Old 08-13-2023, 02:59 PM   #169
billstock67
Drives: 2017 Toyota 86
Have about 3K after MCA install. No other changes at that time.
Previously installed mods: RCE Yellow / Bilstein B6. Whiteline differential & subframe inserts, SPC rear toe arms, Whiteline rear LCA.
Agree with Andrew that rear feels more "natural". For me, also clear improvement. (Street only, have not tracked the car)
Have STI trailing arms on the shelf, will report after install.
billstock67 is offline   Reply With Quote
Old 09-04-2023, 11:51 PM   #170
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
GP Sports also sells a version of this kit without those silver plates. Can this kit be installed on the car without the metal plates, or are rigid collars a necessity?
Originally Posted by Joe-G View Post
If MCA is hard to get, this is an alternative. (not sure if its been shared yet)
Not sure if its any good though...
https://www.gpsports-gallery.com/products/3727/
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 09-06-2023, 09:45 AM   #171
makinen
makinen's Avatar
Drives: Toyota 86
I reckon it can be installed regardless of regid collars but could be better with some kind of similar things.
I installed GP Sports kit without rigid collars, but there have been installed Whiteline subframe insert bushings already. I removed the front bottom urethane insert bushings (left and right) and installed the traction member instead. Still there are 6 urethane insert bushings at the front top, rear top and bottom.
Basically no NVH or subframe movement changed after installation as only two urethane insert bushings substituted with metal ones.
Originally Posted by norcalpb View Post
Do you have a link to the kit that doesn’t come with the metal plates?
At the bottom of this link, you'll find the kit without the metal rigid collars.
Name:  Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB - Reply to Topic - Chro.png
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is online now   Reply With Quote
Old 09-06-2023, 02:43 PM   #172
Danny318
Drives: 2019 BRZ
How do you actually order from gsports?
Danny318 is offline   Reply With Quote
Old 09-07-2023, 06:07 PM   #173
Xed32
Drives: '22 brz Sport-Tech
To those who asked about an equivalent for the front. You would not want that. In Layman's terms the MCA traction mod allows the car to squat during acceleration. Makes it easier to get on the gas early without the back stepping out as force is allowed to go through the suspension and tires instead ( weight transfer is allowed). You would want the opposite at the front, which i believe is what the Jackson racing Anti-dive kit is. That kit tries to keep the car level when braking. "This gives the car a more level stance, allowing the driver to have a more controlled and balanced entry to the corner." I am still thinking about getting that next.
MCA Traction mod allows squat by lessening anti-squat at the rear.
Jackson racing anti-dive kit reduces front-end dive under braking by increasing anti-dive at the front.
Xed32 is offline   Reply With Quote
Old 09-08-2023, 04:32 PM   #174
norcalpb
norcalpb's Avatar
Agree on everything.
The equivalent for the front is the Whiteline “anti-dive kit” which unfortunately reduces anti dive.
The JR kit lowers the front control arm mounting point while the whiteline raises it. Only the JRs mounting configuration is consistent with an anti dive kit.
I personally plan on running the JR anti-dive kit with STi springs to keep the front end from bobbing so much. Also considering the GP sports pro-squat kit over the MCA one as I’m not a fan of how the MCA bolts to the front subframe mounting bolts. Seems to create a lot of unnecessary stress.
The more angled the green lines are in the below photo, the more front anti-dive you have.
Old 12-29-2023, 05:48 PM   #175
norcalpb
norcalpb's Avatar
Just did a traction mod via the GP Sports brackets. It lowered the crap out of the rear end of my brz.
Absolutely loving the change in road feel though. Bumps that would bump me out of my seat no longer do so.
Need to decide if I want to get coilovers vs suspension risers. Currently on RCE Tarmac springs and Bilstein B6 struts/shocks.
Old 01-03-2024, 10:20 PM   #176
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Weird - the MCA Traction Mod has zero effect on static ride height or alignment, and I would have expected the GP Sports piece to be the same in that respect, as it seems to just do the same thing (relocate the front mounting point lower) in a slightly different way...
Tatsu333 is offline   Reply With Quote
Old 01-03-2024, 11:01 PM   #177
makinen
makinen's Avatar
Drives: Toyota 86
It seems like that the spring rates matters.
Old 01-04-2024, 10:31 AM   #178
PulsarBeeerz
Drives: JRSC BRZ SOLD
The ride height change is odd. Dynamically the rate is softer as there is less jacking force but there should be no change to ride height.
PulsarBeeerz is offline   Reply With Quote
Old 01-04-2024, 11:38 AM   #179
Tatsu333
As PulsarBeeerz says, this mod affects the suspension dynamically only due to a change in geometry by relocating that front pickup point. It has no effect on static spring rates, which are what affect the ride height at rest.
Old 01-04-2024, 11:46 AM   #180
Tatsu333
Old 01-04-2024, 05:12 PM   #181
norcalpb
norcalpb's Avatar
One would think so but the Japanese article author I quoted on page 11 did say it lowers the car about 5mm which is how much mine was lowered by. The trailing arm in the stock position creates more leverage on the shock/spring so it does kinda make sense that with more load on the coil itself that the rear would sag more. Did you adjust your ride height at all after installing your set?
Old 01-04-2024, 05:24 PM   #182
Tatsu333
Nope - I was still on the stock Performance Pack suspension when I installed the MCA Traction Mod, and no ride height change occurred (I did measure before and after).
Could be the GP Sports version alters the geometry in some other way? No idea...
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
