Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
GTC-200 wing, smaller wing or no wing at all?
So I need to get a new setup on the car. I'm wearing the outsides of V730s in about 5 hours and the insides are at 80%. No idea what happened, but it's both sides and there is a lot of negative camber.
While I'm getting a setup done, I'm debating removing the rear wing entirely or just going to smaller one (if that's possible). I see ARP has deferent side plates, but they dont state how much of a difference they make. If it's a big difference, for $120, I'd start there (they also dont tell us the difference between the old, the new and the euro side plates) It just pushes too much as it is, and I can't get much, if any, rotation on braking. As far as running ST5, or similar, what is the general consensus for a wing- if there is one?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#2 |
Drives: Crapcan
What’s the whole setup on the car? My biggest problem adding a splitter and wing(gtc200) was my suspension was no longer up to it.
#3 |
Drives: 2013 Subaru BRZ
#4 | |
Suspension is is fine. Stance coilovers.
#5 |
Drives: Crapcan
Yeah, future prof’d it when I did.
#6 |
#7 | |
Sideplates won't change anything drastic what you're looking for. APR is notorious for having wings that produce too much DF for our cars in particular. They're draggy.
Kyle H. - #89 STX
#8 | |
Drives: Toyota GT86
I would be curious what John says about your setup. 6k/9k is pretty common for non aero builds. But maybe its more slicks and aero that require stiffer springs than just aero alone
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following User Says Thank You to autoracer86 For This Useful Post: | RT-BRZ (01-02-2024) |
#9 |
Drives: Crapcan
I am on Annx CSP’s on 10/12k setup now. I was on older T2’s on a 6k flat setup. I was bottoming the fronts a lot and the car didn’t want to rotate.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RT-BRZ (01-02-2024) |
#10 |
Good to know. Thanks everyone.
Looks like my 6k/9k setup needs to go to 8k/9k. Thanks to a couple of key resources for that info. Last edited by RT-BRZ; 01-02-2024 at 03:09 PM. Reason: Updated the information I discovered. |
#11 | |
#12 |
Front
-.10* toe (total) -3.72* Camber 5.71* Caster Rear .12 total toe -3.02 Camber Stance coilovers (I know... they came with the car, they're honestly not that bad and my track is very smooth so its not a big deal) gutted/caged/etc small splitter V730 tires and obviously, the wing
#13 |
Is that rear on both the front and rear or just the front?
#14 | |
Drives: 2013 BRZ HKS Turbo
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
| FS: SARD LSR Style Carbon wing **wing only* | brzzy | Canada Classifieds | 3 | 03-23-2017 09:58 PM |
| Does anybody have seibon gt wing or apr gtc200 universal wing on their car? | spicyricecake | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-17-2016 08:38 AM |
| FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney | Enalband24 | Exterior Parts (Aero, Lighting, Etc.) | 10 | 01-03-2016 12:24 PM |
| Gauging Interest: Wing or GT Wing?! | awang0528 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 05-01-2013 12:12 AM |
