Old 02-01-2024, 10:23 AM   #1
jamestemperante
Drives: Subaru BRZ
Control arms and toe arms
Hello everyone! I just want to ask if this LVTU adjustable lower control arm and toe arms are worth running? Any one here rocking these and what are your insights about this product?
Thanks!
jamestemperante is offline   Reply With Quote
Old 02-01-2024, 09:54 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What are you trying to do with the car, how low are you from stock ?
jamestemperante (02-02-2024)
Old 02-02-2024, 01:03 AM   #3
jamestemperante
Drives: Subaru BRZ
I'm trying to add some negative camber. I'm on KW v1 coilover
Old 02-02-2024, 02:18 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Translated: Doing it for looks not performance.
And if that's the case. Get what ever you want it doesn't matter if all its going to see is normal driving and hardparking.
The Following User Says Thank You to x808drifter For This Useful Post:
jamestemperante (02-06-2024)
Old 02-02-2024, 08:10 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Standard height on those should net you around -2 rear. Well within the range of the stock toe links too. Some cars have issues with uneven camber side to side but chances are you are probably fine on stock parts.
Old 02-02-2024, 12:16 PM   #6
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I'm skeptical of no-name brand parts like this. Hell, I've even seen Verus Engineering lower control arms snap at the attachment points when under autocross loads.
I'd go with SPC RLCAs and call it a day. They just work and have a different adjustment system then most other aftermarket ones that thread in.
You probably don't need toe arms.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Parts Shop Max (PBM) adjustable rear lower control arms & toe arms FS frs_adrian Brakes, Suspension, Chassis 1 04-29-2023 03:45 PM
wanted: rear control arms, toe arms & trailing arms Turbo Canada Classifieds 0 08-14-2018 12:18 AM
Need to buy: stock rear lower control arms/toe arms and intake elbow CoolHandMoss Want-To-Buy Requests 6 07-12-2018 08:44 AM
