Old 01-11-2024, 12:35 PM   #1
aviator86
Drives: Red 2017 86 MT
CEl Codes Help! p2271, P0138
rremove
aviator86 is offline   Reply With Quote
Old 01-11-2024, 01:03 PM   #2
aviator86
Hey All!
I have a 2017 86 running a stage 2+ tune with catless headers and a TRD exhaust.
I've had this setup since August 2022 with no issues since this morning. Car struggled for a couple of seconds to start and got the following codes. After idling for a few minutes you can tell it's running rich.
P2271 and P0138
Do i go ahead and replace the O2 sensors or is there something else I'm missing?
Car has about 110,000km (68k miles)
TIA
Old 01-12-2024, 12:51 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Why are you making more that one thread?
Pick one and stick with it.
Delete the other or edit the post to say ignore.
Reported.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
aviator86 (01-12-2024), Ultramaroon (01-12-2024)
Old 01-12-2024, 08:56 AM   #4
aviator86
Reported.
Thanks for the help!
The Following User Says Thank You to aviator86 For This Useful Post:
x808drifter (01-12-2024)
Old 01-13-2024, 01:29 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Keep in mind, dtc’s are symptoms, like your car saying “hey I have a headache and my stomach hurts.”
P0138 is bank one sensor 2 high voltage.
P2271 is bank one sensor 2 stuck rich.
It does sound like that sensor is bad but I would also double check the wiring and connections to make sure something didn’t cause the issue and you will have repeat issues. Remember to check wiring on both sides of the connection.
Old 01-17-2024, 10:17 AM   #6
Compelica
Compelica's Avatar
Drives: 86 GT
Are you running O2 spacers by any chance?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
CEL P0138 help. Saviorself Software Tuning 3 08-07-2018 10:24 AM
Several DTC codes ryan.moring Issues | Warranty | Recalls / TSB 5 06-05-2017 07:26 PM
Need help. Video and codes P2271, P0171, C1201, U0100 voidn0ise Issues | Warranty | Recalls / TSB 8 05-03-2017 05:58 PM
DTC Codes pleong Software Tuning 12 06-11-2016 01:17 AM
