Old 01-13-2024, 11:52 PM   #1
overd0sed
Drives: 2016 FRS RS2, (sold) 2019 Raiu BRZ
FRS Bumper swap on Facelift 2017+ GT86 Toyota
Hello everyone, would I be able to put a FRS bumper onto my 2017+ GT86? I really like the frs trd front lip. Thanks everyone!
overd0sed is offline   Reply With Quote
Old 01-14-2024, 10:50 PM   #2
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
The bumper will fit if you also swap the headlight brackets. But you need to figure out how to deal with the turn signals in the FR-S bumper. That is why no one does the swap.
Mike_ZN6 is offline   Reply With Quote
Old 01-14-2024, 11:25 PM   #3
overd0sed
Hey thanks for the reply!
The turn signals on the 2017+ GT86/BRZ shines from the headlights. Would a FRS front bumper swap affect that turn signals?
Old 01-15-2024, 09:39 AM   #4
gpvecchi
gpvecchi's Avatar
I made the swap. You can find blinkers covers on japanese market.
Old 01-15-2024, 12:59 PM   #5
overd0sed
Hey gpvecchi, thanks for your comment. I am a beginner to this and really want to make the switch. Could you elaborate on the blinker cover or do you have a link to the product so I can visualize it? Thank you!
Old 01-15-2024, 03:30 PM   #6
Mike_ZN6
Mike_ZN6's Avatar
The new bumper will not affect the turn signals in your 2017+ headlights. The FR-S has the turn signals in the front bumper.
Either you can install the FR-S turn signals and wire them up in addition to the 2017+ headlight turn signals (so you will have 2 sets of turn signals on each side) or you can get something to fit into the FR-S turn signal openings. I have seen brake vents that fit into the turn signal openings before.
Old 01-15-2024, 03:32 PM   #7
Mike_ZN6
Mike_ZN6's Avatar
Did you use the brake vents or something else? I would love to see some pics of your setup if you have any.
Old 01-16-2024, 03:27 AM   #8
gpvecchi
gpvecchi's Avatar
https://www.auto-acp.com/86/products...etail1342.html
Old 01-16-2024, 11:09 AM   #9
overd0sed
Thanks! When you made the bumper swap with the frs headlight brackets did it sit flush on the gt86 body?
Old 01-17-2024, 03:22 AM   #10
gpvecchi
gpvecchi's Avatar
You need the bumper, headlight brackets, headlights washers and caps (if you have them), tow hook cap, side blinkers brackets rivets, front logo, fog light grills (closed grills, if have fog lights, you need fog lights too).
Sitting perfectly. On the japanese market you can find a genuine Subaru accessory, led fog lights for pre facelift, made by PIAA.
Old 01-22-2024, 10:06 PM   #11
overd0sed
If i dont use this cover for the frs bumper do you know if I would be able to wire the blinkers for it to work as well? My goal is to have the headlights, frs blinkers, and frs foglights to all work
Old 01-23-2024, 12:38 AM   #12
gpvecchi
gpvecchi's Avatar
The plug is the same, but it misses the blinker wire. The FRS fog lights have 4 bolts, the facelift have 3 bolts.
You should probably get the cable for blikers and foglight from pre facelift GT86 and add a custom wire from the plug to the headlights (I don't know if this is present in facelift cars).
Old 01-29-2024, 12:21 AM   #13
overd0sed
Thanks! I didn't really worry to much about the fog lights or frs blinkers working as I just wanted to make sure the whole swap fits with all the frs blinkers/fog lights. Prefer the frs trd lip kit.
FS: 2017+ New Toyota 86 front OEM bumper facelift bundle "SOLD" gt86ser Exterior Parts (Aero, Lighting, Etc.) 0 03-26-2023 01:55 PM
GT86 2017 facelift bumper installed on pre-facelift 2015 model yoongjun Cosmetic Modification (Interior/Exterior/Lighting) 2 01-20-2021 11:28 AM
2017 Toyota 86 rear bumper swap? YgRoshi Cosmetic Modification (Interior/Exterior/Lighting) 4 11-06-2020 05:08 PM
2017 facelift gt86/brz sound deadening improvements rsingh Scion FR-S / Toyota 86 GT86 General Forum 4 03-27-2018 10:55 AM
2017 Toyota 86 facelift TMXSTAR Scion FR-S / Toyota 86 GT86 General Forum 11 03-17-2016 11:06 AM
