Old 08-04-2012, 07:59 PM   #4495
Dimman
Kuruma Otaku
Dimman's Avatar
@serialk11r
Just tried to google 458 cams but some jackass tuner calling themself Cam Shaft is ruining my google, dammit!
Because titanium.
Dimman is offline
Old 08-04-2012, 08:15 PM   #4496
serialk11r
Drives: '06 AM V8V Coupe
No idea. But from a manufacturing point normal cams only really need a 2 axis grinder. Normal cams are slightly 3d in the sense that they have a very slight curve across their face but that curve probably comes from dressing the profile on the grinding wheel. Traditionally they are pretty basic mechanical tracing systems. But that's not going to be the case anymore.
Now if they had a 4 or 5 axis grinder they could do it without too much difficulty. But I'm not familiar with the fancy (more than 3 axis) CNC stuff. Or CNC grinding of any kind.
Issue with cams is they need to be hardened. So they would probably rough 4 axis mill them out, heat treat them, then finish 4 or 5 axis grind them. I could see it getting expensive.
Apparently Bosch used a single fancy 3d cam as a fuel 'map' on one of their early mechanical fuel injection systems.
Landis is the name of a company that does cam grinding machines, I believe.
Darn, that sounds complicated. I'm wondering if we'll ever be able to buy a high revving, continuously variable duration throttleless engine, which would need a solid cam rather than variable lifters to be effective. There's more issues than just the cams of course, you can't get rid of the throttle because you need backup output control (actually you can if you allow a lean burn limp home mode, which the EPA would probably freak out over ), and you need an active PCV system and brake booster, and if cam wear is an issue, you need to have an ECU that can remember how the duration on the cams are affected by wear or else you'd have extremely lethargic throttle response as the engine slowly increases the airflow and lets it register via MAF. 3rd party tuning would be a nightmare lol, but the OEM should be able to dial in the ideal amount of overlap and duration for every engine load level.
If BMW replaces ITBs with this on their M cars, I just might have to buy one someday, somehow, electrical problems be damned. The nerdgasm would be too great to contain. They're the only company with the balls to put out cutting edge engine features like this, unless Honda wants to step it up by reviving their canceled AVTEC (which is supposed to be better than Valvematic, the simplest execution of continuously variable duration+lift).
serialk11r is offline
Old 08-04-2012, 09:15 PM   #4497
NickD
Drives: '05 Corvette
After about 2 months of sitting in the closet, assumed broken, I pulled out my old PC, took everything apart, put it back together, and now it's alive and kicking. wtf. I never took anything apart before it broke, at least not that I know of. Maybe something rattled loose? idk. Stupid computers...
NickD is offline
Old 08-04-2012, 09:28 PM   #4498
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Hey, hey! We have feelings too.
Error 404: Brain not found
Snoopyalien24 is offline
Old 08-04-2012, 10:01 PM   #4499
NickD
nevermind, had it up and running about 15 minutes, was listening to music, everything froze, and it's dead again. :|
NickD is offline
Old 08-04-2012, 10:02 PM   #4500
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Ah... Yeah, it's amazing
ichitaka05 is offline
Old 08-04-2012, 10:07 PM   #4501
OrbitalEllipses
Drives: Attitude
I want a yellow LF-A...
OrbitalEllipses is offline
Old 08-04-2012, 10:12 PM   #4502
ichitaka05
Site Moderator
ichitaka05's Avatar
I've sat in there for a first time (& rev it few time), it's just amazing. Just wow
Anyone has spare $300k that can sponsor me? lol
Old 08-04-2012, 10:26 PM   #4503
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Depends...Will I get a return on my investment?
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
Old 08-04-2012, 10:42 PM   #4504
Snoopyalien24
Mr. Sarcasm
Drivers installed correctly?
If they are, motherboard issues fo sho ORRR bad HDD OR bad RAM
Old 08-04-2012, 11:11 PM   #4505
ichitaka05
Site Moderator
ichitaka05's Avatar
LFA will be on your title, so anytime you wanna drive it, it's yours to drive plus this thing is a magnet! It'll bring hot chicks, dudes, even popos! As you can see, they heard the sweet exhaust sound lol I'll write up more about this event when I come back
Old 08-04-2012, 11:19 PM   #4506
M-17
Ninja Cat Mod
M-17's Avatar
Hey, quick question to my fellow FT86 members and BRZers.
What would you choose? Premium BRZ w/spoiler at sticker price or Limted BRZ at dealer invoice or possible even slightly lower price from that as well... hmm? ? ? ? ? ? ? ?
M-17 is offline
Old 08-04-2012, 11:24 PM   #4507
ichitaka05
Site Moderator
ichitaka05's Avatar
Hm... Tough choice. Between those two choice, I'll go w Limited BRZ
Old 08-04-2012, 11:30 PM   #4508
S2kphile
S2kphile's Avatar
My father always taught me that if you're gonna drop that kinda dough on something it better have a massive return. I'm good in the hot chicks department and dudes/popos I'll just leave it there. Can't wait to read your writings on the event.
S2kphile is offline
