Old 12-07-2023, 11:19 PM   #253
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
For the other boxes, I may have done something quite frivolous and completely unnecessary. I need to get new tires for off season driving anyway but my options for what to put them on are all high offset stock size wheels that look rather odd with the camber I have. They work, and it's kind of racecar-sometimes cool from a certain angle buuuut it just looks way better with the Arc8s I have for ax. Logical solution is wheel spacers right? 5mm to get to +37 and poof it's fixed. Anyway, it's pretty obvious where I'm going with this...
Also: "Build Thread"
The Following 5 Users Say Thank You to Spuds For This Useful Post:
autoracer86 (12-08-2023), new2subaru (12-08-2023), NoHaveMSG (12-08-2023), Ultramaroon (12-08-2023), villainous_frx (12-07-2023)
Old 12-08-2023, 05:15 AM   #254
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
haha nice.
autoracer86 is offline   Reply With Quote
The Following 2 Users Say Thank You to autoracer86 For This Useful Post:
Spuds (12-08-2023), Ultramaroon (12-08-2023)
Old 12-08-2023, 12:42 PM   #255
NoHaveMSG (12-08-2023), Spuds (12-08-2023), Teseo (12-08-2023)
Old 12-08-2023, 09:02 PM   #256
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
One diagonal is a bit off towards the bolt hole, but otherwise it's quite well aligned. I'm using grimmspeed gaskets so I imagine it will be fine. Might do a test fit this weekend to make sure the output aligns.
Any thoughts on heat expansion problems if the primaries are touching? I imagine that isn't a good thing.
That, I am not sure about.
Spuds (12-08-2023)
Old 12-08-2023, 09:13 PM   #257
As long as it doesn't bind at all, no sweat. If any of the holes are misaligned enough to bind a fastener, file out some clearance.
Could prolly just shove a screwdriver between the pipes to wedge them apart a bit. I have a long tapered wedge for that kind of stuff. Made it out of the bar from one of those trigger clamp thingys.
Spuds (12-08-2023)
Old 12-14-2023, 10:58 PM   #258
Spuds
The Dictater
Spuds's Avatar
Ok so started taking stuff off the car. Here's the good the bad and the ugly.
Good:
-No oil on the under tray.
-My duct tape and glue fix for the front bumper has held up for another year.
Bad:
-Broke one of those plastic clips. NBD I have extras.
-one hole in the header is at least 1/4" off and won't even go over the stud. Not sure what I'm going to do about that...
-Also, I may have a small exhaust leak at the head looking at the gaskets? Strange.
Ugly:
-Oil keeps wanting to get out of both valve covers. See pics. RTV seems to be working for the most part, but if I can't seal this up I might have to do something really stupid.
-Battery terminal is quite corroded, my guess is from excessive heat. Gross.
The Following User Says Thank You to Spuds For This Useful Post:
Wally86 (12-15-2023)
Old 12-16-2023, 03:14 AM   #259
Spuds
The Dictater
Spuds's Avatar
I think I'm going to try to return the new header as defective. It's one thing for the flanges to be slightly off or a hole to need some filing to not bind. In this case I would have to basically drill a new hole or somehow slot the existing one, and my understanding is that stainless is quite hard and therefore a pita to do those things with hand tools. Maybe I'm expecting too much from one of the least expensive headers you can get.
I might be able to make something to seal the ptuning one...
NoHaveMSG (12-16-2023)
Old 12-16-2023, 03:27 PM   #260
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’d take in the car to an exhaust shop and have them weld the slip joints on the ptuning header. They will need to tack it in place then pull it and full weld it.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Spuds (12-16-2023), Ultramaroon (12-16-2023)
Old 12-16-2023, 04:12 PM   #261
Spuds
The Dictater
Spuds's Avatar
I almost called one this morning to ask about that but got distracted thinking about ways to fix it myself.
NoHaveMSG (12-16-2023), Ultramaroon (12-16-2023)
Old 12-16-2023, 05:03 PM   #262
1. Work down to either removing, or revealing the engine.
2. Clean each part as being removed. Prepare them for installation now.
3. Remove manifold studs.
4. Lap the mating surfaces for the manifold flanges. You'll find any low spots. I alternate lapping with gentle application of a quality bastard file.
5. Those valve covers. Fuck. I know.
6. Put it back together with the ptuning header like msg says.
NoHaveMSG (12-16-2023), Spuds (12-16-2023)
Old 12-16-2023, 05:31 PM   #263
autoracer86
Drives: Toyota GT86
If you end up getting a new more expensive header have you thought about other options beyond PTtuning ? I think JDL and ACE are popular with the auto x/track crowd. Although I think quality is hit or mess with the ACE header.
Old 12-16-2023, 06:28 PM   #264
Old 12-16-2023, 10:38 PM   #265
Spuds
The Dictater
Spuds's Avatar
Yes I did. I already have the ptuning so I think I'm going to stick with that unless I can't get it fixed.
autoracer86 (12-17-2023)
Old 12-16-2023, 10:42 PM   #266
Spuds
The Dictater
Spuds's Avatar
Is 1-4 for the head-manifold issue? If so, it's pretty revealed as-is? I don't understand.
2018 Camaro SS 1LE vs Spuds' FRS Spuds FR-S / BRZ vs.... 13 06-16-2019 10:11 PM
FRS from Vroom - RISKY? Cosa Scion FR-S / Toyota 86 GT86 General Forum 14 10-21-2018 09:27 PM
So my key FOB was put in the washing machine.... Kayzer Soze BRZ First-Gen (2012+) — General Topics 11 06-07-2013 11:43 AM
Vroom! - This week's blipshift shirt blipshift Miscellaneous 1 11-13-2012 10:29 PM
