possible
are you you tuned or stock ?
btw the elm327 identifier app worked with me but gave me couple failed ones when i did the test
although coolant temp, ambient temp, rpm ... a lot of things are working but the one i want the most (oil temp) is not working
builtin nor pid
Old 02-09-2024, 11:47 PM   #26
jflogerzi
jflogerzi's Avatar
If you want something that will Just work as an alternative
https://www.p3cars.com/subaru/p3-v3-...uge-2012-2020/
Or cheaper is
https://www.amazon.com/ScanTool-OBDL...7-93deae8f9840
+ Race Chrono to tap into Can bus.
2013 Series 10 FRS #553
Old 02-10-2024, 10:26 AM   #27
Compelica
Compelica's Avatar
Drives: 86 GT
A wild guess but it's likely that some newer calibrations have the oil temperature accessible via the OBD2 standardized PIDs (the one coming from the link earlier is from the Toyota-specific PID) which could explain why for some owners, the Torque app would work right out of the box and some wouldn't - like mine.
Ohio Enthusiast (02-10-2024)
Old 02-13-2024, 10:51 PM   #28
tarzan_nojane
Drives: 2014 FR-S
Stock
Differential Temperature fika84 Engine, Exhaust, Transmission 42 07-31-2018 08:14 PM
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
E85 and oil temperature jvincent Engine, Exhaust, Transmission 11 11-12-2014 08:53 PM
Intake Air Temperature sw20kosh Forced Induction 18 06-19-2013 04:49 PM
Exterior temperature 2thdoc Scion FR-S / Toyota 86 GT86 General Forum 15 04-28-2013 04:45 PM
