Old 12-16-2023, 05:56 PM   #715
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Tying things back to space, has anyone heard of MagLifter? NASA proposed using MagLev technology and a ramp to the top of a mountain to launch a rocket into space. This wasn't a new idea, as they discussed.
StarTram and others had their own ideas too. Enter ZDan here...
https://upload.wikimedia.org/wikiped...er_Mankins.pdf
Old 12-16-2023, 07:38 PM   #716
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
In a slightly different vein, King's Dominion near Richmond has a roller coaster called the volcano. I'm sure it's common place now, but it used an electromagnetic propulsion system. It was really cool especially when you weren't expecting it. I heard aircraft carriers now use a similar catapult system. Make it big enough and you could do a space launch. IMHO
Old 12-16-2023, 08:22 PM   #717
Sadly Volcano has been decommissioned, but it was a great roller coaster. It wasn't maglev but as @blsfrs indicated was a linear induction driven vehicle. (no lift it rolled on wheels).
There are several of these in the US and around the world now.
https://en.wikipedia.org/wiki/Launched_roller_coaster
I worked at Kings Dominion before the mountain that was used for Volcano was repurposed for the ride. It originally contained three different rides of less intensity, including a floating boat ride similar to It's a Small World.
Amongst other things, I worked on the construction crew that built the Grizzly rollercoaster and was the first person to ride in it's back seat.
Old 12-16-2023, 11:05 PM   #718
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
@Spuds
"Also, the MagLev doesn't need a power supply to keep levitating. It will keep levitating as long as the speed is over 150km/h (93mph). So when it slows down, the tires will drop down, and the carriage will land as normal."
That statement is pretty interesting because the train clearly takes aerodynamics seriously with the shape of that nose, which seems like it would force the train's nose down, and yet such a heavy train is able to achieve lift at just shy of 100 mph. The Hyperloop proposal says up to 60% of the air would just pass through the fan system out the back, generating a little thrust, but ultimately it would only take a smaller percentage to generate lift, and considering the maglev train, even in a low-pressure tube, that seems reasonable.
I don't think it's aerodynamic lift the keeps the train up. My guess is the magnets on the train induce a current in the lifting coils as it passes by, which keeps it afloat by magnetic levitation. That works whether the train is being pulled or coasting on momentum. That's why you need wheels in the first place. Pretty clever.
As for the shape of the front and rear, keep in mind it has to go both directions, so it's a compromise. aerodynamically it would push the nose downward (to keep the nose in the guide at speed) but then there's a low pressure region behind that because air has momentum. As the front, this design keeps that lift point well behind the nose. As the rear, the same basic thing happens in reverse, plus it's tapered to reduce vortices and other drag effects.
Also: "Build Thread"
Old 12-17-2023, 01:52 AM   #719
Irace86.2.0
Aww thanks, I thought it was air lift by his phrasing that it didn't take extra energy input, which now sounds a little disingenuous, but he was maybe comparing it to the EMS-style suspension system.
Old 12-17-2023, 02:29 AM   #720
Spuds
The Dictater
Spuds's Avatar
Well, as I recall he just said it maintains lift without power, which is a completely true statement. It's just the lift coming from the coils, not aero. The act of moving the magnets on the train across the lifting coils causes an upwards force, without any additional power input. The energy source is the momentum of the train pulling a magnetic field across an unpowered coil, inducing a current in the coil, which produces it's own magnetic field that acts against that of the train. The superconductor magnets on the train will eventually lose their magnetic field without power to cool them, but I suppose it will last long enough for the train to stop.
Cool video.
Old 12-17-2023, 01:12 PM   #721
Irace86.2.0
Cool video.
Yeah, I got that, and that video was a nice explanation. I was just being a little pedantic because the energy that is used to provide the force of linear motion forward also indirectly provides levitation, which yes, if energy is cut then the momentum of the train would still be providing lift, but I was also thinking without energy input to keep the train moving forward that the train would come to a quick stop from the eddy currents, similar to how my Keiser M3i stationary bike uses eddy currents to create resistance against the flywheel and abruptly stops the flywheel at a high setting without my input (I had read that the magnets themselves can act as resistance to impede top speed, whether that is thousands of mph only or not). Maybe the magnets don't cause fast braking inherently without energy input. Overall, I got your point. I was thinking it was semantics on whether someone could truly claim levitation didn't require energy when it actually required lots of energy, just not directly on a force resisting gravity.
Knowing they were superconducting magnets and when he said it takes no energy, I was thinking it was levitating in a quantum locking type of way with the assistance of air at speed to overcome gravity. I suppose if I was being pedantic about myself, the linear energy input of moving the train forward to achieve air lift and potential resistance that needed to be overcome to maintain motion would still be the same situation as the one above. No different I guess.
Like I said in my last post, he was likely comparing EMS MagLev trains that require constant inputs of energy to keep the train levitating, where this EDS system only needs energy of motion forward to levitate, so it is more energy efficient.
Old 12-17-2023, 11:32 PM   #722
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Sadam was getting set up with a boost system, but got shut down pretty hard.
Gerald Bull had it all worked out but other countries saw it as a military threat.
Seems Kim wasn't able to get hold of the IP.
edit: Saw this on Hacker News
Neumann Drive - Using a welding rod recycled from space junk to fuel your ion motor.
Suppose you could load up a bin full of MIG welding wire for fuel.
Hacker News Comments
Neumann Drive web site
Old 12-20-2023, 08:36 PM   #723
Irace86.2.0
Static fire at SpaceX today for Flight 3 Starship.
https://www.space.com/spacex-starshi...-december-2023
EDIT: They are doing a static fire test tomorrow for Booster 10. I don't know when the FAA will approve them for IFT3, but I have to imagine it will be in mid January at the soonest because of the holidays, of course. Will they waste the ships or try for a landing, or will they try for a catch?
Old 12-20-2023, 09:05 PM   #724
Irace86.2.0
I don't know if we have done this, but what is your favorite space/scifi movie or movie series? It can be whatever from a more technical and serious movie like Martian to a more fiction/fantasy movie like Star Wars to Guardians of the Galaxy. I don't care. It can be off world or specifically about space travel.
I'm looking forward to Dune 2 for 2024. Adam Sandler's Spaceman on Netflix might be decent, but I don't know how much it will involve space, as it looks to be more of an alien/earth movie.
My favorite space/scifi movie of all time? I'm a fan of Star Wars and Marvel, but when it comes to space movies, combine Christopher Nolan and Hans Zimmer with a great plot, and it is hard to beat:
INTERSTELLAR
Old 12-21-2023, 12:58 AM   #725
Spuds
The Dictater
Spuds's Avatar
Favorite space movie of all time? I think I gotta say Apollo 13. At least it's a standard that I compare other movies to in my mind.
Movies more into the sci fi realm is harder. I watch a lot of science fiction but I think I prefer television series more than movies.
Old 12-21-2023, 01:09 AM   #726
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The math gets way worse when you add reality into the process.
Old 12-21-2023, 12:23 PM   #727
bcj
Geo Tyrebighter Esq
bcj's Avatar
Darkstar
or
Dr. Strangelove
Old 12-21-2023, 12:46 PM   #728
ZDan
ZDan's Avatar
Drives: '23 BRZ
2001: A Space Odyssey
Which Space Saver will fit? Andrew666 AUSTRALIA 25 06-18-2020 09:07 AM
Cockpit Space Chad86 Scion FR-S / Toyota 86 GT86 General Forum 7 03-15-2014 03:24 PM
First run 86's (Space Saver question) DriftEightSix AUSTRALIA 11 01-10-2013 07:25 AM
FR-S space saver sierra Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2012 12:18 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 12:29 PM
